fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
naturephoto1
p.1 #1Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Think Tank Photo recently recently introduced the new Mind Shift Gear Backlight Elite 45L and the Mindshift Gear Stash Master 13L.
https://www.thinktankphoto.com/collections/backlight-series/products/backlight-elite-45l-backpack
The Backlight Elite 45L is the largest in the Mindshift Backlight series and takes carrying a large amount of camera gear to a new level. It includes a removable padded Camera compartment and waist belt.
https://static.bhphoto.com/images/images750x750/1555386352000_1469082.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Removable-Insert-Front-Open-172.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Gear-Sony-Double-088_989aa54a-fe17-418e-a53d-bf64e5b7247e.jpg
The new Mind Shift Stash Master 13L padded camera case:
https://cdn.shopify.com/s/files/1/0532/0233/products/Stash-Master-13L_0005_Stash_Master_13L-Hero-Left-009.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Stash-Master-13L_0005_Background.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Stash_Master_13L-Gear-Sony-061.jpg
can be used to replace the removable camera compartment of the the Backlight Elite 45L allowing the photographer to carry additional personal gear including clothing and backpacking equipment. This square case is relatively deep with an outside dimension of 7.5" (19mm) and has a removable front foam padding (as when used with the Backlight Elite 45L), 3 handles and 2 loops for a strap (not included).
The Stash Master 13L is intended as a padded camera case that can be inserted into regular rollers, backpacks, and camera bags.
I am debating about purchasing the Stash Master 13L to possibly use it with my custom made McHale panel loading backpack. But, I am not sure at this point in my life how much backpacking that I might do carrying photo grear.
Rich
May 19, 2019 at 06:07 AM
naturephoto1
Details
p.1 #2Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
I just place an order for the Mind Shift Stash Master 13L for usage with my custom McHale panel loading backpack, other bags/backpacks, and for usage alone.
I will update the thread once I am in receipt of the bag, how I can configure it, my thoughts, and probably some photos. It should ship from Think Tank in California later today.
Rich
May 22, 2019 at 07:01 AM
JohnC
Details
p.1 #3Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
This is a great idea. I have been using the Mindshift Ultralight 36L as my airline carryon. The removable insert (2 bodies, 3 lenses) can be taken out and carried separately with a shoulder strap or for turning a lightweight daypack into a padded camera bag.
May 22, 2019 at 08:44 AM
naturephoto1
Details
p.1 #4Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
My new Mindshift Gear STASH MASTER™ 13L was delivered within about the last hour and I have started playing with it. The padded insert appears to be as well padded as my Mindshift Gear Backlight 26L. I have been able to get an impressive amount of equipment into such as small pack (External dimensions: 2.2” W x 12.2” H x 7.5” D and Interior dimensions: 11.8” W x 11.8” H x 7.1” D). The case has allowed me to pack the following due to the depth of the case: 3 Sony FF bodies with lenses attached; Leica R 100mm f2.8 Apo-Macro-Elmarit; 2 stacked Leica R lenses using Leica R lens coupler; Sony 1.4X and 2X TCs stacked with lens coupler; 2 Novoflex Leica R to NEX adapters (one in box) the other with the Novoflex ASTAT rotating collar: Sony wired release; and lens blower.
These are the actual pieces loaded into the case:
1 A7rIII in vertical orientation with Sunway Photo L Bracket with Sony 100-400 GM with Kirk replacement foot
1 A7r with Kolari V3 thin sensor modded camera with RRS L Bracket in vertical orientation with Leica M WATE with Leica Filter Adapter and 60mm cap
1 A7r with RRS L Bracket in vertical orientation with Minolta CLE MC 40mm M-Rokkor lens
1 Leica R 100mm f2.8 Apo-Macro-Elmarit
1 Leica R 28mm f2.8 Elmarit V2 stacked with Leica R lens coupler and 1 Leica R 50mm f2 Summicron V2
1 Novoflex Leica R to NEX adapter in box with 1 Leica R to NEX adapter with Novoflex ASTAT rotating collar (foam placed between adapters)
1 Sony 1.4X TC stacked with 1 Sony 2X TC using Op Tech Sony double rear cap in Op Tech wrap
1 Sony Wired release along side stacked TCs
1 lens blower along side stacked TCs
More impressons and quite possibly photos to come.
Rich
May 29, 2019 at 11:45 AM
shac
Details
p.1 #5Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Rich - Thanks for this. It would be great if you could show the Backlight 26L with the Stash Master inserted. Gives an idea of any extra space for other "stuff" e.g. clothing etc.
TIA
David
May 29, 2019 at 06:10 PM
naturephoto1
Details
p.1 #6Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
TIA
David
Hi David,
Unfortunately, the Stash Master 13L does not fit the Backlight 26L. I just mentioned the amount of padding comparing both items as a reference. The Stash Master 13L at this point only fits the new Backlight Elite 45L. But, below are some photos of the Backlight Elite 46L with the original removable insert and with the Stash Master 13L from both the Think Tank/Mind Shift website and from Dan Carr's review and website.
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Empty-079.jpg?
https://cdn.shopify.com/s/files/1/0532/0233/products/Stash-Master-13L_0003_Stash_Master_13L-Open-Empty-013.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Stashmaster-Compatible-Gear-295.jpg?
https://shuttermuse.com/wp-content/uploads/2019/04/mindshift-stash-master-backlight-elite.jpg
https://shuttermuse.com/wp-content/uploads/2019/04/mindshift-stash-master-13l-comparison-800x1070.jpg
https://shuttermuse.com/wp-content/uploads/2019/04/stash-master-backlight-800x1200.jpg
https://shuttermuse.com/wp-content/uploads/2019/04/mindshift-stash-master-13l-comparison2-800x533.jpg
The design of the Elite 45L has packing space above the standard insert (so there would be even more with the Stash Master 13L.
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Top-Access-301.jpg
https://cdn.shopify.com/s/files/1/0532/0233/products/Backlight-Elite-45L-Internal-Aluminum-Frame-278.jpg
This is the link to Dan's review of the Stash Master 13L:
https://shuttermuse.com/mindshift-stash-master-13l-review/
and Dan's review of the Elite 45L:
https://shuttermuse.com/mindshift-backlight-elite-45l-backpack-review/
Rich
May 29, 2019 at 06:50 PM
swldstn
Details
p.1 #7Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
I've already ask Mindshift/Think Tank to make a Stash Master 11L for the Backlight 36L
May 29, 2019 at 08:12 PM
gtvone
Details
p.1 #8Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
An 11, interesting!
Also, semi-interestingly, with a little edge-squish, the 45L main insert fits the Advantage Plus Roller (I was experimenting, it just happened)
May 30, 2019 at 02:50 AM
naturephoto1
Details
p.1 #9Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
gtvone wrote:
An 11, interesting!
I have the Advantage Plus Roller but at this point, I do not have the Elite 45L. Looking at the dimensions of the interior of the roller and the dimensions of the camera insert for the Elite Plus there is a major depth problem due to the handle in the center of the upper half of the roller. The depth of the roller around the handle is only 4.9" and the depth of the camera insert is supposed to be 6.8". The depth of the roller not over the handle (sides) and lower portion of the roller is 6.4".
Rich
May 30, 2019 at 06:26 AM
uscmatt99
Details
p.1 #10Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Rich this is an interesting product! I do have a question regarding the Stashmaster in case you know the answer. Could one stack two of the 13L Stashmasters on top of each other and fit them into the 45L pack, in lieu of the included larger insert? I didn't see that in the review.
Currently I use my F-Stop bag in such a way, with a larger ICU for the camera(s) and lenses. I keep other items such as filters, clamps, etc in a smaller bag on top of the ICU that I can access from the top of the bag if needed, but that I'm less likely to need access to in the course of shooting and just switching lenses.
May 30, 2019 at 08:27 AM
shac
Details
p.1 #11Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
naturephoto1 wrote:
shac wroteRich - Thanks for this. It would be great if you could show the Backlight 26L with the Stash Master inserted. Gives an idea of any extra space for other "stuff" e.g. clothing etc.
TIA
David
Hi David,
Rich
Many thanks for the reply Rich - fortunately I don't need as much capacity as the 45L for photographic equipment. I was more interested in making space for non-photo gear.
Cheers
David
Edited on May 30, 2019 at 08:58 AM · View previous versions
May 30, 2019 at 08:57 AM
naturephoto1
Details
p.1 #12Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
...Show more →
Unfortunately I do not have the Elite 45L to check this. But, looking at the specs, each Stash Master 13L outer dimensions is 12.2" in length and width. The standard insert is supposed to be 19.3" high. So 2 Stash Master 13L should be 24.4" which would be 5.1" longer than the standard insert. Providing there is sufficient room above (5.1" and there is sufficient depth to the Elite 45) it may well. But, in order to do this to access the second Stashmaster completely, you would need to slide it out of the top of the pack itself.
That is an interesting question and would be worth contacting Think Tank/Mind Shift later today after they open an 8:30 AM PST in California. They may not even know and may need to check for you since it has probably never even been considered since both items are so new. Think Tank's phone # is 1-866-558-4465 Extension 1.
If 2 Stash Master 13L would not fit the pack, I also have an older one of these from Kinesis Gear which I have had for some time and is smaller than the Stash Master, and I believe it should fit:
https://kgear.eogear.com/collections/kinesis/products/kinesis-v092-medium-front-opening-module
https://cdn.shopify.com/s/files/1/1658/4705/products/V092Big_2048x2048.jpg
Rich
uscmatt99
Details
p.1 #13Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Thanks for the reply Rich. As it seems designed to be a snug fit, it may be a challenge to remove a second 13L Stashmaster from the top for access. My local camera shop stocks Mindshift products, maybe they have one I can check out in person. There are features of the 45L pack that are superior to my F-Stop Loka, namely the tripod carry options and the belt and back panel design, as well as the removable top pocket.
May 30, 2019 at 09:11 AM
gtvone
Details
p.1 #14Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
naturephoto1 wrote:
gtvone wroteAn 11, interesting!
Rich
I'd have posted the video if I could (not a seller), the edges squish a bit, fits. It was full of my Sony gear (no grips) I've uploaded the video to my flickr. https://www.flickr.com/photos/gtvone/47971583078/ (Sidenote, I work for both companies, so if you have any q's feel free to yell out)
May 31, 2019 at 05:11 AM
naturephoto1
Details
p.1 #15Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Rich
Thank you for the information and the video. This is quite helpful. I could then use the photo insert from the Elite 45L and roll my gear onto the plane and travel with the gear this way in my Advantage Plus Roller. I could then pack the Elite 45L Pack itself and possibly the Stash Master 13L in my hard sided 27" checked bag along with my old Think Tank Bazooka holding either my RRS tripod or one of my smaller Gitzo CF tripods without the heads in the same hard sided piece of luggage.
Rich
May 31, 2019 at 10:48 AM
gtvone
Details
p.1 #16Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
Rich
Rich
You're welcome, hope whatever you choose works out well!
Jun 01, 2019 at 05:04 AM
naturephoto1
Details
p.1 #17Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
It looks like the new Stash Master 13L must be selling fairly well since Think Tank now has the insert listed as out of stock.
Rich
Jun 06, 2019 at 01:58 PM
chambeshi
Details
p.1 #18Think Tank Mind Shift Backlight Elite 45L and Stash Master 13L
posted updated version of this in General Gear Forum - https://www.fredmiranda.com/forum/topic/1609380/0?year=current#lastmessage
Based on initial reviews only, I took the plunge and bought this Elite 45L last week. So far I'm impressed. It meets my needs above and beyond the B'packs I have tried out. No perfect Backpack yet exists, especially to balance a handy Daypack capable of packing a fair pile of camera gear (eg Vanguard Sky 51D) vs Airline-Friendly (eg PD Travel B'pack) vs Outdoor Hiking (eg f-Stop Sukha)
Summary of Comparisons with respect to seeking to dovetail the optimal solution that combines flights + fieldwork, and also wildlife photography in a vehicle using a generous inventory of Nikon gear.
My experience travelling over past few years with at least 10kg of cabin luggage (usually more) is that choice of airline is the biggest factor that controls if one succeeds in reaching the final destination without surrendering valuable gear into the hold (or worse). I've also sought out a solution suitable for hiking, where I have found a waistcoat and/or hipbelt backs up the backpack; ideal for peripherals. All backpacks have failed on at least 1 criterion, and in a key feature.
Wherever possible I fly British Airways, because the maximum cabin limit is usually 2 bags of 23kg each. Hence... the logical choice for wildlife photography trips with heavy Nikon gear! After trying several backpacks over the past 3 decades, I recently settled on the new Mindshift Elite 45L toward the optimum solution for carry on and hiking with 20+kg of gear. Previous to this, among the myriad of choices the more prominent models I have tried :
- Mindshift Backlight 26L: too little volume for big telephoto(s) but these do well for lighter kit (landscape) and day hikes etc. Decent weatherproofing against rain or dust;
- Vanguard Sky Alta 53: excellent for heavy gear loads +tripod (or drone) + big laptop but design team lost the plot on the bag's outside. There is no room for peripherals... weird design failure, which condemns this bag in the field and especially flying; where you want to pack in more than lots of photogear. However it does work well for daytrips with photogear only, although many users may prefer the 51D or 45D versions. So I have kept a 45D for local shooting with a telephoto and 2 bodies, and this pack is ideal for trip to shoot a landscape. The latter models have their main interior divided by a 2-tiered divider (optional) which is useful to organize and access items; access is via Top-Lid, Rear Panel and by Caesarian section, with a zip that halves the main bag into Top and Bottom sections. The Top Lid on all these Sky Alta bags - the biggest 53 especially - is a notable plus to access a big rigged telephoto. Really robust construction. More than Decent weatherproofing against rain or dust. But I finally sold on the 53, as it's not feasible to try and modify to take external pouches;
- Peak Design Travel Backpack: Internal design works well, as does the rear and side panel access. No top access is a -ve; as you cannot access a medium to large lens rigged on a camera. Modular design is a big +ve. But the harness is a joke...even on a moderately loaded pack, given it is rated to take up to 45litres. Camera cube options are limited to smaller photogear mainly (fits a 400 f2.8 Nikkor). Exterior Side pouches prove too tight in practice. In practice these are useless (trying to quickly stash a sealed sandwich at a train-station kiosk crushed them flat!). Poor design at such high price applies especially to what PD has passed off as the "Hip-Belt". This is more a joke, as it is in fact a rip off. So this bag is limited to short trips and airport carry on. It fails as a travel backpack, primarily because the designers failed to upgrade the harness to handle carrying a decent load for longer than 1 hour at best. NOT for a half let alone full day's peregrination, whether urban or outdoors. OTH the packing cubes should fit most packs of similar size. [the Origami style pads/dividers are very useful in this respect, transplanted to another pack :-)] Means to attach tripod is poor for this PD pack; it's really bad actually for a decent sized Sirui or Gitzo; especially when I compare fittings on the bigger Vanguards and Mindshift Backlights. Even though the pack is really well built with strong zips, it is not worth the high price, especially as PD charge extra for the raincoat;
- Mindshift Elite 45L: experience so far as this was recently released: The modular ICU can be vital if you run into strictures of cabin weight / space on a flight (ie regional flights, especially light planes and or draconian regulations). Plus the detachable Top-Lid + hipbelt metamorphoses on separate assembly into a hipbelt of copious volume. The top lid is a big plus to access to a big rigged telephoto. The only -ve is lack of side panel zip access into interior (as in PD Travel B'pack) but I can live without these. The Exterior Side pouches work in practice; so does the exterior strapping system for a tripod. I can pack water or food either side in these panels plus big tripod strapped outer centre.
And it goes without saying any backpack for wildlife must have rear panel access; in this case the padded Hipbelt of the Elite works well to access the bag off the ground (swung off one's shoulders). Another +ve is the Peakdesign camera cubes fit this pack almost perfectly (although the largest cube is shorter than the native camera cube supplied by Mindshift). Excellent weatherproofing against rain or dust with exterior spec fabrics and robust zips., plus included raincover. IMHO this bag is worth the relatively high price. The videos etc don't show in detail that there are a choice of 3 lids to the bag's top: inner camera-module (3 sided zip); thin b'pack top (3 sided zip); and uppermost weather-proof pouch. The latter has 4 clips on each corner to remove, and slide on the detaching waistbelt.
Misc Tactics
While the ultimate bag for max volume seems to be the likes of f-Stop Sukha with big ICU, it's not always possible to get these things into aircabins (!) Outdoors, OTH, these bigger packs can carry plenty plus. They are designed for this task.
At checkin, I always wear a Waistcoat with lots of pockets. Even better than their Venture vest, the Country Innovation Raptor packs a gripped D850 into a main side pocket (+ much more) or the lighter Venture. Highly recommend their outdoor jackets etc designed for people like us :
https://www.countryinnovation.com/raptor-waistcoat
video review refers
Protecting Super Telephoto Rig
Where I plan to shoot mainly in vehicles (also hides) I also pack a Lowepro Lens Trekker 600 AW III for dedicated super-telephoto protection/portage shooting. Besides being more inconspicuous, this pack helps minimize knocks, dust etc in the African hinterland. In flight(s), this bag goes inside a big sports bag into the hold with a tripod and misc. items filling its empty space.
The LensTrekker is long enough to carry an assembled 400 f2.8E + D850; and this rig also fits with added TC2 III. I replaced the thick padded base with a thinner EVA synthetic rubber insert; now the assembled 400 f2.8 fits with extended hood (total length = 625mm). The specs say this bag will also take a 600 f4 with DSLR.
Aug 17, 2019 at 08:19 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
