p.1 #1EFCS new Sony users may want to read up a bit
Since the advent of the amazing A9 and A7RIII, and now Sony's basic () and more affordable A7III.... we have hundreds of new brothers and sisters coming here into the Sony forum, from Canon and Nikon. Perhaps a few of them are n00bs with regard to EFCS.
What is EFCS?
Electronic Front-Curtain Shutter
and it's not new to Sony. But it may be more relevant now, for you, with these new(er) bodies and options.
If you are indeed a n00b, I will give you a crumb of info here, to get you interested:
If you are planning to capture fast moving subjects at fast shutter speeds (such as when photographing sports or wildlife), it is better to turn EFCS off on a mirrorless camera. This is not an issue in DSLR cameras, because EFCS is disabled when shooting in Single and Continuous Release modes. - c/o Nasim Mansurov
I have supplied quoted, tidbits, and nuggets from different threads, blogs, articles for your review.
But if someone has anything to add, specifically with regard to the A9 vs. the A7 bodies, I'm sure many here will benefit from it.
Personally, I forgot about it on my A7rIII and had it set to ON.
and this week I turned it off.
It may not effect everyone. I shoot portrait, primarily in good light, with 1.4 glass, so my shutter speed can get up there. My shutter is now louder.
But I feel as if I prefer the results.
- I hope this info below helps someone
- And, please, pros... do add personal feedback/findings
Our good buddy @Steve_Spencer has said:
The big benefit of electronic first curtain shutter (EFCS) is that it allows reductions in vibration when the first curtain opens and this does make a difference especially in longer focal length shot at are 1/100. The A7r which did not have EFCS had problems with longer focal length shots around that shutter speed.
EFCS can cause problems though as well. As you note, it can lead to problems with flash and it can also affect the bokeh negatively for shots at or above 1/1000 with fast lens at or near wide open aperture. So, part of having a mirrorless camera is that you can use EFCS which is an advantage for some types of shooting, but it should be shut off for other types of shooting. You should get used to changing it depending on the type of shooting you are doing. For me it can be a big annoyance when I forget to do so.
@mcbroomf has said:
EFC eliminates the vibration associated with the mechanical 1st curtain closing/opening as it electronically clears the sensor at the start of the exposure (and with a Sony the shutter is normally open of course for liveview). I can't tell you about flash, but you will get a dark shading if you use it in natural light at faster shutter speeds than ~1/1000.
@Parariss has said:
RE A9
EFCS also reduces mechanical wear and tear and cuts down audible noise. Outside of using flash and shutter speeds faster than 1/1000, most people are best served by leaving it on. It should be said for other passers by, however, that the a9 is a different animal, so these rules of thumb may not apply.
The Sony A9's full-autofocus shutter lag (with the subject at a fixed distance) was good although not exceptional, measuring in at 0.216 second in Single-area (Center) AF mode with the Sony Zeiss 35mm f/2.8 lens. This was with the mechanical shutter and electronic first curtain shutter (EFCS) enabled by default. With EFCS disabled, full AF shutter lag increased to 0.355 second. With the fully electronic shutter, full AF shutter lag was 0.231 second, a little slower than with EFCS.
When manually focused, the Sony A9's shutter lag dropped to 0.097 second with EFCS, or 0.249 second without. With the fully electronic shutter, manual focus shutter lag was 0.119 second.
The Sony A9's prefocused shutter lag was only 0.020 second with EFCS, which is very fast. Without EFCS, prefocused shutter lag increased dramatically 0.165 second, but with the fully electronic shutter, it was only 0.038 second.
From our good friend, Jim Kasson
c/o http://blog.kasson.com/the-last-word/sony-a9-edr-vs-iso-setting/
re: A9
The Dynamic Range test are already in, and one interesting thing was that in single shot mode the electronic shutter actually has slightly more DR than with the mechanical shutter set to electronic first curtain shutter (EFCS).
p.1 #4EFCS new Sony users may want to read up a bit
Have they fixed the banding that occurs with EFCS at shutter speeds above 1/1000?
It was always a pain to have to turn EFCS off when I was shooting in the studio with strobe at those shutter speeds, as it’s not immediately apparent on the back of the camera and the banding is very noticeable when shot against smooth backgrounds like seamless
p.1 #6EFCS new Sony users may want to read up a bit
I wish there was an EFCS auto parameter that we could set!!! firmware update? haha
p.1 #7EFCS new Sony users may want to read up a bit
Dj R wrote: sungphoto wroteHave they fixed the banding that occurs with EFCS at shutter speeds above 1/1000?
It was always a pain to have to turn EFCS off when I was shooting in the studio with strobe at those shutter speeds, as it’s not immediately apparent on the back of the camera and the banding is very noticeable when shot against smooth backgrounds like seamlessI wish there was an EFCS auto parameter that we could set!!! firmware update? haha
Sad trombone - it is something that I don't use often, but when I forget to turn EFCS off after a client session, it absolutely killed me. Thankfully you don't notice it as much on surfaces that aren't a solid color I guess (ie skin) but some clothing and definitely the backdrop would show it - requiring additional retouching time.
I never noticed it shooting on location at 1/1000 or higher on location + strobe, but you notice it right away from studio sessions.
p.1 #8EFCS new Sony users may want to read up a bit
This is where Sony's background primarily as an appliance manufacturer rather than a camera manufacturer is really exposed - if they had any camera nous, they'd get this and fix it straight away...
p.1 #9EFCS new Sony users may want to read up a bit
navmannz wrote: Dj R wrotesungphoto wroteHave they fixed the banding that occurs with EFCS at shutter speeds above 1/1000?
It was always a pain to have to turn EFCS off when I was shooting in the studio with strobe at those shutter speeds, as it’s not immediately apparent on the back of the camera and the banding is very noticeable when shot against smooth backgrounds like seamlessI wish there was an EFCS auto parameter that we could set!!! firmware update? hahaThis is where Sony's background primarily as an appliance manufacturer rather than a camera manufacturer is really exposed - if they had any camera nous, they'd get this and fix it straight away...
-John
Sony can come out with any firmware update they want, all day. they are printing money.
I will see if this is on their radar.
p.1 #10EFCS new Sony users may want to read up a bit
Dj R wrote: navmannz wroteDj R wrotesungphoto wroteHave they fixed the banding that occurs with EFCS at shutter speeds above 1/1000?
-JohnSony can come out with any firmware update they want, all day. they are printing money.
It should be easy enough to do. My Fuji GFX automatically shuts off EFCS and goes with the manual shutter at shutter speeds of 1/1000 and faster. I am sure Sony could do the same thing. I am just not sure that they will.
p.1 #11EFCS new Sony users may want to read up a bit
Elisha82 wrote:
I have had no issue with HSS or SS over 1/1000 with EFCS on the A73.
The bokeh will suffer with fast lenses, however, so if you are shooting with an aperture faster than f/2 you should shut off EFCS for shutter speeds at 1/1000 or faster.
p.1 #12EFCS new Sony users may want to read up a bit
Steve Spencer wrote: Dj R wroteSony can come out with any firmware update they want, all day. they are printing money.
I will see if this is on their radar.It should be easy enough to do. My Fuji GFX automatically shuts off EFCS and goes with the manual shutter at shutter speeds of 1/1000 and faster. I am sure Sony could do the same thing. I am just not sure that they will.
But making cameras has been Fuji's predominant business, so they get the practical application. I'm fairly sure that Sony won't change it via a firmware, because like compressed raw and the star-eater, lots have people have already asked for it to be set up like your Fuji, and they've ignored the requests - and if they haven't done it by now, I think that we can be fairly sure that they won't. IMHO it's the sort of corporate 'we-know-best' that means that their cameras will probably never progress beyond being marvels of electronic wizardry to being true camera classics as in the sense of the Nikon F or the Olympus OM-1.
p.1 #13EFCS new Sony users may want to read up a bit
navmannz wrote: Steve Spencer wroteDj R wroteSony can come out with any firmware update they want, all day. they are printing money.
I will see if this is on their radar.It should be easy enough to do. My Fuji GFX automatically shuts off EFCS and goes with the manual shutter at shutter speeds of 1/1000 and faster. I am sure Sony could do the same thing. I am just not sure that they will.But making cameras has been Fuji's predominant business, so they get the practical application. I'm fairly sure that Sony won't change it via a firmware, because like compressed raw and the star-eater, lots have people have already asked for it to be set up like your Fuji, and they've ignored the requests - and if they haven't done it by now, I think that we can be fairly sure that they won't. IMHO it's the sort of corporate 'we-know-best' that means that their cameras will probably never progress beyond being marvels of electronic wizardry to being true camera classics as in the sense of the Nikon F or the Olympus OM-1.
I disagree. I think the progressive changes in the successive iterations of A7 cameras clearly demonstrate that Sony is listening very carefully to its customers and that it is designing for real photographers. It is designing a new type of camera, however, so some users who are used to older styles of cameras will be discomfited. Sony does update its firmware as necessary. I do not know why it does not add every new feature that is requested via firmware; but I definitely do not think it is because they are not listening to their customers. And they are introducing new models with very innovative new features at a blazing rate.
p.1 #14EFCS new Sony users may want to read up a bit
Steve Spencer wrote: Elisha82 wroteI have had no issue with HSS or SS over 1/1000 with EFCS on the A73.The bokeh will suffer with fast lenses, however, so if you are shooting with an aperture faster than f/2 you should shut off EFCS for shutter speeds at 1/1000 or faster.
Shooting with silent shutter will also do the trick.
p.1 #15EFCS new Sony users may want to read up a bit
Steve Spencer wrote: Dj R wrotenavmannz wroteDj R wrotesungphoto wroteHave they fixed the banding that occurs with EFCS at shutter speeds above 1/1000?
The D850 limits the max shutter speed to 1/2000 if you are in EFCS mode. I have had many over exposed shots outside when I forgot! Technically the easiest FW fix is just limit the shutter speed when the EFCS mode is on.
p.1 #16EFCS new Sony users may want to read up a bit
Unfortunately this doesn’t help when using flash
Fred Miranda wrote: Steve Spencer wroteElisha82 wroteI have had no issue with HSS or SS over 1/1000 with EFCS on the A73.The bokeh will suffer with fast lenses, however, so if you are shooting with an aperture faster than f/2 you should shut off EFCS for shutter speeds at 1/1000 or faster.Shooting with silent shutter will also do the trick.
p.1 #17EFCS new Sony users may want to read up a bit
If I'm using the full E-shutter on my A9 is it true I don't have to concern myself with any of these other EFCS settings? I've never looked at those settings but I've only taken about 10 images with mechanical shutter just to hear what it sounded like
p.1 #18EFCS new Sony users may want to read up a bit
chiron wrote: navmannz wroteSteve Spencer wroteDj R wroteSony can come out with any firmware update they want, all day. they are printing money.
-JohnI disagree. I think the progressive changes in the successive iterations of A7 cameras clearly demonstrate that Sony is listening very carefully to its customers and that it is designing for real photographers. It is designing a new type of camera, however, so some users who are used to older styles of cameras will be discomfited. Sony does update its firmware as necessary. I do not know why it does not add every new feature that is requested via firmware; but I definitely do not think it is because they are not listening to their customers. And they are introducing new models with very innovative new features at a blazing rate.
Actually Sony has added a lot of things via firmware that indicates that they're very much in touch with customer feedback. i.e., uncompressed raw, focusing wide open with live view off, eye-AF with adapted lens...those were all added mid product cycle via firmware update.
Of course there are things that Sony has not done and that always stands out, but I think its folly to say that Sony does not listen to their customers.
p.1 #19EFCS new Sony users may want to read up a bit
p.1 #20EFCS new Sony users may want to read up a bit
Your GFX is more lenient than mine. Mine shuts off EFCS at 1/640 sec and higher.
