Archive 2016 · Ten-Frame Mosaic of Central Orion Region
StarNut
p.1 #1 · Ten-Frame Mosaic of Central Orion Region
Hi,
Sometimes I get sucked into doing really crazy things. This started out, in late 2012, as a picture of something that looked interesting, the reflection nebula NGC1990. But when I processed my data, I realized that my field contained two of the three stars comprising Orion’s belt. So I had to get all three stars, which would include the Horsehead Nebula and the Flame Nebula. Well, then the Orion Nebula is right next door, I thought, so why not?
Over three years later, I learned “Why not?” It took me through most of winter 2012-2013 and winter 2013-2014 to gather the data, with generous framing of the two principal parts of the planned-image. Then it took me another year to learn Pixinsight well enough to re-commence processing images. Then it took me until November 2015 to gather the energy to tackle processing a nine-image mosaic. Then I found out there was a gap in my data, so I had to take one more frame, which I finally finished taking last week. PITA does not begin to describe it!
Anyway, I am pleased with the outcome, which I guess is a good thing!
IMO it looks better in the larger sizes (this image is 15% of full size, lateral measure), so you might want to click through to the higher-resolution versions eventually, if you have a good monitor. You can find a variety of higher-resolution versions here:
http://www.de-regt.com/Astronomy/Orion.htm
Central Orion Region: This is a decent-sized chunk of the Orion Molecular Cloud Complex, a large star-forming region in the constellation Orion. There's a lot going on here! (It looks better in the larger versions, because the tiny stars aren't so scrunched up and fuzzy-looking.)
The three very bright, blue stars in a column toward the left side of the field are the three stars that make up Orion's belt. Yes, the Horsehead Nebula (Barnard 33), a dark nebula, seen in silhouette against the bright emission nebula IC434 behind it, is right next to Alnitak. The Flame Nebula (NGC2024), an emission nebula of ionized hydrogen, energized by a bright new star obscured from us behind the dust of the nebula, is even closer to Alnitak than the Horsehead Nebula. The bright blue star above Alnitak is Alnilam, the middle star of Orion's belt; Mintaka, the third star in Orion's belt, is above Mintaka (close to the top of the image). The large, bright double-ball well to the right of the Horsehead Nebula is the Orion Nebula (M42). We see the Orion Nebula in our night sky as Orion's sword--it is that bright. The Orion Nebula is one of the brightest nebulae seen from Earth, and is the closest region of massive star formation to Earth. The M42 nebula is estimated to be 24 light years across. It has a mass of about 2000 times the mass of the Sun.
The blue clouds are "reflection nebulae," reflecting the light from bright, blue stars in their midst. There are a lot of reflection nebulae in this field (but not to be confused with the bright, blue stars in the field).
There are even some background galaxies showing through.
This area is about 1,500 light years from us; for scale, the horse's head is about five light years "tall." The wispy shape of the ionized gases will change over time (thousands of years), as the stellar winds "blow" the nebulae.
The processing of almost all celestial objects requires "stretching" the histogram, to make all interesting things in the field visible (compared to the brightness of the brighter stars in a field, the dimmer objects would be invisible if the dimmer objects didn't have their brightness intensified relative to the brighter objects). So, for instance, in this field, the Horsehead Nebula is a very dim object, difficult to see (visually) even with a moderately large (say, 10 inch/254mm) telescope without dark skies and a good filter, while the Orion Nebula is easily visible with the naked eye. In this image, so that all are visible, they appear to have similar brightnesses, but they do not (without this sort of process, it would be impossible to show even the Orion Nebula as I have, since the brighter parts saturate the sensor in a very short time, while it takes very long exposures to get the dim, wispy stuff).
It contains approximately 150 hours of light-frame data.
Telescope: Takahashi FSQ106
Camera: Santa Barbara Instruments Group STL11000M
Mount: Software Bisque Paramount ME German Equatorial Mount.
Copyright 2012-2016 Mark de Regt
http://www.de-regt.com/Astronomy/Orion.15.jpg
Edited on Jan 26, 2016 at 12:51 PM · View previous versions
Jan 20, 2016 at 12:14 PM
Brad Williams
p.1 #2 · Ten-Frame Mosaic of Central Orion Region
Wow, quite the image! Never really know what I am looking at here other than "Outer Space", but they are always very intriguing. I can pick out Orion's belt in this one since you mentioned it was in there. Awesome Work!
Jan 20, 2016 at 02:08 PM
kwilliam8
p.1 #3 · Ten-Frame Mosaic of Central Orion Region
Amazing image! Sent you a pm.
Keith W.
Jan 20, 2016 at 02:13 PM
Milan Hutera
p.1 #4 · Ten-Frame Mosaic of Central Orion Region
Beautiful photo, and you got the Horsehead nebula as well! Although it always looked to me like some sort of golem than a horse.
Jan 20, 2016 at 02:18 PM
Chaz
p.1 #5 · Ten-Frame Mosaic of Central Orion Region
I never tire of looking at stunning images like this, knowing the time-consuming effort and painstaking attention that went into their creation. And the Horsehead is superb!
Kudos!! Hear! Hear! Bravo! (CLAP!) (CLAP!) (CLAP!)
I appreciate the artistry and dedication necessary - in 1996 I froze my behind while making long-exposure astro-photos with my Nikon F through an 8" Meade Schmidt-Cassegrain. Had to hand guide while using an illuminated reticle!
Jan 20, 2016 at 02:30 PM
tmiller9
p.1 #6 · Ten-Frame Mosaic of Central Orion Region
Amazing. Simply, amazing.
Jan 20, 2016 at 02:42 PM
JimFox
p.1 #7 · Ten-Frame Mosaic of Central Orion Region
This is just crazy good. I can not imagine spending that amount of time and energy to do this, but I am glad you did! Wonderful work, and it's great when one session/shot can lead to other ideas for more.
Jim
Jan 20, 2016 at 03:44 PM
dbehrens
p.1 #8 · Ten-Frame Mosaic of Central Orion Region
I never tire of these! Dave
Jan 20, 2016 at 04:01 PM
JSecord
p.1 #9 · Ten-Frame Mosaic of Central Orion Region
amazing! I do a lot of landscape astrophotography, but would love to try some more deep sky stuff like this
Jan 20, 2016 at 04:34 PM
Gary Clennan
p.1 #10 · Ten-Frame Mosaic of Central Orion Region
So amazing. Thanks for taking the time to post and share the details....
Jan 20, 2016 at 05:26 PM
StarNut
p.1 #11 · Ten-Frame Mosaic of Central Orion Region
Thanks so much; I'm very glad people enjoy these images I post from time to time.
Mark
Jan 20, 2016 at 07:51 PM
tfoltz
p.1 #12 · Ten-Frame Mosaic of Central Orion Region
I applause your patience and skill, this is awesome.
-Tim
Jan 20, 2016 at 09:17 PM
m_deboer
p.1 #13 · Ten-Frame Mosaic of Central Orion Region
Blown away, thank you for sharing!
Matt
Jan 20, 2016 at 10:19 PM
danws6
p.1 #14 · Ten-Frame Mosaic of Central Orion Region
Incredible.
Jan 21, 2016 at 01:16 AM
Highfive
p.1 #15 · Ten-Frame Mosaic of Central Orion Region
Crazy good. May i say, out of this world good
Jan 21, 2016 at 03:35 AM
jforkner
p.1 #16 · Ten-Frame Mosaic of Central Orion Region
Beautiful image.
I took a look at the larger versions and would agree they’re more impressive, especially the full-res version. But I was curious about a statement you made beneath the image on the linked page…”Data acquired remotely from Fair Dinkum Skies, near Moorook, South Australia…” Does this mean you used a remote observatory to gather the data, then processed it yourself? I’ve always been curious about the use of remote facilities for data gathering for astro work.
Jack
Jan 21, 2016 at 08:50 AM
StarNut
p.1 #17 · Ten-Frame Mosaic of Central Orion Region
Thanks again!
Jack
Yeah, my equipment is housed at a facility in the South Australia desert, east and north of Adelaide. I own the scope, mount, camera, etc., while the host owns and operates the observatory, provides security and trouble-shooting. There is software which allows me to tell my server down there what I want it to do that night; I upload the plan, and the system (if all goes well) takes the images and shuts down when it's done. Then I download the images to my home, and process it when I get a chance.
Mark
Jan 21, 2016 at 01:41 PM
ajkessler
p.1 #18 · Ten-Frame Mosaic of Central Orion Region
Gorgeous
Jan 21, 2016 at 02:54 PM
subgenius
p.1 #19 · Ten-Frame Mosaic of Central Orion Region
Very nice, especially of the Horsehead Nebulae. This is about as good as it gets!
Jan 21, 2016 at 08:06 PM
ArturS
p.1 #20 · Ten-Frame Mosaic of Central Orion Region
Unbelievable. The full resolution is just jaw dropping.
Jan 21, 2016 at 09:06 PM
