Archive 2021 · In the Camellias
DanielScott
p.1 #1 · In the Camellias
From an experimental shoot I did with a friend in April. I wanted to try the brenizer method with a long lens. I like the final outcome, but to be honest in the end I have come to the conclusion that I could have gotten the same image with one frame if I used a 50mm instead of multiple frames with a 100mm lens. Oh well, live and learn right? Soon I want to try this same method with my 50mm f/1.4 lens to see what I might be able to make with it, but for now I'm happy with this.
Shot using an original Canon 5D with a Canon 100mm f/2.8 macro USM lens attached. Lit using all natural light.
May 27, 2021 at 12:09 AM
IainD
p.1 #2 · In the Camellias
Whatever technique you used, it worked. Nicely done.
Iain
May 27, 2021 at 02:40 AM
DanielScott
p.1 #3 · In the Camellias
Iain
Thank you so much Lain.
May 29, 2021 at 01:29 PM
friscoron
p.1 #4 · In the Camellias
The shots I've seen using the Brenizer Method are much wider environmental shots. I don't think it's a fair comparison when you do this with a tighter headshot. I can't even imagine you used that many images to create this image. They often use 50 plus images for these.
Also, it's really about creating shallow depth of field surrounding the subject much like you see in film when shot at f/1.4 or whatever. It's usually not done with a subject like this and a background so close to the subject.
May 29, 2021 at 09:09 PM
John Power
p.1 #5 · In the Camellias
I thought you had to have an R5 to take a shot like that.....
Jun 06, 2021 at 07:49 PM
selfnoise
p.1 #6 · In the Camellias
Cool shot. It has a very 'magazine cover' feel to it.
Jun 06, 2021 at 08:03 PM
DanielScott
p.1 #7 · In the Camellias
I understand the technique behind brenizer and knew that what I was doing doesn't completely match the most commonly used application of it, but as I said I wanted to experiment with it and see what I might be able to make by applying the idea to a close-in portrait.
Edited on Jun 12, 2021 at 04:14 AM · View previous versions
Jun 11, 2021 at 05:27 PM
DanielScott
p.1 #8 · In the Camellias
I'm not sure what you are talking about.
Jun 11, 2021 at 05:30 PM
DanielScott
p.1 #9 · In the Camellias
Thank you very much!
John Power
p.1 #10 · In the Camellias
You used an old camera to a take a great photo....
Jun 12, 2021 at 05:52 AM
