As normal get a new lens than test it on Big Bronco. Make sure I got a good copy, which it looks like I did. This lens is quite sharp on center but I knew going in its not as good as the CV 15 in the extreme corners but still very good. Its really a better 13 or 14mm lens on the corners. Now given this lens is so damn wide and man is it wide the center is very good even wide open. Now its distortion is really not that bad given a 12mm lens and with its profile in Capture One its actually quite good. It does have a very weird handlebar at the very extreme corner, why I said 13 or 14mm. Not sure you can fix it but that's okay. Im just pointing it out.
Now back in my Phase One days we used to use a 28mm lens which was quite good but the corners lacked and there is a trick in C1 that you can apply sharpness with a slider to the corners. Well it works really well on this 12mm too. So if you had something out there on the edge of the frame that was really dang important you can fix it. The extreme corners look about the best at F8/F9 after that at F11 no change and F16 diffraction is coming in full force. Frankly not sure I would use F16 with this lens anyway. Worst case you could pop off 2 shot focus stack and get from your toes to Kansas in focus.
Im just going to do F8 here as most of us would shoot here anyway as this is a 5.6 lens
Here at F8 I turned the lens profile off and on. You can see the handlebar distortion at the very top start getting straightened out with the Profile
Now what we don't know if the actually lens is like 11mm and with profile it goes to 12mm as you can see some cropping happening . My theory dont turn the profile off, your always going to want it anyway
But you can still see a little dip at that very corner. Why I said maybe a 13mm when you need that corner straight
Now I took the lens profile image and brought it into PS and corrected ever so slightly more and it looks almost perfect now. This will count if your doing interiors and such, so good to know this. My bet its now a 13mm lens
As you can see in these crops the very very corner the horizontal lens are bending down. Sky who cares but if your doing interiors or architecture work this will matter
So my view it’s a very dramatic lens to have but you have to shoot carefully with it and subject matter will be very close a lot of the time. BTW I’m about 15 feet to Big Bronco that’s dang close to that wall
Oh yea....I've got the CV 10, I get it! Still a fun lens when the opportunity arises to take advantage of it's unique characteristics.
One of my favorite lenses with very strong center. The superb color rendering shows in your samples but what I think it’s impressive is flare resistance with this ultra wide. The CV 15 has slightly higher resolution everywhere but they are pretty similar at f/8-9, which I use the most for landscapes. At the corners, the CV 15 shows less astigmatism at wide apertures but their FOV and perspective is different enough for me to carry both lenses.
Dang it you guys are killing me and it's on sale at B & H right now for $749. If I hadn't bought the Voigt 110 for myself for Christmas I'd place the order right now. I've been torn between the 12mm & 15mm for some time now...
It’s kind of tough deciding between 12/15 as both of them are quite good. I have a CV 21 so the 15 just seemed a little too much like the 21 just wider but the 12 adds another dimension with the forced perspective. But it also spread my gap out to 15,21,40,75. So it’s a little big between the 12/21 and it was hard selling my 15 because it does gap better. But I wanted wider and more drama so it feels good for me. Also I can crop a little if needed and not give up too many Mpx and if a 60mpx comes out it won’t be as big a deal cropping. The 12 has less copy variance as well. This one looks good so see how it goes
My big thing here with my MF kit is that it’s my personal kit not my work kit. I’m kind of funny in a way if I’m going out for myself I don’t want to feel like I’m working. I’ve done that over 40 years, last thing I want is to haul gear when I’m not being paid to do it. So I want small, light and all fit in a Peak Design 5 sling bag that holds 4 lenses and a body which I can go anywhere with it and not feel it to be a hassle. If it’s a hassle I’ll leave it behind. I’ve killed myself over the years hauling tons of gear for work so I don’t want to when it’s my time. Not sure you can get a kit this small. I’d grab this kit over my AF kit anyday.
