fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Made a short hood for the 400mm DO II
RobAmy
p.1 #1Made a short hood for the 400mm DO II
I just picked up another 400mm DO II. I love the short hood on my 400mm f2.8 and really liked it on the 600mm. I always thought the size of the hood was huge on the DO, the same hood fits the 200-400mm much better. So I made my own short hood. I cut the OEM hood down and put new rubber edging on it. Granted I was nervous cutting a $500 hood but it came out great. Canon reenforces the edge a bit, obviously I cut that off. Doing so you lose a tiny bit of strength, so I can squeeze it a bit easier than the full hood but not by much. The rubber Canon uses is just double sided tape holding it down. It came off very easy but it is a squeak bigger once I cut the hood, so I could not reuse it. I did find the same size rubber edging on Amazon and it fits great, it just has one seam as it is not a solid piece like Canons. Overall this is so much better now, as a bonus I have a short hood for the 200-400mm now . I had a piece of lens coat laying around from a focus ring cover that I did not use and it fit great.
Here a couple size comparisons with my wife's DO
Nov 08, 2019 at 09:32 AM
drobertfranz
Details
p.1 #2Made a short hood for the 400mm DO II
I've been trying to come up with a way for a short hood on my 400mm DO.. I often shoot without the lens hood altogether, throwback from when I shot sports. Not sure I could do this though... Looks great and will be very functional.
Nov 08, 2019 at 11:14 AM
Zenon Char
Details
p.1 #3Made a short hood for the 400mm DO II
That is a good idea. I hated taking mine off and on so I got a toolbox to transport in the car.
Edited on Aug 15, 2020 at 11:40 AM · View previous versions
Nov 08, 2019 at 05:29 PM
Zenon Char
Details
p.1 #4Made a short hood for the 400mm DO II
I'm going to get me some lenscoat as well.
Nov 08, 2019 at 05:30 PM
lighthound
Details
p.1 #5Made a short hood for the 400mm DO II
What effect does this short hood have on your images Rob? Do you see a slight loss of contrast?
Obviously if shooting toward the sun, I could see a risk of lens flare at larger angles relative to the sun, but have you had any issues like that in actual use?
I'd love to have a short hood for my 500 but I don't have the gonads to chop down the OEM $$$$ hood.
I've seriously thought about 3D printing one but I haven't taken the time to figure out how to make the clamp mechanism. I have a few ideas that might work but I need to look into the details more.
As for the rubber ring. I would think you could have just cut the original with a razor blade and then carefully fit onto the new short hood and then mark it where you would need to trim off the extra and pop it on there. Yes?
Nov 08, 2019 at 07:37 PM
jaredmizanin
Details
p.1 #6Made a short hood for the 400mm DO II
I did this with my 800 hood. Actually, I bought a cheap one off eBay (the 400/2.8 lenses use the same hood). I found one for $90 and modified that. I'm not super skilled with tools so I had my dad do a rough cut with a miter saw and then I used a random orbit sander to get things just right. I would totally do the same with a 400 DO II hood; isn't the small size the main selling point of that lens?? If I was a real handyman I would do a little side business selling modified short hoods for super telephoto lenses. Yours came out awesome!
Nov 08, 2019 at 08:07 PM
RobAmy
Details
p.1 #7Made a short hood for the 400mm DO II
...Show more →
I have not had any issues at all with using the short hood on the 400mm f2.8 at all and also no issues with the 600mm short hood. I only made the short hood today for the DO II so I think it will be just fine but will update with any issues.
I was nervous too about chopping up the hood Once you go the short hood, you will not go back.
You could use the rubber ring from the OEM hood but is really soft when removed, the one I bought had a bit more rigid / strength so I used that one. You could easily cut the original, you would only need to take a very small amount off.
I used this trim and ordered 3ft
https://www.amazon.com/gp/product/B07NDW1BBQ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
I thought about 3d printing too, but really wanted the OEM look. 3d would be much cheaper if you mess up.
Nov 08, 2019 at 11:12 PM
EB-1
Details
p.1 #8Made a short hood for the 400mm DO II
What is the purpose in making the lens hood shorter than normal?
Nov 08, 2019 at 11:30 PM
technic
Details
p.1 #9Made a short hood for the 400mm DO II
...Show more →
It's surprising that there isn't already a Chinese or so side business providing such hoods; should be very cheap to make for anyone with some basic industrial manufacturing equipment (maybe even certain 3D printers), as long as the customer accepts plastic instead of carbonfiber or something similar. Probably most of the owners of these lenses are too wealthy or busy to look for alternatives to the rip-off official hoods ...
Nov 09, 2019 at 03:05 AM
RobAmy
Details
p.1 #10Made a short hood for the 400mm DO II
No reason other to shorten the overall length of the lens. Easier carrying it around, walking thru woods, taking the lens in and out of a car window, etc. Possible smaller bag when in full shooting position. Personal choice. No need to do it at all for performance reasons.
Edited on Nov 09, 2019 at 06:22 AM · View previous versions
Nov 09, 2019 at 03:47 AM
jaredmizanin
Details
p.1 #11Made a short hood for the 400mm DO II
technic wrote:
jaredmizanin wroteI did this with my 800 hood. Actually, I bought a cheap one off eBay (the 400/2.8 lenses use the same hood). I found one for $90 and modified that. I'm not super skilled with tools so I had my dad do a rough cut with a miter saw and then I used a random orbit sander to get things just right. I would totally do the same with a 400 DO II hood; isn't the small size the main selling point of that lens?? If I was a real handyman I would do a little side business selling modified short hoods for super telephoto lenses. Yours came out awesome!
Right? I honestly also hate the thumb screw attachment design. I have had multiple problems in the past with a screw coming loose, pieces falling off, etc. Regardless, there is a door of opportunity there for someone to simply make smaller hoods. Although an OEM hood costs us 500-600 bucks, there is no way it actually costs anywhere near that much to make!
Nov 09, 2019 at 05:09 AM
hbcj
Details
p.1 #12Made a short hood for the 400mm DO II
As I read some posts speaking of the 3D design and printer solution to build custom lens hood I use this solution frequently .
as example hereafter my 600mm_III short lens hood , I designed it with Freecad and a 3D printer .
The advantage you can make a prototype , I made the first one with length 10.2 cm for test .
It fitted perfectly and I used it during 2 weeks but seemed to me was a little short .
I modified slighty the CAD design and built a second one with 2 cm more length and big screws.
I use it for 2 month and don't feel needing any modification.
Gabriel
Nov 09, 2019 at 08:09 AM
ChrisMak
Details
p.1 #13Made a short hood for the 400mm DO II
If only the replacement hood were not so indecently expensive, I would give it a go myself! The hood on the 400DOII should not have to be as long as it is.
Nov 09, 2019 at 08:15 AM
cpe1991
Details
p.1 #14Made a short hood for the 400mm DO II
More likely is that you get one with the lens, it's close to unbreakable and so big it's difficult to lose so no-one needs to buy a replacement unless they want to saw it in half. Canon, accordingly, hardly sells any and needs to cover its costs of storing large items that rarely ever sell.
Nov 09, 2019 at 01:59 PM
technic
Details
p.1 #15Made a short hood for the 400mm DO II
That's a factor for sure but still, it seems the Canon hood is far from ideal and given the price of this stuff it is sad that you have to put up with it.
Which reminds me that I should look for an alternative hood for my 100L macro with a better fit, that doesn't rattle when I walk around or even slightly move the camera. Like most Canon hoods the original is a compromised design that - while way cheaper than a 400 DO hood - isn't worth what they are asking for it.
Nov 10, 2019 at 03:59 AM
technic
Details
p.1 #16Made a short hood for the 400mm DO II
I use it
...Show more →
great! I would love to experiment with replacement hoods, e.g. ones that have a rectangular mask to improve flare/contrast performance for macro lenses that are often sensitive to backlighting. Also many designs can be improved for easier or more compact storage in reverse position. You can piece something together from plastic parts but it usually isn't exact and durable enough for real use ...
Nov 10, 2019 at 04:19 AM
cpe1991
Details
p.1 #17Made a short hood for the 400mm DO II
I have no problem with the hood. It's normally reversed for packing for travel and so the lens + full-length hood is no longer than the lens + sawn-off one, and I don't find it gets in the way for normal use.
Nov 10, 2019 at 06:10 AM
KINGOFKNGS
Details
p.1 #18Made a short hood for the 400mm DO II
Rob,
Any reasons why you picked up another 400 DO II? Just wondering after you got rid of it after getting the 400 2.8 IS III.
Ryan
Nov 10, 2019 at 06:23 AM
RobAmy
Details
p.1 #19Made a short hood for the 400mm DO II
KINGOFKNGS wrote:
Rob,
Ryan
Ryan I picked up another DO because I enjoyed the lens a lot. Seeing the crazy used prices, I decided to get another one. I always liked having a 2 lens setup, usually one for flight or closer shots and one for distant 800mm. So the DO works great for flight in the 400mm/560mm range and the 400mm f2.8 works awesome at any range up to 800mm. I do not always have time to change extenders, so a 2 lens system works for me.
I have the 200-400mm so I thought that would be fine as a second lens and the DO would not see much use and sold it. I found the 200-400mm was a bit heavy for that, so I decided to go the DO II route again. I did regret selling it. I always loved the size of the DO lens. Also a big decision was using my wife's DO with the EOS R, works very well and it is a super light weight setup.
I feel with this combo it is the lightest travel combo I have ever had. The DO will not see more use than the 400mm f2.8 (BTW is the best lens I have ever had) but will be a great back up, thus the reason for the smaller hood.
As far as the 200-400mm, like that lens better for larger mammals vs birds as a second lens.
Rob
Nov 10, 2019 at 06:50 AM
arbitrage
Details
p.1 #20Made a short hood for the 400mm DO II
Nice work Rob!!
What did you use to cut the hood?
Nov 10, 2019 at 08:48 AM
