fredmiranda.com Login
This topic is in the 2018 archive. You can read it and like its posts here. It is read only.
Archive 2018Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
GMPhotography
p.1 #1Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Figured Id start the ball rolling as I got my lens yesterday and went out this morning and ran a bunch of tests. I also threw the Loxia 25mm in for good measure as the gold standard on Big Bronco. Big Bronco is a mid range test at about 40 ft for this focal length. This will be followed by a center test and a Infinity test just for the resolution side of the house.
Im not getting into all the lens specs and stuff as if you dont know it by now than you've been under a rock so stay there.
Just FYI i am on tripod here 2 second delay on electronic shutter with the A7RIII. I am focused only on one spot and that is upper center. This Sony has some surprises as its very flat field and very little distortion . Which is where we will start
Oct 30, 2018 at 11:10 AM
GMPhotography
Details
p.1 #2Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Sony looks to have a very slight Pin cushion distortion which is a easy fix and really may not even need a lens profile.
Also I am correcting the vignette and exposure here so everything is on the same level for easier viewing. This is a IQ test so we need to see everything the same for now
Please READ the EXIF data or my instructions carefully
Oct 30, 2018 at 11:12 AM
GMPhotography
Details
p.1 #3Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Okay Upper Left
Upper Right
Center
This is at F1.4
Oct 30, 2018 at 11:19 AM
Holger
Details
p.1 #4Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
...Show more →
FOV differences are bigger than expected.
Oct 30, 2018 at 11:20 AM
GMPhotography
Details
p.1 #5Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
As you can see even at 1.4 its really quite good in the corners. So tells me two things here I have a nice even copy of the lens and the field Curvature is very small or is none. There is a little noise because of the vignette correction
Oct 30, 2018 at 11:22 AM
GMPhotography
Details
p.1 #6Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Lets move on to F2 before we bring in the Loxia at 2.4
Left
Right
Center
Oct 30, 2018 at 11:25 AM
GMPhotography
Details
p.1 #7Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Just for the record. Ive been shooting this wall for years with just about every lens out there and i NEVER seen a 1.4 lens act this good already in the apertures. NEVER at 1.4 this good
Now hold on to your jet packs you not going to believe this next one
Oct 30, 2018 at 11:27 AM
TheEmrys
Details
p.1 #8Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Wow, the anticipation is killing me!
Oct 30, 2018 at 11:33 AM
pdmphoto
Details
p.1 #9Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Looks like mine at f1.4, where it seems to be optimized for - it performs excellent at open apertures.
Looking at the f2.4 comparison the higher contrast of the Loxia is readily apparent to me in the red slat boards along the roof, "Western Home Furnishings" sign (lettering and the rope below the letters), and the Big Bronco star.
Oct 30, 2018 at 11:34 AM
GMPhotography
Details
p.1 #10Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
I did shoot the Loxia 25 here at the same framing. I pulled back but the first image I did want to show the difference in focal length
Oct 30, 2018 at 11:35 AM
GMPhotography
Details
p.1 #11Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Okay at 2.4 for the Loxia and 2.5 for the Sony
Sony top
Loxia Bottom
Left
right
center
Edited on Oct 30, 2018 at 11:37 AM · View previous versions
Oct 30, 2018 at 11:36 AM
pdmphoto
Details
p.1 #12Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
It does look like the Sony may have more saturated colors. I haven't done a direct comparison with my Loxia 21 (poor weather), but I have noticed the same bold colors from my lens.
GMPhotography
Details
p.1 #13Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Paul I am fooling around with exposure just trying to get things even but Id like to see the Loxia and Sony Color stuff too. So try to judge here just IQ
Let me get to F8 where there is nothing going on and post full frame of that
Edited on Oct 30, 2018 at 11:41 AM · View previous versions
Oct 30, 2018 at 11:39 AM
GMPhotography
Details
p.1 #14Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Center
GMPhotography
Details
p.1 #15Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Okay just the left crop
At 2.8
Sony
Loxia
Oct 30, 2018 at 11:45 AM
GMPhotography
Details
p.1 #16Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
So to save time the Sony is perfect at F4 which is amazing but Im loading both the Loxia 25 and Sony Raws now so folks can look at this on there own. I have a project to get on so I need to move along here.
But so far the Sony is damn good
Oct 30, 2018 at 11:52 AM
GMPhotography
Details
p.1 #17Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Okay for color and comparing Ill do F8 on both lenses as no adjustments are made here
Edited on Oct 30, 2018 at 11:55 AM · View previous versions
chiron
Details
p.1 #18Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
I got my Sony 24mm 1.4 GM yesterday and shot my wall of books last night, in comparison against my Canon 24mm 1.4L II, which I like very much and favor over the Batis 25mm. Similar to Guy's experience, my Sony 24mm was very sharp wide open at center, with better, richer colors and better contrast than the Canon 24 1.4L II. The edges on the Sony were also very good wide open, much better than the Canon, with the corners still having a lot of definition, significantly better than the Canon, but losing color to vignetting.
It seems like an outstanding lens, and as I wrote in another thread, it is very small and light. It feels and handles in a way that reminds me of a smaller Sony 12-24mm f/4 zoom. That zoom is an amazing lens, and the Sony 24mm looks to be special in similar ways.
Bravo to Sony's lens designers!
Oct 30, 2018 at 11:53 AM
GMPhotography
Details
p.1 #19Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Im pretty damn shocked its so close if not exceeds the Loxia here. Sunstars and flare maybe a different matter but this thing is good.
Im loading Big Bronco Raws now folks so you can compare on your machines
Here you go
https://spaces.hightail.com/receive/8MbWcHlISr
Oct 30, 2018 at 11:58 AM
jwhatts
Details
p.1 #20Sony FE 24mm f/1.4 GM Lens Big Bronco testing thread plus more
Looks pretty even in the center, the Loxia might have the slight edge in the corners. About what I expected. It's encouraging to see just how sharp the GM is in the center wide open.
