fredmiranda.com Login
Trade safely
This topic is in the 2021 archive. You can read it and like its posts here. It is read only.
Archive 2021SoldLensbaby Burnside 35 and Twist 60, Nikon mount
Jack Flesher
p.1 #1SoldLensbaby Burnside 35 and Twist 60, Nikon mount
   Nikon 50mm f1.2 Ai lens
Price$350.00
PayPal
Shipping instructions
Includes USPS Priority shipping to the lower 48
I am selling off all of my manual focus lenses. I love all of these for their unique look rendering, but the reality is at my age I tend to grab my AF lenses and leave these sitting in the camera cabinet. I probably have not used any of them more than twice in the past 6 months.
This lens is in exc condition all around, with super clean glass. Focus is smooth, but does feel a little dry, could use a professional lube. Purportedly this was the sharpest "normal" lens manual focus lens Nikon ever sold in the 50 to 55 focal range, sharper than the legendary 50/1.4 and 1.8 at every comparable aperture. (The original 58mm Noct was better, but it was considered a specialty lens and focal.) Anyway, by todays today's standards it isn't in the same league IMHO until you stop it down to f2.8 or more. But it does render a gorgeous, smooth and creamy legacy look wide open up through f4, and is excellent for couples portraiture. Includes lens and both front and rear caps.
ITEM2
   Lensbaby Burnside 35mm f2.8 lens, Nikon F mount
Withdrawn
Price$350.00
PayPal
This lens is in virtually new condition. It is also a very solid all-metal build, with smooth focus and aperture rings. It renders very sharp central 2/3rds of the image, with delicious falloff and bokeh, including near perfect bokeh balls. It also focuses to 6 inches(!) It is superb for food photography among others. Depending on aperture and subject to background distance, the bokeh can be adjusted from creamy to swirly. Further, there is a vignette lever that allows you to dial in from 0 to about 2 stops of corner vignette. The depth of the vignette is affected by aperture. By f8 this lens is basically as sharp as any modern lens corner to corner. In fact it is so sharp centrally, I frequently used a soft-diffusion 1 filter with it to tone down its sharpness. Note that it takes a little experimentation time with chimping to understand how all of the above adjustment factors inter-relate to achieve your desired effect, but the resultant images are worth it. Includes lens and both front and rear caps. You can find full details including sample images here at the Lensbaby site -- video is worth watching too as it explains most all the adjustments and features: https://lensbaby.com/collections/collection/products/burnside-35.
ITEM3
   Lensbaby Twist 60mm f2.5 lens, Nikon F mount
Withdrawn
Price$190.00
PayPal
This lens is in essentially new condition. It is well suited to portraiture when you are on location with busy backgrounds. The central 2/3rds is very sharp, and then the outer 1/3rd of the background rapidly swirls creating a unique effect. The sharp central area varies with aperture, and by f8 it's virtually gone except for the extreme outer edges. I found this lens sharper centrally than the Nikon 58/1.4 G lens from f2.8 on, and of course the background swirly blur added more separation. It's also tiny and light (and cheap) by comparison, and thus easy to have in the bag for when you want the effect. Includes lens, both front and caps and box. Full details and example images here on the Lensbaby site: https://lensbaby.com/collections/collection/products/twist-60.
ITEM4
   Dumb adapter, Nikon F mount lens to Z mount body
Withdrawn
Price$15.00
PayPal
Note: this is only offered FS if purchased with any lens above. It's not worth the shipping cost to sell it separately so please don't ask
A dumb adapter to use any of the above lenses on a Z body. Lens mounts are smooth and tight, a very good value adapter. No caps, just the adapter.
Burnside 35 side
Burnside 35 front
Burnside 35 mount
Twist 60 Side
Twist 60 side
Twist 60 mount
Nikon F/FE to Z manual adapter
Edited on Jan 09, 2021 at 06:53 PM · View previous versions
Jan 01, 2021 at 03:58 PM
1joel1
p.1 #2SoldLensbaby Burnside 35 and Twist 60, Nikon mount
Hi,
Are you certain that the Nikon 50mm 1.2 lens is AI-s? Might just be AI. I can't see the entire bottom of the lens so am not certain, but my guess is that it might just be an AI lens. On most cameras, that isn't an issue, on all digital cameras, it isn't an issue at all.
Joel
Jan 05, 2021 at 09:49 AM
Jack Flesher
p.1 #3SoldLensbaby Burnside 35 and Twist 60, Nikon mount
Good catch Joel -- and my bad. There is no "S" divot on the rear mount. Apologies, I just "assumed" it was there. Now corrected...
Jan 05, 2021 at 10:45 AM
bellyface
p.1 #4SoldLensbaby Burnside 35 and Twist 60, Nikon mount
feedback tag
Apr 13, 2021 at 02:15 PM
