victis06 wrote:
What was the equipment used to capture these? The landscape is incredibly unique.
I’m heavily invested in flying. I treat Aerial photography much the same as ground photography. I research, and scout virtually all of my work. So I’ve got two drones. I use the Mavic Air 2 for all of my scouting and video. I use the Mavic Pro 2 for all of my still photography. Both drones compliment one another very well for the end result, a good photo.
To run both drones with each using 6 batteries, I’ve got 3 solar panels, two 100 watt, one 60 watt. Three charging stations. A 500 watt, a 240 watt and a 169 watt. My 60 watt panel attaches to my roof top allowing me to charge my stations while driving. I’m constantly charging batteries while out in the field.
Air 2. The good
It’s flys forever far and away. The same transmission as the Mavic 2 Pro.
Half the price of the Mavic 2 Pro
35% smaller than the Mavic 2Pro
Longer battery flight time (about 5minutes)
Batteries are cheap, and charge faster and require less wattage to charge.
Has 4K 60fps, MP2 has 30fps
The bad
Camera sensor is small in size 2/3 of inch and 12pm and struggles in low light. Don’t believe the 48 mp hype, it’s awful in low light.
Fixed 2.8 aperture
Native 3:4 aspect ratio with stills. However video is 2:3.
Mavic 2Pro the good
Has a fantastic 1inch 20mp Hasselblad sensor that surprisingly does very well in low light.
Has a working aperture. F2.8-f11
The big difference between the two is the camera sensor. The files that come from the MP2 are noticeably more advanced and they allow for advanced post processing. The Dynamic Range is light years better than the files from the Air 2. I will say this in defense of the Air 2 files, I’ve gotten more than a few “keepers” from that drone.
