Archive 2021 · Teresa Tribute
Mark Metternich
p.1 #1 · Teresa Tribute
My sister went to heaven 🙏🏼 about 20 minutes before I took this nearly 4-minute exposure, all alone, as the fog was rolling in and wonderful reddish light cut through the fall cypress tree swamp. The long exposure photo I was taking the very moment I got the text notice of her passing (NOT shown here) was so surreal, I knew something strange was going on, and I knew I would also dedicate that one to her as well (once I get the courage to process it, because I want it perfect, to do justice in dedication to her). So, here is 1 of eventually 2, I will produce for my sister Teresa.
I love you Teresa! ❤️ We all sorely miss you!
Make sure you tell them how much you love them! ❤️ 👍🏼 ✌🏼
*The second photo is my sister Teresa, who was one of my best friends and greatest inspirations/mentors in my life. She always pointed me to faith, and she lived her life solely for others, relentlessly serving her family, friends, neighbors, the downtrodden, the outcast, community, church, and so much more with a heart that is rarely seen in this world!
Technicals for the Techie Minded:
The image is a blend of two images shot back to back.
One taken at 240 seconds, f/64, 50 ISO (for long exposure effects as the fog rolled in and light cut through).
The second exposure was taken immediately next to still any potential foliage, taken at 2.0 seconds, f/8, ISO 50.
The Adobe Ultimate Quality 32-bit Raw Layer Workflow was used (as always) to push the higher quality, higher bit depth lossless workflow as far as possible.
After all possible adjustments were made to the long exposure file in Camera Raw, all the same settings were also applied to the shorter exposure.
Then the exposures were matched by adjusting the exposure slider on the shorter exposure to match the long exposure (using the Toggle Sample Overlay tool in Camera Raw (where is that in Lightroom?) to get the exact RGB values for an area in both images at the same time).
Once the exposures were matched, I brought into Photoshop the long exposure as a Raw "Smart Object."
Next, I changed the Photoshop Workspace to 32-bit.
Then I duplicated the Raw Layer and swapped out the top layer duplicate Raw Layer, by replacing its contents, allowing me to bring in the shorter exposure Raw Layer into the stack.
Putting a Black Mask (hide) on it and using the brush tool (soft) I simply dappled in a few areas here and there where foliage was obviously blurred.
I also went through all 10 Vintage, 10 Modern, and 8 Creative Adobe Profiles to see if any of them would improve the rendering. I pulled a very slight opacity (either locally or globally) from a few of them to improve the rendering.
After a few more correction/tweaks by duplicating a base Raw Layer, pulling it to the top of the stack, always making the adjustments in Camera Raw (not using Photoshop adjustments) and then masking in the correction (black mask, white soft brush) the image was done except a few clean up issues, and so forth.
I love how one can save the entire Raw Layer Stack (just like adjustment layers) in the 32-bit space!
Masks are better, graduation is better, you see no typical no noise build up, no slow degrading of the image, no posterization, a lack of artifacts...
More was done to nit pick and finish off the image (like a few slight independent color channel tweaks in Camera Raw Curves to remove slight color casts (locally or globally) very slight dodges, burns, sponge up in saturation, or sponge down in saturation...) but all adjustments were made using Raw Layers and Camera Raw.
There is more to the story, but for those who are interested, that is a bit of it...
All the best to you and your families! ❤️ 👍🏼 ✌🏼
Teresa Tribute 1
Teresa
Edited on Aug 10, 2021 at 12:04 PM · View previous versions
Aug 10, 2021 at 12:01 PM
Rajan Parrikar
p.1 #2 · Teresa Tribute
Marvellous photo, Mark, the kind we have come to expect from you.
And your sister is lovely.
Brian Woolf
p.1 #3 · Teresa Tribute
A beautiful photos and so sorry for your loss.
Brian
Aug 10, 2021 at 12:38 PM
junglialoh
p.1 #4 · Teresa Tribute
I agree to Rajan. Always thanks to you who provided transparent info for impressive and captivated images.
Very memorable image to you, but also memorable image due to its quality of work.
Aug 10, 2021 at 01:18 PM
fotografur
p.1 #5 · Teresa Tribute
Gone too soon. Sorry for your loss Mark.
Aug 10, 2021 at 08:00 PM
zurura
p.1 #6 · Teresa Tribute
Lovely image Mark. And thanks for explaining the processing. That helps in understanding the process.
Sorry for your loss.
Cheers,
Gautam
Aug 11, 2021 at 03:19 AM
Alfredo Mora
p.1 #7 · Teresa Tribute
My deepest condolences Mark.
Wonderful image. Thank you for the detailed write-up.
Aug 11, 2021 at 01:19 PM
MJKoski
p.1 #8 · Teresa Tribute
May she rest in peace now. I wish you well.
I would describe the photo as calm and serene. And perhaps timeless above all. There are lots of trees but still, the outcome is pleasing to look at.
Aug 11, 2021 at 01:36 PM
hm2008
p.1 #9 · Teresa Tribute
Sorry to hear your lost. Thank you for sharing such beautiful pictures and the process details.
Aug 11, 2021 at 01:40 PM
Sashi
p.1 #10 · Teresa Tribute
Sorry to hear about your loss, Mark. The photo you posted does justice to Teresa and it's my belief that the second one will be equally as good, if not better.
Thanks for sharing
Aug 11, 2021 at 02:01 PM
Michael H
p.1 #11 · Teresa Tribute
Wonderful tribute, wonderful image. Thank you for sharing this touching story.
Aug 11, 2021 at 03:00 PM
gordon l
p.1 #12 · Teresa Tribute
Poignant memories are often linked to images I take at the time. This image and your wonderful sister will always be linked in your mind, I suspect. Wonderful image. I'm sure you sister is even more wonderful.
Aug 11, 2021 at 03:17 PM
jcw1982
p.1 #13 · Teresa Tribute
Beautiful photograph Mark and your sister was a beautiful woman. Sad to hear of your loss. Thank you for sharing.
Aug 11, 2021 at 06:58 PM
James Markus
p.1 #14 · Teresa Tribute
Mark, I am sorry to learn of your loss.
Peace
Jim
Aug 11, 2021 at 07:58 PM
roythegreat
p.1 #15 · Teresa Tribute
Mark, my heart weeps to look at her photo. I hope she is doing good with God.
Sorry to hear such a loss. Our condolences are with you and your family.
Aug 11, 2021 at 09:28 PM
mabidally
p.1 #16 · Teresa Tribute
My deepest sympathies dear Mark on your sisters passing may you have courage and strength to bear this loss.
It's a lovely pic!
Aug 12, 2021 at 05:19 PM
John Webb
p.1 #17 · Teresa Tribute
Mark deepest and sincere condolences, It seems that you’ve had a rough couple of years. Your images of the cypress trees in the swamps are just outstanding and I’m sure your sister would have loved them. Take care and hopefully we can meet up sometime as my wife and I are looking to retire in St Augustine within the next year.
Aug 12, 2021 at 08:39 PM
dakel
p.1 #18 · Teresa Tribute
Wow Mark just an incredibly beautiful image and tribute to your sister. I'm very sorry for your loss. I can't imagine losing my sister so my heart and prayers go out to you and family.
Aug 13, 2021 at 12:57 AM
p.1 #19 · Teresa Tribute
First, condolences to you and the family on your loss! She is in a far better place Mark!!
Just a fantastic composition! All the major and finer points of photography composition are displayed here!!
Again condolences..it is hard!
Aug 13, 2021 at 06:36 AM
fcarucci
p.1 #20 · Teresa Tribute
Beautiful image. Sorry for your loss
Aug 13, 2021 at 11:01 AM
