p.1 #1Samyang 35mm f1.4 massive front focusing only at long distances
So I got a Samyang 35mm f1.4 and it works spectacularly indoors and portrait distances. However I tried focusing further away and it seemed to be drastically front focusing with AF, such that what I focused on is blurry even on the LCD. Using DMF I was able to make it tack sharp manually. Here's an example of focusing on a very clear subject, the head of the lamp post:
With more testing, my lens has issues even at like 30 meters away with apertures smaller than f3.5 or so
It was pretty odd, as I'm on an older NEX-5 currently that just uses contrast detection, not even phase detection. It's also focusing stopped down, be so it's not focus shift. The firmware is v.01, could v.03 actually fix this or just AF speed/stability?
I noticed wide open seems to do better, with it sometimes being in focus, though I couldn't test obvious and clear subjects like the lamppost at the time as it was too bright.
I also have the Samyang 24mm and 35mm f2.8 which seem fine, both wide open and at f/8 at the time, so it's doesn't appear to be the body nor the lack of light at f/8.
p.1 #3Samyang 35mm f1.4 massive front focusing only at long distances
realVivek wrote:
Try it after cleaning the sensor. AF performance will be affected by how clean your sensor is.
Also check to see if there is wobble or droop on the camera mount (this has a plastic mount) when you mount the large lens.
Great ideas I hadn't thought of. I did do a wet sensor cleaning a few weeks ago but can definitely see at least one piece of dust in these pictures, so I'll try that. Though, as I mentioned, the two other Samyang lenses I have don't have this issue on the same body
Those other Samyangs that I have are tiny, so mount wiggle sounded quite possible with this large lens, but I just checked and it's tightly coupled.
p.1 #5Samyang 35mm f1.4 massive front focusing only at long distances
I did test another sensor cleaning and it still has the same issue :
liftedspirit wrote:
What firmware is the lens? The latest Samyang firmware was supposed to fix some of the autofocus issues the first couple firmwares had.
It's the first firmware, V. 01. Most of the firmware notes
I've read on these lenses are that it improves autofocus "performance" and tracking speed, not outright incorrect accuracy. I was hoping someone who had this lens on earlier firmwares could comment if they had this issue.
The previous owner said they only used the lens at portrait distances, and I don't see this issue at closer portrait distances and wide open.
I did order the lens station and hope that fixes it.
p.1 #6Samyang 35mm f1.4 massive front focusing only at long distances
So I got the mount and it seemed to fix the issue in some cases (lower light golden hour on a tripod) but the next day in bright daylight it did still front focus. There is a "AF Punt" option that I'm hoping can have an effect.
