This topic is in the 2016 archive. You can read it and like its posts here. It is read only.
Archive 2016Sony A7r II vs Canon on 11-24 f/4 too soft?
madlantern
p.1 #1Sony A7r II vs Canon on 11-24 f/4 too soft?
I recently bought a A7r II, along with a Metabones IV adapter with which to use my Canon lenses. The 11-24 f/4 is perhaps my most used lens, so I decided to try this with the Sony + adapter combination. I compared the Sony A7R II against the Canon 5Ds R. I tried both auto focus and manual focus.
All shots were taken with f/8, ISO 100, and 1/25 sec. No adjustments, expect default sharpening: amount 25; radius 1.0; and detail 25.
For my manual focus shots, I zoomed to the highest magnification on live view LCD and used the red “CIBC” sign in the center of the image as reference (the standalone one on the sidewalk, not the one affixed to the side of the building).
For the auto-focus shots, I used the same area. On the Canon, I put the focus rectangle directly on the sign. On the Sony, I used “Flexible Spot-M” - against directly over the sign. In between every shot, I twisted the focus ring to the left about 1/4 of a turn to force it to focus again.
So I got 20 images in total.
5x Canon Autofocus
5x Canon Manual focus
5x Sony Autofocus
5x Sony Manual focus
the raws + jpgs are here:
https://www.dropbox.com/sh/inu341rm5kyviwd/AADeyBh-8bR5J9P2ho5D68Wna?dl=0
Some of the shots I got seemed disappointingly soft. Especially on the Sony with autofocus. Between the 5 sony autofocus shots, there’s quite a bit of variation. Some are noticeably shaper than others. On the Canon, all the all shots seem remarkably consistent - i.e. no variation between them.
I know an adapted lens is not going to have great AF performance at all, but this seems too poor given it's just a static image - and a very contrasty and easy to focus one.
In comparing the the manual focused shots, the Canon still seems to retain a a very slight lead - even after normalizing for the slightly lower resolution of the Sony.
So my question are these results normal? Or do I have a broken adapter? Or some other cause?
Edited on Jun 09, 2016 at 06:12 AM · View previous versions
Jun 09, 2016 at 04:47 AM
Eyvind Ness
Details
p.1 #2Sony A7r II vs Canon on 11-24 f/4 too soft?
I did a similar test recently, but with the TS-E 24mm II, with similar results (no AF, of course). the 5DSR is much easier to use also, with a better LCD, and more zoomed in for manual focus.
Jun 09, 2016 at 05:13 AM
madlantern
Details
p.1 #3Sony A7r II vs Canon on 11-24 f/4 too soft?
Really? thats very unexpected. how is this even remotely acceptable - especially for a high resolution body like the A7R II?
As a landscape enthusiastist who sometimes prints very large (24 x 36), this softness severely limits my options
Jun 09, 2016 at 05:18 AM
MJKoski
Details
p.1 #4Sony A7r II vs Canon on 11-24 f/4 too soft?
Sad but true. Adapters give more headaches than they solve...
Jun 09, 2016 at 05:28 AM
Eyvind Ness
Details
p.1 #5Sony A7r II vs Canon on 11-24 f/4 too soft?
I use my A7RII for travel and when low weight is essential. For all other uses, especially uses involving a need for fast AF acquisition and tracking, I always grab the 5DSR.
But you already owned a 5DSR when you bought the A7RII? With which expectations or plans, if I may ask?
Jun 09, 2016 at 05:37 AM
madlantern
Details
p.1 #6Sony A7r II vs Canon on 11-24 f/4 too soft?
Exactly - I was hoping to get a smaller body with light lenses for hiking and a camera with great high ISO performance. I know the Sony lens lineup is lacking, so I was expecting to adapt my existing Canon lenses until a few years from now where Sony builds a more complete les lineup. The 11-24 is especially important to me, especially since Sony will probably never release an equivalent.
But the adapter performance is killing that last part of my plan. I was hoping this is an isolated Metabones QC problem that can be solved by an exchange (or two).
I wasn't expecting great AF performance, but this was a static scene focusing on a very contrasts part. I don't use AF a lot, but I'd still like to have it for those times I'm in a hurry. And besides, even looking at the manual focused images, the canon seems to be the slight winner
Edited on Jun 09, 2016 at 06:01 AM · View previous versions
Jun 09, 2016 at 05:48 AM
Cliff L.
Details
p.1 #7Sony A7r II vs Canon on 11-24 f/4 too soft?
Did you have the in-body image stabilization turned on in the A7R II when you did this test? If so, try repeating the test with the OSS off.
Jun 09, 2016 at 06:00 AM
madlantern
Details
p.1 #8Sony A7r II vs Canon on 11-24 f/4 too soft?
I'm not sure. The "SteadyShot" option is set to ON and but the "SteadyShot Settings" is set to AUTO. I didn't manually program in the focal length. With the Metabones IV adapter, I thought IBIS is only engaged if you manually punch in the focal length? Or is this not so?
Also to get the best picture in theory, would I have to manually disable IBIS every time I shoot on a tripod? I do that now with OSS built into the lens, but I thought IBIS could be left on without consequence.
Jun 09, 2016 at 06:05 AM
MJKoski
Details
p.1 #9Sony A7r II vs Canon on 11-24 f/4 too soft?
Right...you need to disable it. If it is set to on then it is on.
Jun 09, 2016 at 06:42 AM
Gary Clennan
Details
p.1 #10Sony A7r II vs Canon on 11-24 f/4 too soft?
The 11-24mm is known to be awesome (albeit huuuuge) on the A7RII. My bet is that your adapter (or the IBIS) is the culprit here.
Jun 09, 2016 at 10:40 AM
Jman13
Details
p.1 #11Sony A7r II vs Canon on 11-24 f/4 too soft?
What firmware is your adapter on? Current is 0.49, I believe.
Performance with the metabones (and any smart adapter) is really variable between lenses. My 70-200/4L and 100/2 both work beautifully with the smart adapters, for instance. I'm not sure what the compatibility is for the 11-24mm.
Jun 09, 2016 at 12:45 PM
Jman13
Details
p.1 #12Sony A7r II vs Canon on 11-24 f/4 too soft?
xoda wrote:
molson wroteDid you have the in-body image stabilization turned on in the A7R II when you did this test? If so, try repeating the test with the OSS off.
If IBIS is set to On, it'll use it all the time (though I've found it to be tripod sensing in my situations). You only need to enter focal length if you are adapting a lens without EXIF information passed between. Smart adapters pass the focal length to the camera, so you won't need to manually input that for IBIS to work.
Jun 09, 2016 at 12:49 PM
madlantern
Details
p.1 #13Sony A7r II vs Canon on 11-24 f/4 too soft?
I repeated the test… some very strange results.
First, I noticed that the corner sharpness for the on the 5Ds has improved significantly. I used liveview with 2sec timer both times. So I don’t know what would cause the discrepancy.
[size=12]Autofocus[/size]
Then I compared the autofocus performance of both the Sigma MC11 and the Metabones IV adapter against the native body. I exchanged the Metabones IV adapter today, so this is a new copy. I never had the Sigma previously.
The autofocus performance for both lenses seem markedly improved from my previous adapter. I took ten shots with each adapter (again, resetting the focus in between each shot). With the Canon, it managed almost no variation whatsoever between shots, but both adapters still show some variation. But the Sigma seem better in this regard.
I highly recommend downloading the full sized jpgs/raws and reviewing them sequentially in Lightroom.
Corner
I also compared the manual focus performance of the adapters. In the center, they are no different than the 5Ds. Woohoo! But the corner performance seems far inferior to the 5Ds.
The strange thing is - I went back and compared the today’s Metabone IV with yesterday’s. Yesterday’s was much much better in the corner. Why is I didn’t realize adapters could affect optical performance so much.
Jun 09, 2016 at 11:28 PM
madlantern
Details
p.1 #14Sony A7r II vs Canon on 11-24 f/4 too soft?
Here's the full-sized jpg link: https://www.dropbox.com/sh/vc8pa0kop1z21we/AABPJ4MCd2qY8V4BK_9fAL9Ea?dl=0
Corner
Jun 09, 2016 at 11:43 PM
jamato8
Details
p.1 #15Sony A7r II vs Canon on 11-24 f/4 too soft?
I use the 11-24 on the A7RII and get excellent results. Good contrast and sharp. I shoot around f8 with ibis.
Jun 09, 2016 at 11:50 PM
madlantern
Details
p.1 #16Sony A7r II vs Canon on 11-24 f/4 too soft?
do you use the Metabones IV adapter? Or Sigma? Or some other one?
Jun 10, 2016 at 01:54 AM
ThanhHa
Details
p.1 #17Sony A7r II vs Canon on 11-24 f/4 too soft?
xoda wrote:
Corner
The problem is adapter's thickness will cause image degradation with floating element lens. Try to focus to a very far distance (infinity focus) with your lens on the 5DS, then on the A7RII with the Metabones, then repeat with the Sigma MC-11 and you should see the focusing scale window in the lens reads different value with all 3 setups. You can use your phone's camera to capture the focusing scale window in the lens after each test and compare them in the screen.
Jun 10, 2016 at 02:36 AM
madlantern
Details
p.1 #18Sony A7r II vs Canon on 11-24 f/4 too soft?
Yes - I noticed that. The Metabones and 5Ds had slightly different focusing scale readings. The Sigma was much more different.
Is image degradation on floating element lenses an inevitable law of optical design, or can user minimize or even eliminate it?
Jun 10, 2016 at 03:13 AM
MJKoski
Details
p.1 #19Sony A7r II vs Canon on 11-24 f/4 too soft?
You can add shimms into the adapter to bring it close or even with Canon standard register distance. Of course if the adapter is too thick then shimms are not gonna help :]
Jun 10, 2016 at 04:26 AM
Cliff L.
Details
p.1 #20Sony A7r II vs Canon on 11-24 f/4 too soft?
ThanhHa wrote:
xoda wroteCorner
It may not be the adapter's fault... it could be your camera body.
David Kilpatrick's review of the A7R II includes some interesting observations on the sloppy tolerances of the Sony lens mount (and may explain why some of the adapters I found to work very well on the A7R wouldn't even fit on the A7R II...)
Jun 10, 2016 at 06:26 AM
