fredmiranda.com Login
This topic is in the 2020 archive. You can read it and like its posts here. It is read only.
Archive 2020Slightly fuzzy Grackle
Bsmooth
p.1 #1Slightly fuzzy Grackle
Heres an inflight shot of a Grackle. A lot of my shots with the new D500 and 50PF combo seem like this. Almost sharp but not quite. per Morris's advice I'm posting the shot and EXIF info.
http://live.staticflickr.com/65535/49819237328_5da1c98fde_b.jpg
I can copy the EXIF, not sure how to show it though.
• Image Width - 5568
• Image Height - 3712
• Bits Per Sample - 16 16 16
• Compression - Uncompressed
• Photometric Interpretation - RGB
• Make - NIKON CORPORATION
• Orientation - Horizontal (normal)
• Samples Per Pixel - 3
• X-Resolution - 300 dpi
• Y-Resolution - 300 dpi
• Planar Configuration - Chunky
• Software - Adobe Photoshop CS6 (Windows)
• Date and Time (Modified) - 2020:04:25 22:50:22
• YCbCr Positioning - Centered
• ISO Speed - 800
• Sensitivity Type - Recommended Exposure Index
• Exif Version - 0231
• Date and Time (Original) - 2020:04:25 11:27:41
• Date and Time (Digitized) - 2020:04:25 11:27:41
• Components Configuration - Y, Cb, Cr, -
• Exposure Bias - +2/3 EV
• Max Aperture Value - 5.7
• Subject Distance - 23.71 m
• Metering Mode - Multi-segment
• Light Source - Unknown
• Sub Sec Time - 19
• Sub Sec Time Original - 19
• Sub Sec Time Digitized - 19
• Flashpix Version - 0100
• Color Space - sRGB
• Sensing Method - One-chip color area
• File Source - Digital Camera
• Scene Type - Directly photographed
• CFAPattern - [Red,Green][Green,Blue]
• Custom Rendered - Normal
• Exposure Mode - Manual
• White Balance - Auto
• Focal Length (35mm format) - 750 mm
• Scene Capture Type - Standard
• Gain Control - Low gain up
• Contrast - Normal
• Saturation - Normal
• Sharpness - Normal
• Subject Distance Range - Unknown
• Coded Character Set - UTF8
• Envelope Record Version - 4
• Application Record Version - 0
• Date Created - 2020:04:25
• Time Created - 11:27:41-07:00
• Global Angle - 30
• Global Altitude - 30
• IPTCDigest - 6f5cf899f9ff53b0b7ab59e02f2a7eaf
• XMPToolkit - Adobe XMP Core 5.3-c011 66.145661, 2012/02/06-14:56:27
• Format - image/jpeg
• Color Mode - RGB
• ICCProfile Name - sRGB IEC61966-2.1
• Creator Tool - DxO PhotoLab 3.2
• Metadata Date - 2020:04:25 22:50:22-04:00
• Rating - 0
Apr 27, 2020 at 08:26 PM
RustyBug
Details
p.1 #2Slightly fuzzy Grackle
A few things make me go "hmmm" ...
1. Why is there a "hole" in his wing?
2. Planar Configuration - Chunky (what is that )
3. F/5.7 (essentially Wide Open)
4. Sharpness "Normal" (recalling that Phase Fresnel may need more / different)
5. Gain @ Low (vs. none )
6. Adobe & DXO Photo Lab (processing may not be optimized for PF lenses)
Have you tried processing using Nikon's native software (I forget its name)? Cannon's DPP4 has profiling associated with different lenses, not sure if Nikon does that also.
7. 23.7 Meters, you're pushing 80 feet away from a 1 foot subject at roughly 10x. PF, Wide Open & Long Distances each take their toll on things. Combine two and it's worse. Combine all three strikes against you ... and you may just be expecting a lot. Even without PF Optics, 80 feet away begins taking its toll on detail, including atmospheric impact.
Curious to see a test / comparison shot for the same settings on a static bird @ 80 feet.
Also, is this shot with VR on? I'm assuming so. Not sure how much the distance / angular impact might be having on a modest amount of under/over correction (influenced by "Phase" Fresnel ). Does the VR have different modes?
Again, some test shots at 80 Feet (tripod vs. handheld vs. VR On/Off/modes matrix of shots) may give some insight, as well.
Your (posted) grackle is only about 400 px long, out of 5568 px width. This is about 7%-8% of your available frame width. Here again, (if that is accurate info) I think you're asking a lot. You might check in with someone like Geoff (Arbitrage) or Tony (ImageMaster) for their thoughts on things, too.
Here's a link to the 500 PF dedicated thread. Note in the page, the level of detail in the long distance shots vs. the near distance shots. THEN, notice the picture of the eagle from 100 yards (4X farther) of an eagle (X bigger than a grackle) and how much detail it lacks. Then see the same picture of the eagle further down, after Geoff ran it through Topaz and Geoff's "magic sauce" of sharpening (and some image size reduction).
https://www.fredmiranda.com/forum/topic/1549025/167
There are many things that effect the acuteness / sharpness of an image. Distance, lighting, lens, AA filter, aperture, motion, etc. Those are but some of the contributors / detractors from acuteness. Depending on how many (and which ones) are in play, can make the impact on the need for sharpening highly variable. Yet, for some reason, most folks still want to use the same kind of sharpening for ALL their shots. Kinda like putting ketchup on everything from French Fries to Filet Mignon or using pepper as your only seasoning for everything. If you want to really bring the most out of your images, you may need to learn to apply differing types and amounts of sharpening.
Anyway, hope this help. Good luck with your continued effort. Once you get things dialed in, it'll be worth the effort. But, I see some test shots and test sharpening ahead to get a better understanding of what you may need when shooting PF glass over longer distances. When it comes to detail ... proximity is King and lighting contrast is the Queen ... with long reach capability being the Court Jester that will fool you into thinking that you can get great detail easily over long distance. Others make it look easy, but I suspect that their years of experience have them dialed in a bit more than folks starting new.
To that point, again I reference the fact that diffracted optics like Phase Fresnel are not the same thing as "regular" glass ... whether Nikon's PF or Canon's DO. I'ts kinda like looking through one of those plastic magnifiers with the concentric rings vs. a ground magnifying glass. Granted the difference in quality of PF/DO doesn't take as much of a hit anywhere nearly as the plastic magnifier does ... but the illustrative point is that you are dealing with a "stepped" optical refraction, rather than a smooth one. That's not to knock on the PF ... just to realize that there is a difference in the optical projection, thus a difference in sharpening may be warranted, and that difference may be extrapolated / amplified even further with your deep cropping / enlargement factor.
Apr 27, 2020 at 11:14 PM
Bsmooth
Details
p.1 #3Slightly fuzzy Grackle
I noticed the hole too,wasn't sure what happened, maybe the Grackle had a tough winter!
I'm not sure what that Planar Chunky setting is ?
I did try Nikon's software and wasn't impressed with it at all
The DXO Software corrects for each lens, and it makes a huge difference.
I did close down to 6.3 and all the shots were done at that setting, not sure why it isn't reflected in the readings.
VR was at the Sport setting
As far as sharpening in the camera, they were shot RAW, so that all gets done afterwards.
Apr 28, 2020 at 08:05 AM
Steve Spencer
Details
p.1 #4Slightly fuzzy Grackle
...Show more →
What is the shutter speed? I don't see it in what you have copied.
Apr 28, 2020 at 08:28 AM
Bsmooth
Details
p.1 #5Slightly fuzzy Grackle
I kept switching between 1/2000 and 1/2500, so it was either. I also was switching between 800 and 1000 ISO, because of the changeable lighting conditions. BTW I took that info off what I got from Flickr.
Is there a way to automatically transfer that info to your picture here ?
Apr 28, 2020 at 09:56 AM
RustyBug
Details
p.1 #6Slightly fuzzy Grackle
BTW, have you micro adjusted your lens / body combo for the longer distances
Apr 29, 2020 at 03:19 PM
Bsmooth
Details
p.1 #7Slightly fuzzy Grackle
I just did using the Dot Tune method. I had used another method taking 10 shots and it came out to -1. Using Dot Tune it actually came out to a midpoint between + 1 and +2, so I used +2, since I fine tuned it to a little over 40 feet.
I did it twice and it came out very consistent.
May 02, 2020 at 02:28 PM
FM ForumsPhoto CritiqueJoin Upload & Sell
