fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020Should I cut a carbon fiber lens hood?
Susurrus
p.1 #1Should I cut a carbon fiber lens hood?
Hello. This is my first new post, and I've searched the forum for this but couldn't find anything. Please let me know if this should be posted someplace else.
I recently found a 2006 model Nikkor 500mm f4 AF (non VR) in the photography closet in our department. The lens is no longer used since the outreach folks use a 600mm with VR now, so I was given the lens to use for work (as a biologist).
However, the hood is an HK-24, which measures 9.75" long. Whereas, on both the newer Nikkor 500mm f4 and on the Canon 500mm f4 the hood is only 7" long. This hood makes the lens/camera combo (without the 1.4x TC) 27" long.
I'd like to cut the hood down using a high speed rotary saw designed to cut carbon fiber (actually designed to cut carbon fiber arrows for archery). I feel confident that I can cut it cleanly and re-use the rubber lip from the front edge, but my question is how short I can go.
For protecting the lens, I'm not going to cut it to less than 6" long, but I'm curious if anyone has used aftermarket hoods and can comment on noticeable differences between cutting it to 7" vs. 6". It may seem unnecessary, but I shoot primarily incidental photo/video from a vehicle, and spinning that beast in the cab of a pickup is tricky. Also, many backpacks for that lens are around 25-26", and I'd like to store it in a case with hood and TC mounted, ready to shoot. (E.g. vertexphotos seat pack).
If anyone has used aftermarket products or cut down a lens hood, please let me know if you've experienced a hood that was too short.
Thanks!
Jesse
Aug 15, 2020 at 10:01 AM
Blakehfreeman
Details
p.1 #2Should I cut a carbon fiber lens hood?
If you’re using someone else’s equipment I’d pick up an aftermarket. My memory is a bit fuzzy but I thought some of the shorter tele hoods can be fitted to your lens (400mm/500mm) but it’s been 8 years since I’ve shot with any of that glass!
Two last points.... I don’t think carbon fiber would take nicely to being cut/if you DO go down this path preclear it with whoever lent you the lens (your firm/govt etc).
Good luck! 😬
Aug 15, 2020 at 10:33 AM
tntcorp
Details
p.1 #3Should I cut a carbon fiber lens hood?
jesse, i'm not aware of any aftermarket hoods that are shorter than the oem hood. the aquatech hood is the same length
perhaps in specific situations you may observe a loss in contrast, but i believed that would be rare. other than a loss in resell value, i would say cut away.
but if it was me, i would custom make one from pvc tubing and not alter the oem hood.
Aug 15, 2020 at 10:43 AM
Susurrus
Details
p.1 #4Should I cut a carbon fiber lens hood?
Thanks. This lens is old enough that the oem hood is hard to find, so that's a good point. However, it's also old enough, and without VR, that I don't think cutting the hood will sacrifice much for resale.
I have never used an aquatech hood, but I often stand my lens on the hood in the car seat, and those don't look like they'd support the weight of the camera like the carbon fiber hoods. The Lenscoat hood for a new 500 f4 would be a good solution otherwise, since that one is shorter.
Aug 15, 2020 at 10:50 AM
JBPhotog
Details
p.1 #5Should I cut a carbon fiber lens hood?
FWIW, the lens hood that came with the lens is designed for that lenses specific characteristics. Shortening the hood will only degrade the optical quality with flare, lower contrast etc. Is two and three quarter inches seriously affecting your handling of the lens, certainly the weight of the hood can’t be a factor?
You may want to bear in mind that a replacement OEM hood for that lens may be impossible to attain should you need to restore the package to its original spec and you are reducing its resale value should the owner want to sell it at some point.
Aug 15, 2020 at 10:53 AM
Susurrus
Details
p.1 #6Should I cut a carbon fiber lens hood?
Thanks, great points, but yes 2-3" is significant. Weight is negligible, but if it were cut, I could fit it in the same pack with a TC attached--I can't do that now. Also, when trying to get the lens from the passenger seat to the driver's window in a hurry, I think every inch could help.
Since it's owned by the state, and is an out-dated lens, it will eventually (if ever) go to a surplus auction, and resale is not a concern.
Degraded optical quality is my main concern, so I'm curious if anyone has experience with that. The new 500mm f4 has a shorter hood, so I'm presuming 7" is still enough to reduce flare and maintain contrast. On a Canon forum, one user has cut his hoods in half, and claims that there is no noticeable difference up to 45 degrees toward the sun, after that you get flare.
Good points though. I'm definitely cautious about choosing to do this, hence wanting more input.
Aug 15, 2020 at 11:02 AM
NickHoffman
Details
p.1 #7Should I cut a carbon fiber lens hood?
Basically you are creating shade on the lens element with the hood, so I would suspect you would just be limiting your angle of attack into the sun or light source by shortening the hood. Test with a cardboard moc-up at that length
Aug 15, 2020 at 11:17 AM
Thang
Details
p.1 #8Should I cut a carbon fiber lens hood?
I would not cut the oem hood if you plan to sell the lens later. A local photog is making them from 3D printer. He is selling them to us here in SoCal. I have been using one for 800mm fl lens without any noticeable loss in contrast and or IQ. The hood is about three inches short and works great. 99% of the time I shoot with the sun on my back.
Aug 15, 2020 at 11:29 AM
Susurrus
Details
p.1 #9Should I cut a carbon fiber lens hood?
Nick--great idea to use a cardboard test! I'll give that a try first.
As I said above, resale isn't a concern. If it were my lens, I'd buy a 3D printed one, but since work wont reimburse me, and this lens is going to sit on the shelf until it's worthless, my only concern with cutting the OEM hood is for loss in quality, not for resale.
Thanks all for the input!
Aug 15, 2020 at 12:08 PM
Norm Shapiro
Details
p.1 #10Should I cut a carbon fiber lens hood?
Just leave it as it is. It was designed that way so just leave it alone.
Susurrus
Details
p.1 #11Should I cut a carbon fiber lens hood?
Innovative concept! Hahaha
Aug 15, 2020 at 12:14 PM
sjms
Details
p.1 #12Should I cut a carbon fiber lens hood?
the right answer
Aug 15, 2020 at 12:20 PM
EB-1
Details
p.1 #13Should I cut a carbon fiber lens hood?
A shorter hood will give a bit less light protection, but is far better than no hood.
I say go for it!
Aug 15, 2020 at 12:21 PM
AcuteShadows
Details
p.1 #14Should I cut a carbon fiber lens hood?
Hoods for zoom lenses are not optimal for all focus lengths either. So shortening the hood just means finding a different balance between optical performance and handling.
As for the carbon fibres, pay close attention to the direction (or multiple directions) of the fibres. Because the properties of the material very much depend on the layout of the fibres, as well as the matrix material, tools that work for carbon fibre arrows may not work well with other carbon fibre items.
Aug 15, 2020 at 12:23 PM
sjms
Details
p.1 #15Should I cut a carbon fiber lens hood?
if you ruin it its nearly impossible to find. if you get this it can take a beating and if you do its price is ugly.
https://www.bhphotovideo.com/c/product/618407-REG/Aqua_Tech_1381_SoftHood_Collapsing_Hood_for.html
Aug 15, 2020 at 12:33 PM
Susurrus
Details
p.1 #16Should I cut a carbon fiber lens hood?
Thanks. I have looked at those, but have heard mixed reviews as far as how well a camera/lens will stand on one of those. Some people say they are firm, others say they wouldn't stand a lens on one. I travel with my camera upright, strapped to the passenger seat so it only needs to rotate 90 degrees to be pointed out the window. I'm not sure the Aquatech would support that.
I do understand that if I ruin it it's impossible to find, but on the other hand, it's impossible to find a shorter hood, so if I make it better...
Also, if I ruin it, I can always buy an aquatech! hahaha
Aug 15, 2020 at 12:56 PM
sjms
Details
p.1 #17Should I cut a carbon fiber lens hood?
or you could buy the aquatech and not ruin it to begin with. i used the aquatech for a few years while shooting certain sports. no i wouldnt stand a lens on one either. but then i rarely needed too.
Aug 15, 2020 at 01:02 PM
Susurrus
Details
p.1 #18Should I cut a carbon fiber lens hood?
FYI, Aquatech's hood is 7.7" long, and 1" is behind the rib at the end of the lens. The HK-24 is 9.75" long and only has 0.25" behind the rib, so the OEM extends ~2.75" beyond the Aquatech.
Does anyone experience notable loss in IQ or Contrast with Aquatech if their OEM hood was longer?
If not, I'm leaning toward the gamble to chop the OEM off.
Aug 15, 2020 at 01:27 PM
Susurrus
Details
p.1 #19Should I cut a carbon fiber lens hood?
Also, if anyone wants to trade an Aquatech for an OEM HK-24, I have one I'd trade!
Aug 15, 2020 at 01:29 PM
sjms
Details
p.1 #20Should I cut a carbon fiber lens hood?
the HK-24 is a $400+ item. that's why when i used my 300/2.8VR i used the Aquatech. then i went over to the Sigma 120-300/2.8 who's hood was Alloy and took more than a few direct hits from frisbees during ultimate events and i didn't bat an eye. hurt my nose once or twice though.
why would empty air cause either or? a hood is an addition for shade i have shot many times w/o one. it is not an optical component.
Aug 15, 2020 at 03:20 PM
FM ForumsNikon ForumJoin Upload & Sell
