fredmiranda.com Login
This topic is in the 2016 archive. You can read it and like its posts here. It is read only.
Archive 2016D500 w 3rd Party Glass - Battery Drain
backdoorhippie
p.1 #1D500 w 3rd Party Glass - Battery Drain
I have another thread out there regarding an issue I'm having with my D500 when using the Sigma 150-600mm Sport lens where the image review screen will not turn off and all active camera functions stay on. It's not a problem I can reproduce at will, but it will happen at some point every time I shoot. Until yesterday it never happened with another lens, but when I put a Kenko 2x TC on my Nikon 70-200mm f4 it happened the first shot out, but like the Sigma was an intermittent issue.
I bring that up because after shooting about 150 frames I put the camera down as is (with the TC connected) and went about my business for the night. The camera was in the ON position, but nothing was displaying.
This morning the battery is dead.
I'd mentioned in the 150-600 thread that I'd noticed undue battery drain overnight with the lens attached, but that would be, maybe, a 20-30% drop. I stuck a fresh battery in before shooting yesterday, fired 150 frames in 2 hours, set it down, and now it's unusable.
I'm going to play with this some more, but I'm desperate to find out if anyone else has seen this with any 3rd party lenses/optical attachments? I'm using the current Li-ion20 battery, so it's not that. I expect no help from Nikon since they seem to refuse to acknowledge the idea that their bodies should function properly with 3rd party lenses, but I will be contacting them anyway.
Jun 09, 2016 at 04:39 AM
Chris Dees
Details
p.1 #2D500 w 3rd Party Glass - Battery Drain
Put the camera in "Airplane Mode" (No WiFi, no BT).
But even than I do not come close to the battery-usage of my D810.
Edited on Jun 09, 2016 at 07:28 AM · View previous versions
Jun 09, 2016 at 06:26 AM
trenchmonkey
Details
p.1 #3D500 w 3rd Party Glass - Battery Drain
IIRC you use OS/VR 24/7 ?? Turn off the camera when you're not shooting. Problem solved.
Jun 09, 2016 at 06:27 AM
backdoorhippie
Details
p.1 #4D500 w 3rd Party Glass - Battery Drain
Camera is in airplane mode with no WifI, no BT.
No, OS/VR is not 24/7, it turns on and off with depression and release of the shutter button with the time until "parked" determined by firmware. I tend to only have it on with longer lenses, and I've had those lenses attached to many other bodies for many years with the camera on and no battery drain. Sure turning the camera off prevents drain, but it does not solve a problem that obviously exists. It's like saying, "Every time you drive over 25mph your car starts shaking? Well don't drive over 25mph."
I would add that I've let the 70-200mm f4 live on the D500 for days at a time without the TC, with both the camera and VR both "ON", and experienced no unexpected battery drain.
I've learned to expect lower battery life than on my D750 and D800 - I get that. What I'm seeing (or am reasonably certain I'm seeing) is that the camera does not go "quiet" when not in use when some 3rd party equipment is used. What I'm trying to assess is if it's a systemic thing across all D500's or something peculiar to mine.
Jun 09, 2016 at 06:35 AM
trenchmonkey
Details
p.1 #5D500 w 3rd Party Glass - Battery Drain
Well known OS eats batteries. You've previously complained about
the 150-600 Sport and using OS all the time. Trying to help here,
but I'm now convinced you have an evil D500. Send it in, seriously.
Jun 09, 2016 at 06:50 AM
backdoorhippie
Details
p.1 #6D500 w 3rd Party Glass - Battery Drain
You misread my other posts.
1. Yes, the D500 goes thru batteries faster, and the old ones in particular, but this is regardless of lens and OS use.
2. The Sigma 150-600mm Sport caused an issue with the image review screen not turning off. OS was blamed for similar, but not identical issues elsewhere, and while trying to get to the bottom of that issue (while working with Sigma) I asked how others had various OS settings on the lens to determine if changing mine might "fix" my problem, which could lead Sigma to possibly pinpoint why I was getting it. Then yesterday I was able to, for the first time, replicate the issue with the 70-200mm f4 + Kenko 2XTC combo while using VR, leading me to believe that whatever may be triggering this has to do with OS/VR and 3rd party products.
3. Last night, unlike other nights where the D500 has sat attached to the 150-600mm Sport with both camera and OS turned on, the battery in the camera - which had been charged to 100% earlier in the day - drained completely with the 70-200mm + Kenko TC attached.
I get that OS eats batteries, but in all cases I can hear the OS disengage. I understand that doesn't mean it's "off", but based on what I experienced with the 150-600mm it was at least "mostly off" since there was no significant drain while dormant. That wasn't the case last night. I've been trying to recreate the issue this morning but after 2 hours I've seen zero battery drain. The intermittent nature of the bug tells me that there must be some set of conditions that "sets" the camera to stay on, whether that means the displays and functions do not turn off or the OS stays engaged when it's not supposed to.
My problem is that this only happens with 3rd party lenses, which Nikon will see as my problem, not theirs. My only blessing may be that no one else has experienced this (something I'm trying to document) and they may then at least take a look at my camera.
I do appreciate the help. I'm not the type to ask for it until I've exhausted ideas on my end, something I continue to push further and further.
Jun 09, 2016 at 07:15 AM
backdoorhippie
Details
p.1 #7D500 w 3rd Party Glass - Battery Drain
And wouldn't you know it, as I'm typing this I turn around and notice that the menu display from the last time I checked my battery is still on after 10 minutes and has gone from 98% to 95% (which is expected). I'm creating a video to show the effect and will demonstrate that the OS has disengaged (though perhaps not "parked") with the intent of sending it to Nikon to prove my issue.
Jun 09, 2016 at 07:23 AM
Mark K
Details
p.1 #8D500 w 3rd Party Glass - Battery Drain
I have both the Kenko TC and Sigma 1401, as well as the 150-600S and how can I have never had this problem
Jun 09, 2016 at 08:16 AM
backdoorhippie
Details
p.1 #9D500 w 3rd Party Glass - Battery Drain
And that's the $64,000 question. Or perhaps it's how is it that I'm the only one.
The intermittent nature of it points to the possibility of a strange combination of trigger factors, from the use of OS to mode (I'm always in manual and Ch when it happens) to 3rd party attachments. It may be something in my setup, it may be something in my camera.
Jun 09, 2016 at 08:28 AM
snapsy
Details
p.1 #10D500 w 3rd Party Glass - Battery Drain
Certain Sigma lenses prevent Nikon cameras from triggering their normal metering timeout (default 6 seconds), causing the camera to stay awake for a minute or more of being idle between shots. The same thing occurs on the D7100/D7200.
Jun 09, 2016 at 08:37 AM
CanadaMark
Details
p.1 #11D500 w 3rd Party Glass - Battery Drain
What is your custom setting C2 set to?
Jun 09, 2016 at 08:57 AM
backdoorhippie
Details
p.1 #12D500 w 3rd Party Glass - Battery Drain
Yeah, this ain't that. This is a never, ever in your battery's lifetime will it time out. I'm not saying it's not related, in fact I suspect that it's probably a similar trigger as what is happening with the Sigma 17-50mm where it adds 1 minute except that it just keeps restarting that timer instead of adding to the total time.
C2 is set to AF = Accuracy and OS = Dynamic View. No custom setting for the focus limiter.
Jun 09, 2016 at 09:02 AM
backdoorhippie
Details
p.1 #13D500 w 3rd Party Glass - Battery Drain
Following up, my issues with things not powering down on my D500 finally hit a scenario yesterday where it occurred with no 3rd party optics involved when I had the image review fail to time out when I was using my 70-200mm f4 with no TC and no VR. I'll be contacting Nikon Customer Service today. For the record, here's what I've encountered thus far:
With the Sigma 150-600 Sport:
1. Image review will stay on after chimping and never time out. The meter stays on as well.
2. Menus will not time out after viewing or changing a setting.
With the Kenko 2x TC on a Nikon 70-200mm f4:
3. No rear screen activity but battery drained overnight, so I would assume the meter (at least) stayed active all night.
With the Nikon 70-200mm f4:
For anyone interested I'll keep you posted on what I hear from Nikon.
Jun 14, 2016 at 05:33 AM
FM ForumsNikon ForumJoin Upload & Sell
