Archive 2020 · How to remove shadows on dslr sony a5100
luizcrf
p.1 #1 · How to remove shadows on dslr sony a5100
Hello everyone!
Two weeks ago I bought a Sony a5100 with 16-50 lenses (Model SELP1650), but when I started filming I noticed shadows around the image.
I researched forums about the problem, and saw that it could be an effect called 'vignette'.
I shoot with the setting 1/80 F5.6 and ISO around 400 to 600 (with 3 lamps of 60w in a room of 3 meters by 3 meters)
and I was recommended to set the camera to 1/60 F11 and a higher ISO (around 2000)
I put this setting, but with the ISO increased, the image is very saturated.
Is there any other solution to remove these shadows?
The camera is very good, and the focus is fast, but this problem with "shadows" (or "vignettes") is putting an end to my filming.
The image below is part of a shot on a white wall
Configurations: 1/80 F5.6 and ISO around 400 to 600 (with 3 60w lamps in a 3 meter by 3 meter room)
https://imgur.com/yRsQuai
May 29, 2020 at 02:28 AM
ftllens
p.1 #2 · How to remove shadows on dslr sony a5100
you could make custom settings in software to cancel it out if studio setting
May 29, 2020 at 02:58 AM
j4nu
p.1 #3 · How to remove shadows on dslr sony a5100
I think with this lens (16-50), your options are to correct in post processing or close down (e.g. to f11 as you suggested).
It's a kinda "pancake" lens so vignetting is an issue...
May 29, 2020 at 03:48 AM
QuietOC
p.1 #4 · How to remove shadows on dslr sony a5100
Sony calls the vignette "shading." Check in the MENU for your "Lens Comp." settings. If "Shading Comp." is set to "Off", setting it to "Auto" should help.
May 29, 2020 at 05:59 AM
luizcrf
p.1 #5 · How to remove shadows on dslr sony a5100
Hello friend, what software do you recommend for this?
Jun 03, 2020 at 11:08 PM
luizcrf
p.1 #6 · How to remove shadows on dslr sony a5100
I saw some reviews on youtube. Some users with the same lens as my camera. None of the footage had a "vignette".
Is it a defect in my lens?
Jun 03, 2020 at 11:09 PM
luizcrf
p.1 #7 · How to remove shadows on dslr sony a5100
Hi, I checked this option, and it is "enabled"
Jun 03, 2020 at 11:11 PM
ftllens
p.1 #8 · How to remove shadows on dslr sony a5100
Hey you could try Capture One for Sony. They have custom profile that can negate vignette for faster workflow
Jun 04, 2020 at 03:21 AM
j4nu
p.1 #9 · How to remove shadows on dslr sony a5100
I don't think it's your lens specifically, although I guess there's a small chance for that too...
Maybe the pictures you saw were already processed to remove vignetting.
Jun 04, 2020 at 05:07 AM
