Archive 2018 · Which Loupe for the D850?
Matthew C
p.1 #1 · Which Loupe for the D850?
I am wanting to use a loupe with my D850 to assist with live view focusing with my manual focus lenses.
I have searched on Amazon and eBay and Google but there doesn't appear to be anything targeted at the D850.
I have seen some reference to the Zacuto Z-Finder 2.5X working, and I have seen an image of a loupe attached to the D850 by an elastic band, but I was hoping some of you would be able to comment about which brand of loupe is working for you?
Thanks.
Jan 31, 2018 at 01:08 PM
bs kite
p.1 #2 · Which Loupe for the D850?
Why not just use the magnifying glass button on the back, while you are in LiveView?
Robert
I did not know exactly how to use this feature on my D850, until a few days ago (duh).
Maybe you can't use it because it really works best on a tripod.
What do you think? Did you know about it?
Jan 31, 2018 at 01:35 PM
bs kite
p.1 #3 · Which Loupe for the D850?
When I magnify the LiveView image, I do not know why the image bounces around so much. Yes, of course, it is going to show any movement. But I do not think it would be that much vibration with a loupe. Maybe I am doing something incorrectly. Help!
Maybe others can clue-in both of us.
Jan 31, 2018 at 01:40 PM
snapsy
p.1 #4 · Which Loupe for the D850?
I use the Zacuto 2.5x on DSLRs. It makes a huge difference in getting to perfect focus quickly and confidently. I shoot with tripods and prefer to hold the loupe up to the screen myself rather than using the attachments.
Jan 31, 2018 at 01:44 PM
snapsy
p.1 #5 · Which Loupe for the D850?
Loupe would show the vibration more if it's a magnifying variety. Either your tripod isn't doing its job or perhaps you're seeing the IS element shift if you happen to be using an IS lens and IS is enabled.
Jan 31, 2018 at 01:45 PM
Andre Y
p.1 #6 · Which Loupe for the D850?
I use a Kinotehnik, which made a dedicated frame for the older DSLRs that fit into the tabs for the plastic screen protectors. On the D850, you have to use a glue-on frame, which doesn't stick so well to the oleophobic screen protector I have on it, so it's gaffer taped onto the screen!
The great thing about the Kinotehnik is that it doesn't interfere with things like RRS L-plates, is high quality, light, and affordable. It also gives you a fairly complete view of the screen. Early Zacutos would cut off parts of the screen, but I've been told later versions show the whole screen now.
Jan 31, 2018 at 01:59 PM
bs kite
p.1 #7 · Which Loupe for the D850?
Just took it outside. No vibration. So, it is the hardwood floor. Would never have guessed it.
Love that magnifying feature on the D850.
Thank's for the input.
Jan 31, 2018 at 02:26 PM
kaplah
p.1 #8 · Which Loupe for the D850?
Thanks.
The Zacuto is optically good, and the full attachment system is secure, if bulky. However, if you use the adhesive-frame attachment, the adhesive portion is not tall enough for Nikon LCDs, and you then choose between cutting off some of the image (at the top) or the image information during review (at the bottom).
At least, that was the case as of 2016-12-07 - might have changed, I'd contact Zacuto to confirm if you're considering their product with the adhesive attachment.
Jan 31, 2018 at 02:50 PM
JBPhotog
p.1 #9 · Which Loupe for the D850?
Although I don't use a D850, I have a Hoodman Loupe and would not be without it or one like it. They make one for the 3.2" LCD's.
Jan 31, 2018 at 04:42 PM
Photozack81
p.1 #10 · Which Loupe for the D850?
Robert
This is kinda my thinking.
I can understand some sort of viewfinder magnifier on occasion, but LV has this built in.
Feb 01, 2018 at 04:05 AM
mawz
p.1 #11 · Which Loupe for the D850?
The magnifiers also shade the LCD, providing a much better viewing experience in sunlight, they basically turn the LCD into a large EVF for tripod shooting.
Mar 23, 2018 at 08:48 AM
HCE HCE
p.1 #12 · Which Loupe for the D850?
I use a Hoodman if I need to block bright light but it is bulky and a bit inconvenient.
A small 1.5-in diameter souvenir magnifier with about a 4-in focal length is a lot handier, thinner, cheap and doesn't require the eye to be positioned perpendicular to the screen. The one I use is attached to a folded case of vinyl marked Florida
-Jay-
Mar 23, 2018 at 09:01 AM
