Archive 2017 · Breakthrough Photo X2 vs X4 ND Filters
csebasti
p.1 #1 · Breakthrough Photo X2 vs X4 ND Filters
I'm interested in buying a 6 stop ND filter and after a lot of research I'm thinking about going with a Breakthrough Photo X2 or X4 filter. But, I'm having trouble understanding what the real differences are between the two. Can anyone help out with what is different and how that affects the real world results?
It appears the differences are the grip on the filter ring, the glass ,and the amount of coatings. Is this correct? Anything else? What does that translate to in real world use?
Essentially, is the X4 worth 70% more than the X2? (6 stop 77mm).
For reference, I'll be using this for landscape work on a 5DIV, 17-40, and 24-105. I'm not a pro, but do sell my work at art fairs and such.
Thanks for any help.
Chris
Jun 10, 2017 at 12:39 AM
Norm Shapiro
p.1 #2 · Breakthrough Photo X2 vs X4 ND Filters
I bought the 4X one. Better glass and a 35 year warranty. Sure it costs more but I do a lot work around the ocean and wanted a filter that could handle the elements along with a company that stands behind their products. This is my second filter I've bought directly from them along with their excellent 77 to 52 mm adapters.
Jun 10, 2017 at 04:34 PM
sjms
p.1 #3 · Breakthrough Photo X2 vs X4 ND Filters
X4 (used to be called X3)
25 year warranty
Shott B270 glass produced in Germany
16 layers of multicoating (8 per side with the outer being hydrophobic)
3.1mm deep
X2
25 warranty
H-K9L optical glass made in Japan
8 layers of multicoating (4 per side with hydrophobic outer)
3.5mm deep
I use the 3, 6 and 10 stop X4
X4 CPL
72-77, 77-82, 72-82 brass step rings
all of them BT.
Jun 10, 2017 at 07:37 PM
csebasti
p.1 #4 · Breakthrough Photo X2 vs X4 ND Filters
Thanks for the info guys. Anyone know of any reviews showing the real world differences in practical use in terms of image quality, color neutrality? I'm trying to get an idea if the price difference is really worth it for me. I understand it certainly will be worth it for some, and not for others.
Chris
Jun 11, 2017 at 08:34 PM
sjms
p.1 #5 · Breakthrough Photo X2 vs X4 ND Filters
They have pretty much proven to be the most color neutral filters out there
Jun 11, 2017 at 09:27 PM
csebasti
p.1 #6 · Breakthrough Photo X2 vs X4 ND Filters
Right, that is what I've read. What I'm trying to figure out is should I drop the extra cash on the X4, or go with the cheaper X2. I haven't been able to find anything that gives me any indication of the performance difference between the two.
Jun 11, 2017 at 10:49 PM
sjms
p.1 #7 · Breakthrough Photo X2 vs X4 ND Filters
with a 300 day return policy I would think you yourself can work out which one is perfect for you.
neither of the images below reqd CC
6 stop X4 BT filter.
6 stop X4 BT filter
Jun 12, 2017 at 07:37 AM
csebasti
p.1 #8 · Breakthrough Photo X2 vs X4 ND Filters
Yes, that is true. Good point.
Nice images.
Jun 13, 2017 at 02:05 AM
GroovyGeek
p.1 #9 · Breakthrough Photo X2 vs X4 ND Filters
Color correction is not that big a deal (or more precisely color temperature correction). I do it on all my images anyway, whether they are taken with a filter or without. Color shift on the other hand can be problematic. Sticky surfaces, as on some Hoya filters, can be a PITA around water.
All reviews I have seen agree that in terms of quality BT is the best there is. If money is no object go with them with the understanding that a full set will set you back $500+ for the 77mm version. Make sure that this is big enough for your lenses. May WA lenses nowadays require larger filters. Some WA lenses require ultra thin rings on the wide end to avoid vignetting.
For me the requirements are no color shift, no particularly bothersome cleaning issues, and only then multi-coating. Most of the time you would not be shooting into the sun with strong ND, so reflections are not that big a deal. I don't measurebate much and am yet to see the difference between a single coated and multi-coated filter. It probably is there if you pixel peep.
Jun 23, 2017 at 01:54 AM
sjms
p.1 #10 · Breakthrough Photo X2 vs X4 ND Filters
everyone has their own "specifications" to live and work with.
Jun 23, 2017 at 07:48 AM
gavinator68
p.1 #11 · Breakthrough Photo X2 vs X4 ND Filters
I know this is an ancient thread but thought I would add one more important point about the very real differences between the two versions...........the X2 is anodized aluminum and the X4 is electroplated brass. The brass, in this sort of fine-threaded application, will provide a smoother thread experience, over a longer period of time, in more environments compared to the anodized aluminum of the X2.
Cheers,
David
May 04, 2023 at 04:11 PM
mark1958
p.1 #12 · Breakthrough Photo X2 vs X4 ND Filters
the one issue I have with Breakthrough filters is they tend to get stuck.. and need a filter wrench to separate
May 07, 2023 at 05:18 PM
sjms
p.1 #13 · Breakthrough Photo X2 vs X4 ND Filters
use lip balm on the threads.
May 07, 2023 at 05:26 PM
LBJ2
p.1 #14 · Breakthrough Photo X2 vs X4 ND Filters
One of the reasons to buy X4 (harder brass) instead of X2 ( softer aluminum).
Either way, a $9 "3 Packs Camera Lens Filter Wrench Kit, CPL UV ND Filter Removal Wrench Tool Set" from Amazon.
May 09, 2023 at 07:13 AM
