fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019"Superresolution" shooting & processing for M43 (files ava...
Blueshound
p.1 #1"Superresolution" shooting & processing for M43 (files available)
Ever since reading Ian Norman's discussion on "super resolution" in Petapixel (link below), the idea that one can effectively accomplish something fundamentally similar to the Pixel Shift features on a small number of newer cameras, but without the restriction of mandatory tripod use, I've been keen to try this process for myself. I've been conducting tests on and off over the past several months, and posted some results in a Flickr album that I will link below. The album is "Shaky Human Pixel Shift"; several files in the album are available for download, so that you can view the results on your own monitor. The latest two files, also linked below, compare a "superres" file with a single frame from the burst series used for the "superres" final image. The initial development in LR CC is identical, and virtually no other processing is performed, with the exception of a light treatment of Smart Sharpen to both images as a final step.
Note that the "Superresolution" image required a very minor amount of edge cropping, necessitated by the auto-averaging.
Links
https://petapixel.com/2015/02/21/a-practical-guide-to-creating-superresolution-photos-with-photoshop/
Super Res Image: https://flic.kr/p/2eng9gE
Single Frame: https://flic.kr/p/2foxrH5
Album: Shaky Human Pixel Shift https://www.flickr.com/gp/blueshound/66oG80
In fact, the mind-blowing promise of this method is not only that you're freed from the tripod, it actually requires the slight movements inherent in hand-holding to produce the (supposedly genuine) extra detail that differentiates this from simple up-sampling, which "imagines" extra detail. You still have to be as steady as possible, and if you're too shaky, the auto-alignment won't work satisfactorily.
The resulting outcome is a file size that is approximately twice the size native to your cameras' sensor. The G9 sensor produces 5184 x 3888 pixels@ 240 ppi. The final test image that I've posted is 10381 pixels x 7748 pixels
Depending on the addition or omission of one step in the process, that being the size increase of the images in the stack, you can have dual benefits of a significant increase in file size with no apparent loss of resolution (in fact Mr. Norman seems to make a case for increased, actual resolution), as well as a dramatic reduction in noise with little to none of the detail smearing that is inherent in noise reduction software.
It seems that the price you have to pay for this gift from the Photo Gods is merely the time and effort you have to put in to get there, and also you need to have a reasonably recent version of Photoshop to hand.
A variation on this process, assuming that you were fore-sighted enough to have shot the bursts, is just averaging to dramatically reduce noise in low light, high ISO shots. (If the light weren't low, why would you have used a higher ISO, right?). In my experience, this process can work extremely well, again assuming that you were using a high enough shutter speed to avoid shake or blur, nothing is moving in frame, and you have a reasonably steady technique when hand-holding.
The process assumes that hand-holding moves the frame by a a couple of pixels, or some small number, not being too unsteady with the camera. Otherwise the result is a very soft final image that doesn't look sharp.
I've tried the process several times now, with both Panasonic m43 cameras & my Sony A7RIII. (The latest test, linked above, is from my new G9.) I'd say that my success rate has been over 80% - I've only processed a series or two that came out unacceptably soft. I've looked at it both from the point of view of simple noise reduction, to "Superres" for larger files with details preserved at least as well as in a single frame.
The brilliant thing for m43, or any camera with a smaller sensor, is that this process MAY provide you with greater results in terms of file size & noise characteristics, without waiting for tomorrow's technology. And while still enjoying the size & weight reduction compared to a larger system.
Has anyone else tried this, and if so, how were your results?
Brian
Edited on Apr 10, 2019 at 07:59 AM · View previous versions
Apr 08, 2019 at 01:21 PM
ELinder
Details
p.1 #2"Superresolution" shooting & processing for M43 (files available)
You've just described how the E-M1X hand held high resolution mode works and its benefits. Yes, it works and has definite advantages, but a few of us have found that the increase in resolution is not always evident even if the decrease in noise is. It's definitely a good tool to have in your pocket, but also not a universal fix-all.
Erich
Apr 08, 2019 at 01:43 PM
James Farrell
Details
p.1 #3"Superresolution" shooting & processing for M43 (files available)
Brian: Thanks for your post. The article that you referred to is four years old. So, nothing really new. I too own the EM1X (actually two of them) and have experimented with the hand-held high resolution settings. Candidly, I really don't find it very useful. For me (and maybe I am the problem) I find the results very 'iffy'; totally hit or miss even when I follow all of the recommended guidelines. Moreover, the increase in image size is not giving me a lot extra pixels that are really sharp compared to a good quality standard size raw file.
I have better luck if I carefully compose, focus and expose a scene with a good lens and process the standard size raw file in Photoshop and use the image enlargement algorithim "preserve detail". I do limit the Photoshop enlargement - maybe 30% or so max, which is smaller than the HHHR raw file.
For the kind of shooting I do - a lot of wildlife shooting in Canada often in less-than-ideal lighting - the HHHR option really does not work.
Apr 08, 2019 at 02:01 PM
Blueshound
Details
p.1 #4"Superresolution" shooting & processing for M43 (files available)
Thanks for the informed replies. To be clear, it was never my intention to put this forward as a solution for everyone. It's only that I found it interesting, and in part because I have seldom seen it discussed. I've also had it work reasonably well, anecdotally. And I am aware it's not new.
Kind of interesting that the EM1x has implemented something similar, or perhaps the same?
I certainly understand why it is not of universal interest. Nonetheless, I can imagine situations where it will be useful to me.
Brian
Apr 08, 2019 at 02:17 PM
bobbytan
Details
p.1 #5"Superresolution" shooting & processing for M43 (files available)
How big do you want your files to be, and what's the end use? According to this article, with a 20MP file (5184 x 3888 pixels) you can get Excellent IQ with a 24" x 36" print and "Very Good" IQ with a 36" x 48" print.
https://fotoworkspro.com/blogs/fotoworkspro-blog/how-big-can-i-print-my-image?mc_cid=9f0a7b7c74&mc_eid=0cd2e21e6c
Apr 08, 2019 at 03:43 PM
Blueshound
Details
p.1 #6"Superresolution" shooting & processing for M43 (files available)
Not to be frivolous, but on one level, it's kind of analogous to going to the moon . . . because you can . . .
More seriously, I've printed images at 40 x 30 and slightly larger, and I love large prints. Although I only have so much space for them. This on its' own isn't a real reason, as I've had good results with both Photoshop's Preserve Details option, and also with Genuine Fractals, now reincarnated by On1 as Resize.
The noise reduction aspect is interesting, it may be the best form of NR I've seen, however I've not tried DXO, which is getting a lot of praise right now. If you consider stacking burst images, and averaging, as a means of arriving at a file that is clean enough that you don't need NR software, perhaps that can be considered a win.
At any rate, it's an interesting conversation. Thanks for your input.
Brian
Apr 08, 2019 at 04:48 PM
bobbytan
Details
p.1 #7"Superresolution" shooting & processing for M43 (files available)
I believe Topaz's AI Gigapixel does a better job than the dated Genuine Fractals or Resize. I use that in combination with Topaz AI Clear (NR with sharpening) and it does a great job - but your original files have to be tack sharp and correctly exposed to begin with.
...Show more →
Apr 08, 2019 at 05:06 PM
Blueshound
Details
p.1 #8"Superresolution" shooting & processing for M43 (files available)
Interesting. I'll look into those. In past years I did use various Topaz apps extensively, but less so since I went to Sony FF cameras. Time to have a fresh look.
Thanks
Brian
Apr 08, 2019 at 05:09 PM
AJSJones
Details
p.1 #9"Superresolution" shooting & processing for M43 (files available)
If you restrict the viewing distance based on the print dimensions, then you can begin to generalize on "quality". As you say, it's the end use. I have quite a few 24x48 prints that regularly are scrutinized by guests at 10-12" - or even closer if they have good close focus eyes - after they have viewed the whole image from a distance. The extra detail (in the high-res landscape images) is what draws them in to experience both near and far. When that close, the print extends beyond the field of vision and the experience is quite different Of course, not everyone feels inclined to get close but it's a common reaction. A couple of tripod hi-res shots from the Mk2 make a spectacular wide print - be nice to be able to do that hand-held but not enough to upgrade just for that
Apr 08, 2019 at 05:38 PM
Blueshound
Details
p.1 #10"Superresolution" shooting & processing for M43 (files available)
AJSJones wrote:
bobbytan wroteHow big do you want your files to be, and what's the end use? According to this article, with a 20MP file (5184 x 3888 pixels) you can get Excellent IQ with a 24" x 36" print and "Very Good" IQ with a 36" x 48" print.
...Show more →
Feel I need to jump in here and remind that I was referring to a process that applies to a wide range of cameras. Not limited to upgrading to a specific model having an internal Pixel Shift feature.
So you CAN do that without the tripod, and in all likelihood with your existing camera. Tha's what makes it so intriguing.
Brian
Apr 08, 2019 at 05:53 PM
AJSJones
Details
p.1 #11"Superresolution" shooting & processing for M43 (files available)
Brian
I was responding to the comments I quoted. I didn't read the links but am familiar with the "multiple frame., scale up, align stack, scale back down" approach - to improve both SNR and resolution. Never tried it myself but accept the likelihood of success, based on first principles, if executed well. Now back to regular programming
Apr 08, 2019 at 07:45 PM
Bob Kane
Details
p.1 #12"Superresolution" shooting & processing for M43 (files available)
I do this often for larger prints and it works well most of the time. PS is not the best program at alignment, and when it fails PhotoAcute is a better solution. I've had particularly good results from Mavic Pro 12MP (1/2.3" sensor) drone photos, printing 30x20 with good results. Even if the "resolution" increase happens to be small, averaging out the noise is a major benefit.
Apr 08, 2019 at 08:25 PM
Blueshound
Details
p.1 #13"Superresolution" shooting & processing for M43 (files available)
Thanks for the reply, Bob. You get the original point that I was making. It's just another possible tool in the toolbox, but the cool thing is that it can be done with most cameras, doesn't require an upgrade to a new model with Hi Res onboard. (And at present, there's only one model that even proposes to allow the function to work when hand held.)
I know a landscape pro who was interested to try the process with his drone (I think he said the sensor was APS-C format). Not sure if he's tried it yet, also I have no clue if you can get a drone to remain still enough during the burst captures for this to work.
But obviously you've managed it!
Brian
Apr 09, 2019 at 07:18 AM
galenapass
Details
p.1 #14"Superresolution" shooting & processing for M43 (files available)
Very cool Brian. I like posts that reminds us of techniques that are out there but rarely discussed. About 3 to 4 years ago someone posted this method using a Nikon V2 or V3. I can't remember. That camera is very fast and can easily take bursts for alignment in post. He got great results, far exceeding what a 1 inch sensor should be able to achieve both in terms of noise and resolution. Great tool to use, everyone should give it a try.
Apr 09, 2019 at 07:43 AM
Bob Kane
Details
p.1 #15"Superresolution" shooting & processing for M43 (files available)
A couple of years ago I compared up-rezzing results using a bunch of programs (AKVIS, Resize, PS and others). With the hype about Topaz Gigapixel I revisited the files and found it to be slightly but noticeably better than the others. However, it was hard for me to decide whether it was better than Preserve Details 2.0 now in PSCC; I don't think I should have spent the money on the Topaz program, but try it for yourselves free for a month. And Bobby is right--don't waste time up-rezzing marginal files with any software.
Apr 09, 2019 at 03:33 PM
Blueshound
Details
p.1 #16"Superresolution" shooting & processing for M43 (files available)
Update: I realized there was an issue with the links for direct access to the two comparison images, so these should now work. Copied below for convenience.
Comparing software options for either or both up-sampling or noise reduction is certainly relevant to this conversation, but please be sure you've had a good look at my posted samples.
Links
Re: Topaz AI Clear, after the recommendation of that software, I downloaded and tried it on the image of the Honolulu skyline at night that you can find in the album I've linked. My initial reaction was that the result was pretty good, but not quite as good as the bursts shot, averaged etc. I plan to spend more time with it, and perhaps my impression will improve if I become more familiar with it. This was certainly the case with Topaz Infocus and Denoise.
Brian
Apr 10, 2019 at 08:07 AM
James Farrell
Details
p.1 #17"Superresolution" shooting & processing for M43 (files available)
Brian: I revisted the Peta-Pixel article about the Photoshop enlargement process you posted in your original thread here. I'll "eat a little crow" here and apologize for summarily dismissing the article without a lot of thought and some experimentation when I first replied to your post last week. Today, I spent a great deal of time playing with it and found that it really works fairly well. In fact, I think it is much better than the in-camera hand-held high resolution function of my EM1X bodies.
I will say that the process is quite involved, laborious and slow going. So, I decided to create (record) a series of Photoshop recorded "actions" (I use PS CC 2019) to make the process more easily repeatable. Of course, depending on how many images one uses to create the enlargment, it still takes some time for some of the steps to finish. But, having the Photoshop actions stored is certainly the way to go. Thanks, Jim
Apr 10, 2019 at 04:08 PM
Blueshound
Details
p.1 #18"Superresolution" shooting & processing for M43 (files available)
Hi Jim! Firstly, thank you for revisiting the topic. I'm glad you rediscovered something of merit. Not that I'll use it religiously, but it does open up some possibilities.
And you have an advantage that I don't have - the ability to compare to the similar feature in the EM1x. So an interesting observation, there.
When I first read Norman's article, only a year or so ago, this was my initial thought process:
1. I really love my Sony A7Rxx's 42mp resolution and file quality;
2. I still have fond memories of my time with m43, the small, light lenses but with images that have a "certain look" that I still appreciate (I prefer perceived depth of field to lack of it - I feel this is part of the "rendering" of m43);
3. Wouldn't it be interesting if this is factual, that a smaller-sensor camera with limited resolution (compared to 42mp, mind you) could, under reasonable circumstances, produce files that blow through it's native resolution ceiling;
4. Wouldn't it be interesting if the same process could obviate much of the noise inherent in shooting static scenes in low light, requiring higher ISOs?
5. Wouldn't it be convenient if I could travel without a tripod, and still be able to shoot clean images of cityscapes, landscapes, basically any scene without movement, during the blue hour where you normally have either the compromise of noise, or lugging the tripod?
What's not to like?
Well . . . you're of course correct, there is an investment in time and computer resources required. I've experimented with files from both m43 cameras and the A7RIII. I can testify that there is a very big difference between waiting for PS CC to align, convert to Smart Objects & apply a stacking mode to 24 files from m43, and doing the same thing with 24 files from a 42mp camera.
The good news is that the computer does the heavy lifting - I can go do something else in the meantime. (m43 files go much quicker, compared to those from the Sony.) But the advantages are the same.
The two comparison images I linked to only used 8 frames - goes much faster. For those bursts, I shot over 24 frames, but I only used the first 8.
Larger numbers of frames are (a bit) better for extreme noise reduction. Really large numbers of frames will blur moving water, in place of a ND filter, but if you're looking for a really soft result, you may need well in excess of 24 images. I seem to recall Fred referring to something on the order of 90+ frames.
Good point on the PS actions. Oh, as to the laborious process, I don't do what Ian Norman suggested, and manually calculate opacity percentages. Instead I convert all images in the stack to Smart Objects, and let the stacking mode do the work. The step for the computer to convert all to Smart Objects is often the longest in term of time required.
Brian
Apr 10, 2019 at 04:58 PM
James Farrell
Details
p.1 #19"Superresolution" shooting & processing for M43 (files available)
Brian: Thanks. Agree with the opacity percentage step being too much of a 'mental' hassle and overly labor intensive. While it takes some time to convert the layers to a smart object and then modify the stack (I use the 'median' stacking option) it's better than calcuating and entering manually an opacity percentage. I am going to continue experimenting; hope to settle on a much smaller number of images to combine - maybe 10 is a good number.
Also, going to try, just for snicks, exporting the composite image as a TIFF (or something else) and washing it through Capture One Pro 12 and see what happens. Love Photoshop but not real crazy about ACR.
Apr 10, 2019 at 05:51 PM
Blueshound
Details
p.1 #20"Superresolution" shooting & processing for M43 (files available)
I suggest trying 8 images although 10 may work at least as well. I've had the most predictable results in terms of auto-aligning when the bursts are shot using silent shutter.
As re: subsequent editing, my experience has been that the resulting file takes post very well, sometimes better than one of the single frames. You do have the option to continue on with it as a raw file, if that suits your workflow.
I've been performing basic development on LR CC prior to loading the frames as a stack in PS, but this may not be necessary, I can't say. You could try RAW development subsequently in C1.
These Smart Object composites also take sharpening very well before looking over cooked. Using only cameras with no AA filters, I don't generally do much conventional sharpening unless preparing a print file. But do try your favorite sharpening tool and see what you observe.
Brian
Apr 10, 2019 at 06:23 PM
FM ForumsMicro Four Thirds ForumJoin Upload & Sell
