fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Monopod Gimbal Head
animalsbybarry
p.1 #1Monopod Gimbal Head
I have been using modified gimbals and long lenses on monopods for a very long time.
I have also been using them with waist pouches/holsters and shoulder supported flag carriers
The support and flexibility for fast moving subjects is unbelievable.
Now Wimberly has designed the ultimate Monopod Gimbal Head MH-100 and it will be available this month for $179 and can be pre-ordered from the Wimberly website.
This is the best Monopod Gimbal ever made, and will revolutionize how people use their long lenses.
Update the name of the product now appears to have been changed to MonoGimbal Head.
https://tripodhead.com/products/monopodhead-main.cfm
Edited on Sep 16, 2019 at 07:20 AM · View previous versions
Sep 05, 2019 at 08:30 PM
Chris Court
Details
p.1 #2Monopod Gimbal Head
Thanks for the ad.
C
Sep 05, 2019 at 11:43 PM
Roland W
Details
p.1 #3Monopod Gimbal Head
I will stay with the very functional Really Right Stuff MH-01 monopod head, which I have used for years. A bit more money, but I can outfit it with a lever release clamp, which I find very useful for a monopod head. The Wimberley head requires side loading your lens using a screw clamp, and there is no way I would want to do that with a big lens. Top loading is best for both true gimbal heads and for monopod heads.
Sep 06, 2019 at 12:58 AM
Roland W
Details
p.1 #4Monopod Gimbal Head
And by the way, being it is your first post, and you just recently became a member of this board, that is kind of a dead giveaway that you are just here to post a promotion of a new product. You would get more respect if you just said what relationship if any you have to Wimberley. And it might have been nice to hear why you and/or Wimberley think the new product is better, because I fail to see any benefits. If by chance you have actually used the product or a prototype of it, it would be nice to hear real experiences, and comparisons to other monopod heads.
Sep 06, 2019 at 01:08 AM
animalsbybarry
Details
p.1 #5Monopod Gimbal Head
I do not work for Wimberley
Edited on Sep 16, 2019 at 07:23 AM · View previous versions
Sep 06, 2019 at 04:26 AM
Dragonfire
Details
p.1 #6Monopod Gimbal Head
Chris Court wrote:
Thanks for the ad.
C
I'm certain the parts are created in China, just like the Movo GH700 is identical in every way to the WH200.
You have pushed my to do a head-to-head comparison with your ad.
Stay tuned.
Edited on Apr 21, 2020 at 06:54 AM · View previous versions
Sep 06, 2019 at 04:43 AM
Thern
Details
p.1 #7Monopod Gimbal Head
Sorry to say but I dislike this MH-100 concept.
Apart from the fact I don't like the idea of side (un) loading the rig the weight of the complete rig is offset of the center and thus the base of the monopod, causing instability.
Sep 06, 2019 at 05:00 AM
animalsbybarry
Details
p.1 #8Monopod Gimbal Head
Wimberly is located I Virginia, and every product is 100% US made.
If you want to test the product I suggest using a double web flag carrier ( such as Annin 660018 or Supply Room F-C306 (Olive Drab)) and a sturdy Monopod.
I am curios what you will compare it too? Because as far as I know there is currently nothing like it available?
This Gimbal is precision machined from a solid aluminum billet
Edited on Sep 09, 2019 at 02:02 AM · View previous versions
Sep 06, 2019 at 05:13 AM
animalsbybarry
Details
p.1 #9Monopod Gimbal Head
Thern
I understand your concern about the side mount / offset nature of this Gimbal being unstable as it is not centered above the Monopod.
Most people will think that because everyone is used to using a Tripod, and for a Tripod that would be true.
But for a Monopod Gimbal the assumption is wrong.
This product is ONLY intended for use on a Monopod and ONLY only intended for use on long lenses with rotating rings.
There is absolutely no reason or advantage for the camera to be located above the Monopod (even though common logic would lead people to believe otherwise) and in fact you will have 360 degree rotation.
Unlike a tripod there is absolutely no reason the Monopod needs to be held vertically, you will naturally and automatically (without even thinking about it) hold the Monopod at the angle that balances the rig, and the rotating lens ring (which is left loose) rotated to the angle that keeps the camera level.
Everything can effortlessly be done single handed...... this is the easiest way ever to track fast moving subject like birds in flight.
Because you do not need to hold the weight of the rig it is always instantly ready at eye level (this is faster that handheld because you do not need to raise the camera) and of course you can keep the camera on target as long as you want because you do not need to put it down
Again I highly recommend using a waist level support like a double web flag carrier to make the system the most functional.
Note: any kind of belt pouch will work fine, but for extended use I highly recommend a double shoulder or harness support (such as a flag carrier) to better distribute the weight, and more importantly to keep the weight off your hips.
Edited on Sep 16, 2019 at 07:27 AM · View previous versions
Sep 06, 2019 at 05:40 AM
animalsbybarry
Details
p.1 #10Monopod Gimbal Head
Wimberly MonoGimbol, it is totally new and original built in the USA
Edited on Sep 15, 2019 at 06:34 PM · View previous versions
Sep 06, 2019 at 06:38 AM
Dragonfire
Details
p.1 #11Monopod Gimbal Head
American companies have been manufacturing jewelry, clothing and shoes in China since the mid 1980s and the American tooling industry began manufacturing in the mid 1990s after cad/cam was able to be ported to Windows NT and iges truly became universal. I ran 5 seats of SDRC in my jewelry design salon.
They save the money on the labor and sell as if Made in the USA.
I closed my employers jewelry company for defrauding my clients in 1985 and he was force to pay treble damages to my retail jewelry store customers.
I just purchased a WH200 and will do a head to head, dimension to dimension, weight to weight and tension to tension comparison.
Your sleazy AD precipitated my response.
Sep 06, 2019 at 07:15 AM
animalsbybarry
Details
p.1 #12Monopod Gimbal Head
First of all I disagree about my comment being a AD
I receive nothing from the sale of these products but I am very excited this product.
P.S.
The discussion about the regular Wimberly head is not actually relevant to me , because I am only interested/excited about the MH-100 Monopod Gimbal.
I use a Monopod Gimbal for over 90% of my photography. I saw a previous discussion here about putting a Gimbal on a Monopod and wanted to share this with people I knew were interested in the subject. The forum would not (as a first time poster) allow me to join an existing discussion. That is the reason I began a new discussion. It is not my intention to offend anyone, and if something I said or my excessive enthusiasm offends you I apologize for that.
Edited on Sep 16, 2019 at 07:32 AM · View previous versions
Sep 06, 2019 at 07:29 AM
Dragonfire
Details
p.1 #13Monopod Gimbal Head
animalsbybarry wrote:
I use a Monopod Gimbal for over 90% of my photography.a previous discussion here about putting a Gimbal on a Monopod and wanted to share this with people I knew were interested in the subject. The forum would not (as a first time poster) allow me to join an existing discussion. That is the reason I began a new discussion. It is not my intention to offend anyone, and if something I said or my excessive enthusiasm offends you I apologize for that.
Had you opened with that statement ...
Sep 06, 2019 at 11:25 AM
EB-1
Details
p.1 #14Monopod Gimbal Head
I have also been them with waist pouches/holsters and shoulder supported flag carriers
That looks like a really nice head, and it is different from most others in being able to balance on the main axis. I have the RRS MH-01 and it is not well balanced like that. The user is relying on some friction (hard to control precisely) or usually fully tightening it at a particular angle. Of course the side mount of the Wimberley could be a problem and I don't like side mounts in general on the really heavy lenses.
In any event, it is nice to see new support products that offer better options for some users.
Sep 06, 2019 at 05:45 PM
animalsbybarry
Details
p.1 #15Monopod Gimbal Head
Side mounts seem sturdy to me
Edited on Sep 15, 2019 at 06:25 PM · View previous versions
Sep 06, 2019 at 06:21 PM
dclark
Details
p.1 #16Monopod Gimbal Head
Gimbal head on a monopod is not a new concept. I have used the Pro-Media Tomahawk for years. It is a bit bigger and more expensive than this Wimberley.
I like the Tomahawk gimbal. I do not like the monopod heads that have the lens mounted on top and dependent on friction to keep it steady. The side offset of the gimbal makes no difference to me in terms of the stability and handling. Some side offset makes it easier to aim up and down without hitting the monopod. Also if the lens can be aimed straight down and then locked it can be easier to carry. That does not work for large telephotos with hoods.
I may take a look at the Wimberley once it is available. It may be enough lighter to make it worth a switch.
Dave
Sep 06, 2019 at 10:23 PM
EB-1
Details
p.1 #17Monopod Gimbal Head
A few people here have expressed some concern that this is a side mount Gimbal.
I fail to see the issue.
I'm confident that it will be plenty strong enough for the load.
I use the Sidekick fairly often and the problem is that many of us are not young and strong. It's a hassle to attach and remove a big tele on a sideways gimbal mount many times each day and there is a risk of the camera/lens crashing to the ground. I mostly use the Sidekick and a 100-400 for landscapes and use a small gimbal with the larger lenses for wildlife.
Sep 06, 2019 at 11:20 PM
animalsbybarry
Details
p.1 #18Monopod Gimbal Head
I once bought a Tomahawk.
It was far too large and heavy, so l sent it back
Edited on Sep 16, 2019 at 07:34 AM · View previous versions
Sep 07, 2019 at 05:05 AM
animalsbybarry
Details
p.1 #19Monopod Gimbal Head
EB-1
There is a simple method to attach your big lens.
Attach the head to your folded Monopod.
Set your lens and camera down anywhere.
Attach and secure your Gimbal and folded Monopod
Extend the Monopod to approximately the length you want (or a little longer than you want)
Last, lift it up into final position (put the base of the Monopod in the pouch if you are using one) and adjust the length to the exact length you want.
This method is very easy, attaching a lens in position is more difficult.
P.S. I always recommend a lens strap for safety. If you are not able to put the lens strap on your body at least wrap it around your wrist. A camera strap can also be used for added security, but lens straps are the best safety device.
In over 50 years I have never damaged a camera because I alway use safety straps.
Edited on Sep 07, 2019 at 09:29 AM · View previous versions
Sep 07, 2019 at 05:33 AM
dclark
Details
p.1 #20Monopod Gimbal Head
As I have explained yes there have been some other gimbals that can be used on monopods but they are all crap.
This is designed from the ground up to be the ideal Monopod Gimbal and is unlike anything out there.
You mention carrying your big lens.... that is what this is designed to do.
You CAN rotate your lens to the vertical position and lock it in for carrying, it is specifically designed to allow that. ICarry options were specifically considered in the design of the Wimberly Monopod Gimbal
I have been using and modifying Monopod gimbals for 90% of my photography
...Show more →
EB-1
There is a simple method to attach your big lens, but it will only work with the Wimberly MH-100
...Show more →
Your comments are way over the top!
"they are all crap. " Your comment is absurd. There are a number of good products available. As I stated in my comment the ProMedia Tomahawk is a good product. It is a long way from being crap.
"but it will only work with the Wimberly MH-100". Attaching the camera/lens before deploying the monopod works with any product. It's silliness to claim that can only work with a Wimberley.
I think you are doing your buddies at Wimberley more harm than good with your intemperate comments. Sign off before you do them more damage.
BTW, your're spelling Wimberley wrong.
Dave
Sep 07, 2019 at 08:14 AM
FM ForumsPhotography Gear & AccessoriesJoin Upload & Sell
