fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Understanding the defective shutter of my Sony A7iii
Jannik Peters
p.1 #1Understanding the defective shutter of my Sony A7iii
Hello everybody,
after some valuable hints by our readers after publishing my GM 135mm review on www.phillipreeve.net, I found out that my Sony A7iii must have a defective shutter. The "ring flare" that I described in my 135 GM review is actually an artifact that is caused by light leaking through the shutter. I don't know the technical reason but I can describe it at least for now:
- Electronic shutter is of course without any issues and therefore useful to understand what happens due to the shutter issue
- Artifacts show mostly in vertical stripes around bright light sources but also in ring flares
- There seems to be mechanical wear, my sensor is full of dust although I cleaned it three weeks ago. (look at the image at f/11 below)
- Exposure at very fast shutter speeds (around 1/8000) is about 1EV too bright compared to the preview and the electronic shutter image
- The artifacts show mostly at very high shutter speeds and with very bright light sources (and mostly show when I look for flare performance..)
After getting hints from three different (independent sources), I get the impression that this issue is much more common than known before. I am very curious if there are more people on FM who are struggeling with issues like that.
Regards, Jannik
Apr 23, 2019 at 02:03 PM
vdo1
Details
p.1 #2Understanding the defective shutter of my Sony A7iii
Does that shutter have any small shiny part that moves along an arc when the shutter is travelling? Like we can see here:
https://2.img-dpreview.com/files/p/E~forums/54450320/9df6783cb69344c9903424cb24b3225d
Is there any difference between EFCS and full mechanical?
Apr 23, 2019 at 04:13 PM
StephenLowell
Details
p.1 #3Understanding the defective shutter of my Sony A7iii
Jannick,
Is EFCS (Electronic First Curtain Shutter) turned off when you're shooting "manual" shutter? If left on, at high shutter speeds, image artefacts can result.
Let us know.
Stephen
Apr 23, 2019 at 04:55 PM
StephenLowell
Details
p.1 #4Understanding the defective shutter of my Sony A7iii
Yes! There is a difference between EFCS and full mechanical.
Apr 23, 2019 at 05:10 PM
Tirpitz666
Details
p.1 #5Understanding the defective shutter of my Sony A7iii
Yeah was thinking the same, especially because the exposure in the lamps shot looks off, which is one of the effects of using EFCS at high shutter speeds.
It's quite annoying that even the last FW update doesn't let configure the option to Turn it OFF/ON to a button, as it can affect shooting quite a lot, even in ters of bokeh rendering wide open.
P.S. Dust accumulation on the Sony sensors is unfortunately quite normal, definitely the most "dusty" camera I've ever owned..
Apr 23, 2019 at 05:11 PM
vdo1
Details
p.1 #6Understanding the defective shutter of my Sony A7iii
StephenLowell wrote:
vdo1 wroteDoes that shutter have any small shiny part that moves along an arc when the shutter is travelling? Like we can see here:
I mean in Jannick’s experiment... do the rings look the same with or without EFCS?
My suspicion is that it’s the reflection of some shutter shiny part into the lens and back to the sensor.
Apr 23, 2019 at 05:17 PM
jtra
Details
p.1 #7Understanding the defective shutter of my Sony A7iii
When shutter failed in my D750, it was doing same thing for a week until it failed completely. Circular shape was most visible in faster exposures. https://www.dpreview.com/galleries/9058993461/albums/d750-failed-shutter https://www.dpreview.com/forums/thread/4037492
I think the circular shape happens because shutter blades are moved by arm rotation against pivot next to the sensor. It is brighter because a hole develops close to where the arm is attached.
See this video of shutter blade attachment movement:
Apr 23, 2019 at 11:21 PM
Jannik Peters
Details
p.1 #8Understanding the defective shutter of my Sony A7iii
EFSC looks like electronic shutter. I did this with full mechanical shutter.
I have this issue at least since my GM24 review last year, so it is still working with the issue for a while. Nevertheless, I feel it got worse since because I never got that ring flare before.
Apr 23, 2019 at 11:49 PM
Jannik Peters
Details
p.1 #9Understanding the defective shutter of my Sony A7iii
Do you remember that I was asking about B135 flare resistance? I think we know the answer now:
Zeiss Batis 135 by Jannik Reeve, auf Flickr
Apr 23, 2019 at 11:52 PM
realVivek
Details
p.1 #10Understanding the defective shutter of my Sony A7iii
I checked my A7/7R/7S. Their shutters have only one shiny metal rivet.
I am yet to check the gen II shutter.
Apr 24, 2019 at 02:44 AM
realVivek
Details
p.1 #11Understanding the defective shutter of my Sony A7iii
Perhaps it would be worthwhile to get a Nikon Z body with a Z-E adapter to check the lens performances?
(Or use an older gen camera)
https://live.staticflickr.com/1970/44791663184_d0fdbc9c79_h.jpgZeiss Batis 135 by Jannik Reeve, auf Flickr
Apr 24, 2019 at 02:46 AM
vdo1
Details
p.1 #12Understanding the defective shutter of my Sony A7iii
Guess Jannick is now qualified to vote here:
https://www.fredmiranda.com/forum/viewtopic.php?TopicID=1537478
Apr 24, 2019 at 07:54 AM
E1ho
Details
p.1 #13Understanding the defective shutter of my Sony A7iii
https://k.kakaocdn.net/dn/kDSzm/btquMCjp98Y/DjBeF7MZAe5GtOFwjNcV91/img.jpg
https://k.kakaocdn.net/dn/bQWMsx/btquOGYZjks/zOGADJ4LsM32BosyItvlI1/img.jpg
85mm. taken with mechanical shutter. EFCS off.
I have similar problem. I think it's caused by roughness of shutter blade or something.
It gets obvious when stopped down, high shutter speed.
Uneven exposure which gets darker on the top of the frame is also seen in my image.
Apr 24, 2019 at 10:20 AM
wind30
Details
p.1 #14Understanding the defective shutter of my Sony A7iii
I have another problem with mechanical shutter is that at 1/8000 pics are overexposed. It’s like 1/5500 or something.
So I have shot using silent at 1/8000. Is there anything detrimental to iq other than the rolling shutter effect for fast moving stuff? Anything bad on the bokeh, etc?
Apr 24, 2019 at 04:11 PM
HelBen85
Details
May 19, 2019 at 10:04 AM
derKoekje
Details
p.1 #16Understanding the defective shutter of my Sony A7iii
Great picture regardless! That Batis has beautiful rendering.
Edited on May 19, 2019 at 11:45 AM · View previous versions
vdo1
Details
p.1 #17Understanding the defective shutter of my Sony A7iii
If it’s a light leak in the shutter (like a micro pin hole), why would the image of the circles get sharper when closing down the aperture? (at same shutter speed)?
Jesse Evans
Details
p.1 #18Understanding the defective shutter of my Sony A7iii
Probably because the shutter speed is decreasing due to the smaller aperture.
May 19, 2019 at 12:52 PM
