Archive 2020 · R6 Randomly activated shutter while off
Jman13
p.1 #1 · R6 Randomly activated shutter while off
So, I often leave my camera on my desk while at work...I just like having it there. Anyway, a few times now, my R6 will just randomly power on by itself, open the shutter and then close the shutter. It's not recording the exposure, but you can hear the shutter activate. This is after sitting off for a fair bit of time (hour+).
I'm assuming this is normal, but I am wondering if everyone else has noticed this. Does it just randomly take black frames for pixel mapping here every so often?
Edited on Nov 20, 2020 at 07:27 PM · View previous versions
Nov 20, 2020 at 12:59 PM
windsun33
p.1 #2 · R6 Randomly activated shutter while off
Several years ago I had that happen occasionally, then it went away. Never figured out why, but one theory was that it was getting random triggers from WiFi - maybe try putting it in airplane mode?
Nov 20, 2020 at 01:05 PM
AmbientMike
[X]
p.1 #3 · R6 Randomly activated shutter while off
Maybe you should call a pastor or something? maybe this is a spying feature?
I mean I kinda doubt it but I leave WiFi off anyway. Is the lens cap on just in case? Maybe a more likely reason, if I do a sensor cleaning in menus on my camera it fires the shutter 2x. But idk kinda weird, it'd bother me
Nov 20, 2020 at 01:06 PM
highdesertmesa
p.1 #4 · R6 Randomly activated shutter while off
This would freak me out so badly. I'm going to be keeping a closer eye on my R5
Nov 20, 2020 at 01:47 PM
p.1 #5 · R6 Randomly activated shutter while off
Big Brother.
Nov 20, 2020 at 01:54 PM
Jman13
p.1 #6 · R6 Randomly activated shutter while off
After looking in a little deeper - I do think it's related to the bluetooth connectivity. If I open the app and connect directly, it opens the shutter on power up, and closes it when I disconnect and quit the app. I imagine what's happening is the wireless app is touching base with the camera and then disconnecting. Sounds exactly the same as what I've experienced.
Nov 20, 2020 at 02:02 PM
grog13
p.1 #7 · R6 Randomly activated shutter while off
You're saying it powers on when the switch is off? Or when it's just asleep? The shutter on Canon mirrorless models is closed when powered off, correct? I wonder if it's possible your shutter is sticking open when you turn it off, then it closes on its own later, and that's what you're hearing?
Nov 20, 2020 at 02:04 PM
grog13
p.1 #8 · R6 Randomly activated shutter while off
Yes, this makes more sense than what I just suggested
Nov 20, 2020 at 02:07 PM
EB-1
p.1 #9 · R6 Randomly activated shutter while off
It's probably being hacked. Maybe you can store the camera in a Faraday bag when not in use and remove the battery pack just to be sure.
Nov 20, 2020 at 02:15 PM
jedibrain
p.1 #10 · R6 Randomly activated shutter while off
A pastor can be a great spiritual leader, but you need a priest to perform the holy rituals associated with exorcism.
-Brian
Nov 20, 2020 at 02:16 PM
amacal1
p.1 #11 · R6 Randomly activated shutter while off
Normal? I hope not.
Nov 20, 2020 at 03:15 PM
Nelu
p.1 #12 · R6 Randomly activated shutter while off
My R5 shoots unlimited 8K videos without over-heating, while turned off
Nov 20, 2020 at 03:37 PM
Daniel Smith
p.1 #13 · R6 Randomly activated shutter while off
Artificial intelligence trying to learn something new?
Mirrorless can't see when it is off.
Your DSLR doesn't do this because it can still see through the lens when the power is off.
Nov 20, 2020 at 05:35 PM
Photonadave
p.1 #14 · R6 Randomly activated shutter while off
Your camera is watching you and making plans . . . & before you are .
Nov 20, 2020 at 06:20 PM
AmbientMike
[X]
p.1 #15 · R6 Randomly activated shutter while off
I'd probably turn off WiFi first for one thing it's really easy. I'd be concerned if it worked, though
It really sounds like an intervalometer, though, so I'd look at the built in intervalometer.
Nov 20, 2020 at 06:35 PM
Mike_5D
p.1 #16 · R6 Randomly activated shutter while off
The thread came up in a search when my R6 suddenly started doing the same thing.
I switch the camera off and the shutter closes. Then some time later, I'll hear shutter sounds. I was finally able to reach the camera quickly enough and see that the shutter was open. Then a few seconds later it closed again.
I used to keep my camera in airplane mode but recently started using the GPS via phone and have been leaving the Bluetooth and Wifi enabled. I think that's when it started randomly cycling the shutter. My phone is also nearby but I don't have the Canon app up when this happens.
Jun 30, 2022 at 01:35 PM
Smokin14
p.1 #17 · R6 Randomly activated shutter while off
My R6 started doing this today, out of the blue. I haven't even used it in a couple of weeks. What the OP didn't mention was whether or not the screen was coming on as well. Mine does. Flickers on & off. I've never used the app, so don't have that on my phone. Wifi is off. Camera seems to operate fine in the ON position, I wonder if I should just remove the batteries when not in use? I really don't want to have to be out a shipping & repair expense.
The camera is insured though.
Jun 20, 2023 at 07:34 AM
Jman13
p.1 #18 · R6 Randomly activated shutter while off
That sounds different from what I experienced.
Jun 20, 2023 at 08:12 AM
bogeypro
p.1 #19 · R6 Randomly activated shutter while off
Is your R6 nicknamed "Chucky" or is it connected to "SkyNet" (Terminator)?
Jun 21, 2023 at 08:03 PM
Ferrophot
p.1 #20 · R6 Randomly activated shutter while off
I have had mine start up and take a burst of shots. Only happened once in the 2 years I have had it. It has frozen twice but reset all ok after taking the battery out. It has been fine after I set it to airplane mode.
Jun 22, 2023 at 12:52 AM
