Seems the crown is no longer working with the latest CC Photoshop update (2021) from Adobe. I used to be able to use the crown to change the size or hardness of brushes. Now the crown isn’t working at all in Photoshop. It is working in LR. It’s also working in my Microsoft Office apps.
Seems to new PS update killed integration with the Logitech craft keyboard. Anyone else with the Craft have this issue?
Thanks for confirming. Currently scouring the net to see if I can find out what's going on. As I said, no issues in Lightroom, it's just Photoshop that's not working
Open Logitech Options, and click your keyboard.
Click "All applications"
Scroll down to "Add application" and click it. It will open another window for more apps.
Scroll down to "Other..." and click it. If not there, go to "Program Files" and look for the "Adobe" folder.
Open the Adobe folder and click "Adobe Photoshop 2021". That will take you to the root folder housing the Photoshop 2021 files.
Click on "Photoshop.exe" and the windows will close and take you back to Logitech Options where you should see "Adobe Photoshop.
Note: Photoshop will be listed in under applications (it was for me) even though the crown isn't working. Just ignore it and follow the procedures above. What you are doing is basically adding/re-adding the Photoshop app to the software. Once the procedures above are done the crown should now work (does for me).
p.1 #5Photoshop 2021 and Logitech's Craft keyboard
Edit - it seems I spoke too soon. It seems the fix only works as long as Photoshop is not closed. Once you close and open Photoshop again the issue returns
p.1 #7Photoshop 2021 and Logitech's Craft keyboard
Laurent-b wrote:
Hi Andrew,
sorry, I forgot to activate notifications,
thanks for the link to logitech support forum,
I'll follow updates there.
By the way : just received this morning, an answer from logitech support...
....asking for a screenshot...
Thanks. That's where I've been posting and looking for a solution. As to Logitech wanting an image. Not sure how that helps them. It's not like the image is going to tell them what the issue is. Anyway I posted a few images of the software there, so...
p.1 #8Photoshop 2021 and Logitech's Craft keyboard
Hi everyone. Have any of you used Photoshop in a mobile app? It seems to me that the phone will not process the photo professionally, as in professional photoshop on a PC. Maybe I'm old-fashioned, and I should give it a try. My colleagues advise me to conduct an experiment and edit a couple of pictures in PicsArt https://www.apkdojo.com/picsart. They say that it is much more convenient and the photos are no less atmospheric. Before I try it out, I'd like to know if any of you have used it? Is photo processing on the phone inferior to professional processing on a PC? Maybe it is better to combine these two treatments?
