here is the video I shoot with EOS R5, no log used, straight out of camera,
IMHO, color is great, IBIS is killer, High ISO no problem at all.
As a most still photo person, this easy to use 4k120fps is pretty amazing.
only "downside" i found is time limit of 4k120 is 30 mins and camera itself will overheat in 40mins in my testing, not a big issue at all for me though.
here is link for video.
Lens used to shoot video :
EF 200mm f/1.8 handheld
EF 135mm f/2 handheld & on tripod
I shot my footage in clog and edited in final cut on a 2017 imac 21 inch (quad core w 32gb ram). I did have to use proxies. Note the camera makes a 30 fps clip of 120 fps footage. My output is 24 fps
Oh my goodness I don't know what I found most fascinating about the video. The fact you handheld the camera vs your son(?) examining his soothers. So awesome. Takes me back. . nicely done for a primarily stills photographer.
I worry though if the camera overheats with video and then you want to use it for stills, you have to wait. I've got an R6 on preorder (coming over from Nikon) so I'm excited and nervous all at the same time.
i use no log profile, just color profile - portrait. when it imported to fcpx, i choose 24fps .
davidttus wrote: evertdoorn wroteI shot my footage in clog and edited in final cut on a 2017 imac 21 inch (quad core w 32gb ram). I did have to use proxies. Note the camera makes a 30 fps clip of 120 fps footage. My output is 24 fpsi use no log profile, just color profile - portrait. when it imported to fcpx, i choose 24fps .
Atlasman2 wrote: davidttus wroteevertdoorn wroteI shot my footage in clog and edited in final cut on a 2017 imac 21 inch (quad core w 32gb ram). I did have to use proxies. Note the camera makes a 30 fps clip of 120 fps footage. My output is 24 fpsi use no log profile, just color profile - portrait. when it imported to fcpx, i choose 24fps .Why did you choose 24fps?
davidttus wrote: Atlasman2 wrotedavidttus wroteevertdoorn wroteI shot my footage in clog and edited in final cut on a 2017 imac 21 inch (quad core w 32gb ram). I did have to use proxies. Note the camera makes a 30 fps clip of 120 fps footage. My output is 24 fpsi use no log profile, just color profile - portrait. when it imported to fcpx, i choose 24fps .Why did you choose 24fps?So i can get more "cinematic" look and 5x slo-mo.
I think a higher frame rate might smooth out your pans, but I think you proved what you intended to prove- the IBIS works very well.
freaklikeme wrote: davidttus wroteAtlasman2 wrotedavidttus wroteevertdoorn wroteI shot my footage in clog and edited in final cut on a 2017 imac 21 inch (quad core w 32gb ram). I did have to use proxies. Note the camera makes a 30 fps clip of 120 fps footage. My output is 24 fpsi use no log profile, just color profile - portrait. when it imported to fcpx, i choose 24fps .Why did you choose 24fps?So i can get more "cinematic" look and 5x slo-mo.I think a higher frame rate might smooth out your pans, but I think you proved what you intended to prove- the IBIS works very well.
I agree.
24fps should be reserved for the cinema––not computer screens, tablets and smartphones. There's nothing cinematic about dropped frames––24fps on a 60Hz device. I think the cinematic formula consists more of screen aspect ratio, camera in motion, focus pulls, etc.
