Lens Functions:
A-B Focus: Af is only allowed between assigned focus point A and B
Focus Preset: You can assign preferred focus point and move telemeter with one touch
Focus ring switch: You can switch Focus ring to Aperture Ring
Custom Function Key
Focus Ring customization
MF Ring Rotation: You can change direction of ring rotation
TAMRON Announces Development of 2nd Generation Standard Zoom Lens for Sony E(FE)-Mount
Dramatically improved with optics, AF drivetrain and customizable features!
28-75mm F/2.8 Di III VXD G2 (Model A063)
On August 5, 2021, SunPhoto, the official source of income for TAMRON, a general wide-angle device manufacturer based in Saitama, Japan (CEO Ko Seong-seong), announced the second-generation large-aperture standard zoom for Sony E(FE)-Mount. Announced the development of the lens, 28-75mm F/2.8 Di III VXD G2 (Model A063).
release schedule
For Sony E-mount (35mm full-frame) to be released in 2021
The 28-75mm F2.8 G2 is the superior product of the 28-75mm F/2.8 Di III RXD (Model A036), a popular zoom lens acclaimed worldwide, reflecting constant evolution and user-centered design. The A063 incorporates a new optical structure to improve superior optical performance while maintaining the excellent portability of the existing A036, and is equipped with the VXD linear focus drive, an ultra-fast, quiet AF drive system. This provides faster AF speed and greater precision. In addition, the shortest shooting distance of 0.18m in the 28mm wide-angle section and the maximum shooting magnification of 1:2.7 allow you to experience the world of wide-angle macros, and it features improved handling and design. TAMRON's 28-75mm F2.8 G2, pioneering the market for compact large-aperture standard zoom lenses for mirrorless cameras, is a true next-generation lens capable of recording everyday scenes.
TAMRON's proprietary design software 'TAMRON Lens Utility' that can be customized according to your taste
A063 is compatible with TAMRON Lens Utility software developed independently by TAMRON. You can customize the function by connecting the PC and the lens with a cable (sold separately), and optimize the function according to the purpose of shooting, such as photography or video.
(Introduction of TAMRON Lens Utility function)
● Focus Set button setting
- AB Focus: You can use AF only within this section by setting two focus points (A, B).
- Focus Preset: You can set the preferred focus point and move the rangefinder position with one touch.
- Focus Ring Function (Focus/Aperture): You can turn the focus ring into an aperture ring.
- Function setting on camera: The Focus Set button on the lens can be used to call custom functions of the camera.
*Functions assigned to the Focus Set button can be initialized.
● Focus ring setting
- MF Ring Rotation: You can set the rotation direction of the focus ring.
- MF Method: When using the focus ring, you can set the operation method.
● Firmware update function
Main Features
1. Best image quality among standard zoom lenses in its class
2. Equipped with VXD linear focus drive that realizes high-speed, low-noise, precision AF
3. Shortest shooting distance 0.18m Max shooting magnification (1:2.7 (@28mm)
4. User-friendly design and improved texture design
5. Lightweight, compact design, filter diameter of 67mm
* Product specifications and exterior features are subject to change without prior notice.
TAMRON Announces Development of World's First F/2 Mirrorless Zoom Lens with Maximum Brightness
Travel zoom lens that allows for seamless super-aperture shooting from wide-angle to telephoto
35-150mm F / 2-2.8 Di III VXD ( Model A058)
On August 5, 2021, SunPhoto Co., Ltd. (CEO Ko Seong-seong), the official source of income for TAMRON, a comprehensive wide-angle device manufacturer in Saitama, Japan, announced a large-aperture zoom lens for Sony E(FE)-Mount, 35 Announced development of the -150mm F/2-2.8 Di III VXD (Model A058).
release schedule
The 35-150mm F2-2.8 is a large-aperture zoom lens that covers the range from wide angle (35mm) to telephoto (150mm), optimized for travel photography. This lens, the first Sony E-Mount to achieve a maximum aperture of F2, allows you to capture majestic views, large structures at a wide angle (35mm), and experience dynamic close-up shots at 150mm. Beautiful sunrise and sunset photos / You can take pictures of exotic buildings, interiors, and night scenes with just one lens. Capable of meeting high expectations in a wide range of shooting conditions, the A058 is the ideal lens for travel for photographic production purposes. In addition, the VXD linear focus drive AF system is equipped to achieve high-speed, low-noise AF, and the ergonomic design provides improved operability and texture.
The A058 supports most of the wide-angle, standard, and telephoto areas frequently used by photographers, making it easy to compose the perfect composition without wasting time swapping lenses in front of the shooting location or subject.
The A058 is compatible with TAMRON Lens Utility software developed independently by TAMRON. You can customize the function by connecting the PC and the lens with a cable (sold separately), and optimize the function according to the purpose of shooting, such as photography or video.
* Functions assigned to the Focus Set button can be initialized.
Main Features
1. The world's first F2-2.8 large-aperture zoom lens
2. Multi-purpose design that allows you to enjoy large-diameter shooting without interruption from wide-angle 35mm to telephoto 150mm
3. Unrivaled optical performance
4. Equipped with VXD linear focus drive that realizes high-speed, low-noise, precision AF
Why the move to having mfd at shortest FL? If it could do even 0.25x at 150mm that would be much nicer than even 0.4x at 35mm IMO. Given it can only focus to 33cm at 35mm I'm guessing this is a lower magnification lens. Sony 35 GM focuses at 25cm and does 0.26x so at best the Tammy would do ~0.197x at mfd and no doubt much worse at 150mm.
The 35-150 would be a dream lens for me - IF (if!) the optical performance is really good and the bokeh looks smooth. The expression "travel lens" suggests mediocre optical performance (on a similar level to the 28-200),though...
This is standard for varifocal lenses opposed to true parfocal zooms. A varifocal lens can be smaller since it doesn't require the length to allow close focusing at the long end.
Sony cameras can electronically compensate the focus shift of varifocal lenses making them act like a parfocal zoom as long as the focus is in the reduced range of the long end.
QuietOC wrote: Pixel Perfect wroteWhy the move to having mfd at shortest FL? If it could do even 0.25x at 150mm that would be much nicer than even 0.4x at 35mm IMO. Given it can only focus to 33cm at 35mm I'm guessing this is a lower magnification lens. Sony 35 GM focuses at 25cm and does 0.26x so at best the Tammy would do ~0.197x at mfd and no doubt much worse at 150mm.This is standard for varifocal lenses opposed to true parfocal zooms. A varifocal lens can be smaller since it doesn't require the length to allow close focusing at the long end.
Thanks. I like how my 70-200 f/2.8 and 100-400 for example have same mfd at all FL. For close up work I much prefer a longer FL, 100mm+.
28-75 G2
You can download a7r4+28-75 G2 sample JPG files from above link.
it looks sharper than original 28-75
Compared to original 28-75, Size and weight is about same(10 gram lighter though).
They are gonna release some more information at 02/Sep and mid/Sep
f1atlux wrote: 28-75 G2
The comparison images they posted between the G1 and G2 is odd. They highlight the G2's improvement in the horizon at the edges, but the close-up rocks and grass show the opposite where the G1 is better. It looks to me that the plane of focus is different between these two shots. Perhaps these lenses have differing field curvature--G2 flat or curving away while G1 is curving inward.
In any case, the center mountain shows that the G2 has slightly better microcontrast.
Not really familiar with the Tamron lens line up but wouldn't the III designation on most of their lenses indicate that it's the 3rd iteration of that lens? If so, is the G2 the 4th? This sounds like a line up I'd like to become familiar with.
No the III means it's specifically designed for mirrorless. Di I was originally for lenses first designed specifically for digital capture. Di II were those specifically designed for APS-C digital capture.
One more quickie. Does that mean the III lenses are NOT compatible with APS-C cameras? That's another thing that I don't really understand as there's no mirror mechanism to slam into the lens and also the flange distance is the same. At least I think it is.?
With Sony and Nikon, there's no physical differences with the mount dimensions or clearances between aps-c and ff lenses or bodies. So the mirror-less aps-c lenses can be used on full frame and vice versa. The aps-c lens does trigger the crop mode and that can be over-ridden if desired, with the limited image circle perhaps still having some uses on the ff bodies. This is different from Canon where on dslrs, there was interference with the aps-c lens and ff body mirrors so the mounts were made to preclude using the aps-c lenses on the ff bodies. I don't know what they've done for mirror-less when it coms to mount/lens compatibility..
Craig Gillette wrote: BennyR wroteOne more quickie. Does that mean the III lenses are NOT compatible with APS-C cameras? That's another thing that I don't really understand as there's no mirror mechanism to slam into the lens and also the flange distance is the same. At least I think it is.?With Sony and Nikon, there's no physical differences with the mount dimensions or clearances between aps-c and ff lenses or bodies. So the mirror-less aps-c lenses can be used on full frame and vice versa. The aps-c lens does trigger the crop mode and that can be over-ridden if desired, with the limited image circle perhaps still having some uses on the ff bodies. This is different from Canon where on dslrs, there was interference with the aps-c lens and ff body mirrors so the mounts were made to preclude using the aps-c lenses on the ff bodies. I don't know what they've done for mirror-less when it coms to mount/lens compatibility.....Show more →
Canon has got one mirrorless full frame mount EF-R and one mirrorless APS-C mount EF-M, which are mutually incompatible.
Has anybody seen any information on the physical specs of the 35-150? Very curious to know things like filter size, length and diameter, and weight. How will it compare to the 70-180 physically? And of course someday it will be nice to know something of its optical performance, but that will have to wait until there are actual lenses being made.
