fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020Photoshop CC stopped working . Windows 8.1
echelonphoto
p.1 #1Photoshop CC stopped working . Windows 8.1
OK...this is devastating. Have been running photoshop cc for four years under the photographers subscription plan. Today it fail to open, wont run. I called Adobe and they tell my PS wont run with windows 8.1, but yet it runs with windows 7 and 10. Now I have to do a windows upgrade. Could not tell me why it is not compatible any more. I am really pissed. At least a two day delay in getting this up and running and serving my customers.! How can a large company like this screw with its subsribers?
Dec 16, 2020 at 03:47 PM
rattlebonez
Details
p.1 #2Photoshop CC stopped working . Windows 8.1
personally I would gladly upgrade to Windows 10 to get Photoshop cc working if it was me
I never liked the Windows 8 interface & OS. A failure on the UI for sure.
A very good photo editor alternative: https://affinity.serif.com/en-us/photo/
Another option is ON1 Photo Raw 2021 - I don't even need Photoshop or Affinity with that. I can process the RAW file and even make local adjustments.
Dec 16, 2020 at 04:37 PM
Ho1972
Details
p.1 #3Photoshop CC stopped working . Windows 8.1
I assume you're tried the compatibility options for the Photoshop.exe file?
Or can you roll PS back to a previous version? If all this fails, you may be able to do an in-place upgrade which keeps your apps and settings intact. So you're just looking at a couple of hours instead of a couple of days to migrate to Windows 10. If you want, you can do a clean install later when time is not a factor.
Pro tip: Do a full system backup (e.g. Macrium) before you do anything other than the compatibility settings.
Dec 16, 2020 at 06:47 PM
John Wheeler
Details
p.1 #4Photoshop CC stopped working . Windows 8.1
Hi echeonphoto
What version of Photoshop CC are you running.
The last supported version of PS that supported Windows 8.1 was PS 2018 (version 19).
They never supported Win 8.1 after that. That usually means use at your own risk as they are not testing or qualifying Win 8.1 initially or for any "dot" version that come out. Running Win 8.1 on anything ater SP 2018 was skating on thin ice.
If you are using PS 2018 then the complaint would be quite valid.
The subscription plan does not force one to move to a newer version of PS yet the subscription plan and new versions of PS are only supported on a relatively small number of OS versions going back and yes that is a pain yet is a business decision as each supported OS requires a set of company resources to support and most companies put an upper limit of how far back they go to support old OSes. Win8 was poorly received by companies and individuals and the customer base is relatively small. Similar to older OSes.
Adobe is not the only company that does this. Most software companies have similar limits. I had to upgrade my Mac OS a couple days ago because the Turbotax 2020 was not supported on High Sierra (which with Big Sur coming out would have made me 4 versions old. It was a pain yet I knew it would eventually happen.
I feel your pain yet you may have had expectations for which Adobe was clear about not supporting?
Dec 16, 2020 at 08:59 PM
echelonphoto
Details
p.1 #5Photoshop CC stopped working . Windows 8.1
I was running cc 2015.5
Dec 17, 2020 at 11:32 AM
echelonphoto
Details
p.1 #6Photoshop CC stopped working . Windows 8.1
So....I went ahead and installed Windows 10 and had no hitches per se...all my programs are intact and I now have a new version of CC running. However...there is a problem with calibration. I will start a new thread on that.
Dec 17, 2020 at 01:10 PM
