I'm struggling with my processing workflow since moving to the XT-3. I had been using Adobe Bridge (as my DAM), Lightroom, and Photoshop (when needed). When I bought the XT-3 earlier this year, I understood that CaptureOne was handling the X-Trans Sensor Images better. I started using Capture One and trying to compare with Lightroom. It seemed I was getting some odd artifacts with LR. Months later, I just have not found a good workflow with Capture One. I like browsing folders and images with Bridge but I don't think there is any similar option with Capture One. I also don't have great workflow sorted out with CaptureOne so it is a constant learning process. So, question for Fuji users:
1) Has Lightroom and Photoshop resolved issues with processing X-Trans images? Is Capture One still the better option?
2) Any option like Bridge that integrates with Capture One well?
3) If Capture One is the preferred solution, can anyone point me to some good videos on building my workflow? I like the look and feel of Capture One so would love to work it out if I can. I just don't have a good setup.
The issue with with artifacts in XTrans files in LR is due to XTrans files taking sharpening differently in LR, you want push Amount rather than Detail if I remember correctly. Check if you were pushing Details and if you were that's it dial it down and use Amount for sharpening.
Maybe someone has better more recent info on this here.
I no longer have any concerns about how Lightroom handles X-Trans III files. Back in version 6 I used Iridient X-Transformer to process the RAF and then import. Now I don't bother.
I've also compared Capture One 12 (admittedly a bit older now), Lightroom (current) and IXT. I thought Lightroom did the best job. However, other people clearly like Capture One. Honestly, if you like the look and feel of Capture One, use it. Both C1 and LR are pretty amazing.
I tried c1, did not like it from workflow and user interface perspective. It is a great software but not for me. Moved back to the adobre raw concerter (photoshop) knowing about “worms” issue and yes - seeing it on the 200% zoom.
Then, I had a chance to print a huge print from such a file, processed in adobe and it was fantastic. I do not worry about processing anymore
You can use C1 as a browser by using a "dummy" or "empty" session. So called because this approach doesn't import anything into C1.
Create a new session called anything you like e.g "C1_browser" and save it wherever makes sense.
Now, instead of importing files into the session, go to the library tab and scroll down until you get to the view of the system folders. Navigate to where your images are stored, which you can now browse and edit from inside C1.
C1 works at the folder level, so when you click on an image, C1 opens all the photographs in the folder and builds previews for all of them. But you can start working on the image you clicked on immediately. The next time you open any image from that folder it should open immediately as the previews will already be built.
The previews and edits are stored in sub-folder inside the same folder you opened raw from, called "Capture One", rather than in a single database like Bridge does. In C1 you can choose to save any exports, e.g edited tiffs "with image" so they are saved beside the original raw.
Many people use this approach with C1 as it lets you use C1 as a browser, while also setting up things like favourites, etc. It also allows you to drag raws from other programs e.g. I drag thumbnails from Photo Mechanic into C1 for editing.
It's a little clunky, but equally, it also works well. But you do need to understand how sessions work, and to get your head round what C1 can do.
rbf_ wrote:
The issue with with artifacts in XTrans files in LR is due to XTrans files taking sharpening differently in LR, you want push Details rather than Amount if I remember correctly. Check if you were pushing Amount and if you were that's it dial it down and use details for sharpening.
You have that backwards. Raising the Details fader too high can create the weirdness that you want to avoid, especially if the image is a bit noisy.
I use ACR/Photoshop for my workflow. (I occasionally use Lightroom, but it is not my primary post-processing tool.) ACR works much the same way as LR when it comes to raw conversion. You even have many of the very same controls. I can't guarantee this since it has been a few years, but a while back I heard directly from someone high enough in the Adobe hierarchy to be able to speak with authority that LR, ACR, and Photoshop share much of the underlying code, so while they present a different interface and workflow, they tend to do the same things, in the same ways, to your files.
All of this is my preface to saying that I've used ACR/Photoshop for my post-processing workflow for Fujifilm files from the get-go. It works really, really well. You have to use some different settings for x-trans files, but you have to customize settings differently for any camera.
If you are used to using a camera with AA filtering you'll perhaps find that your Amount setting is lower than you have used in the past and that your radius may need to be a bit smaller. Basically, you'll sharpen a bit less aggressively than you would with an AA filtering camera.
If you already are used to files from cameras without AA filtering, you are probably close to on the right track by working from familiar settings — just be really careful with the Details fader.
A lot of the hand-wringing about Adobe and x-trans files dates back to the very earliest versions of Adobe programs to work with x-trans. At that time there were a few issues that cropped up even when you did things right. Two, in particular WERE problematic. There WAS an effect that was sometimes called "smearing," where the color of one area could blend over into an adjacent area when there was a very high contrast boundary between the two and when the boundary was far from being a straight line. I never see this any more and have not for years.
The other issue was the infamous "worms" issue. This typically showed up with fine details, most often in the green channel, when the details were semi-random (as opposed to a smooth gradient or a regular pattern) and when the details were close to the one pixel detail level and contrast was low. This is best addressed by lowering the Details setting, or perhaps leaving it at zero.
Another issue, which I feel is related to the "worms" issue, could arise along contrasty edges in high ISO images with noise. Because we typically use a mask to constrain maximum NR to smooth areas and away from edges, more noise can be left along these high contrast boundaries. When you sharpen, you can end up with "weirdness" along those boundaries if you crank Details. So don't. :-)
If you're new to Fuji and have little experience with Adobe products then I would definitely be looking at all the options. If you're familiar with Adobe and have bought into their suite of products then you can get comparable results. Worms are gone unless you go crazy on the details slider. Push details down and amount up and voila...no worms and the details are enhanced.
After trying all the different software and sharpening solutions mentioned, I can give a updated info on this: X-Trans with Adobe software is currently a non-issue using the new "enhance details" feature on either LR or ACR (I say new but it's around for some time now). It's a processing of the RAW files based on machine learning algorithms that works particularly well on X-Trans, renders detail in a "normal" way (no more artifacts) and greatly enhances the color resolution at low ISOs. The only drawback is the time it may take to process the files, depending on how capable is the GPU (it relies heavily on the GPU). I compared all the software and this is simply what gives the best results, even better than the famous previous champion Iridient.
On my work flow I usually make adjustments on the original raw file, then apply the "enhance details" (it creates a new dng file) on images that benefit from it (almost every from ISO 100 to 400 or 800, at higher ISOs I don't find it necessary since it's also where the supposed X-Trans advantage shines).
I have tried both LR and C1. I didn't really care for the C1 user interface. I was really reluctant to go to the subscription model of Lightroom but ultimately I have been pretty happy with it. As far as image quality, I have not seen any noticeable artifacts in my images. I guess if I started seeing more of that, I might start questioning if this is the right platform for me.
Using C1 since this lockdown (almost coming to be a yr) and I like it. I use sessions system and things run smoothly. I do my editing with files on my external USB3 dual drive setup. My computer is almost 5 yrs old. LR will just choke but C1 has no issues. Cameras A7rIV and GFX50s.
I was all-in on C1 when I was still working primarily on the desktop. I've largely moved away from it for the simple reason that a mixed iPad Pro + Desktop workflow is possible with LR+PS and not with C1 because they do not have a mobile app.
My general workflow is built around my iPad Pro on the move and desktop at home and leveraging LR+CC sync to handle all the data.
I still think C1 is a better RAW converter and a better overall editor than LR alone, but it really forces you into a laptop/desktop workflow and to put it bluntly, I can't get a laptop as powerful as my iPad Pro 2020 for anywhere near the same weight budget.
Relatively high amount and a small (fraction of 1) radius with little or not push of the details slider is a good approach. Problems ensure if you make the radius too large (I never go as large as 1.0) or crank up "details."
Also, a multi-step sharpening workflow can be good. Not sure how easy this is in Lightroom since my workflow is ACR plus Photoshop. I do basic input sharpening in ACR, then important the converted images to Photoshop as smart layers. (This allows a lossless return to ACR to touch things up later.)
I do a separate sharpening operation (also a smart filter) in Photoshop to tune things up. (I also do yet another sharpening process on files after I downsize to print them.)
Adobe handles Fujifilm x-trans files just fine these days.
bobby350z wrote:
Aren't ipad screens tiny? Unless one is shooting pro events what's the rush to develop so fast in the field and post.
12.9" and very high quality screen, superior to most laptop screens.
And I tend to have a lot of downtime when in the field, I'll be out for 15-20 hours, but a lot of that is just waiting for the light. I select and do basic edits, as well as Instagram uploads while in the field.
Plus with the Pencil 2, I do a lot of my editing on the couch with the iPad Pro rather than at my desk. LR CC syncs edits between the two platforms.
I use Faststone Image Viewer (Free) and I set "Edit in external program" to Affinity Photo ($25 on sale) so it's now a library for Affinity Photo.
For raw processing I use Fuji's Raw Converter (Silkypix, free) and it does a great job.
Not only is my total cost for all this $25 USD, (one time license, not subscription) but it's the best and preferred workflow for my needs.
I have LR and Capture One for Fuji (paid for, not express) and I prefer the free options with Affinity regardless of the price. Faststone is one of the easiest programs I've used, Affinity is like Photoshop, if you know Photoshop, you know Affinity, and Fuji Raw Converter is Silkypix, not easy, but not too hard to learn.
myotis wrote: Tim Carpenter wroteI like browsing folders and images with Bridge but I don't think there is any similar option with Capture One.You can use C1 as a browser by using a "dummy" or "empty" session. So called because this approach doesn't import anything into C1.
This is how I use C1 having dumped the bugfilled Cataloging process.
One caveat to this method. Every time you browse to a folder and select a file, C1 logs that into your "empty" session. If you do a lot of that, you will notice C1 getting very lethargic as the session database is not real happy with more than a couple of hundred logged images.
So, when I create a new empty session, I make a zip file of the sessiondb file. When I notice the rot setting in, I simply restore the zipped empty session over the active one.
The good part about working this way, is all your work gets saved as text files in the folders created, and these can be backed up for safe keeping.
I prefer the results I get for my Fuji files from C1.
For Canon I use LR.
I think that there are things that LR does better (brushing, cloning, DAM), and PS is even better than LR. LR can be clunky at times for me while cloning/healing.
