fredmiranda.com Login
This topic is in the 2015 archive. You can read it and like its posts here. It is read only.
Archive 2015How Much Damage?
EB-1
p.1 #1How Much Damage?
So far my 5DsR has fallen onto the pavement from about 4 feet, then rolled down a hillside, hit a rock and bounced up and off it. There are several noticeable dents on the prism and the top dial is looking the worse for wear, but the body still works fine. How much additional impact can it handle?
Nov 17, 2015 at 08:37 PM
Details
p.1 #2How Much Damage?
Hang in there. I figure you'll be able to tell us the answer in a few weeks or so.
Maybe we should start a pool.
Nov 17, 2015 at 08:40 PM
johnvanr
Details
p.1 #3How Much Damage?
Adding reminder not to buy gear from you...
Nov 17, 2015 at 09:02 PM
PetKal
Details
p.1 #4How Much Damage?
Have no fear,
EB never sells any of his gear.
Edited on Nov 17, 2015 at 09:08 PM · View previous versions
EB-1
Details
p.1 #5How Much Damage?
The odd part is that this is the first physical damage encountered in over a decade. I think the last one was a 1.4x TC in 2003.
snapsy
Details
p.1 #6How Much Damage?
I project it can handle 3 more hills
Nov 17, 2015 at 09:12 PM
johnvanr
Details
p.1 #7How Much Damage?
EB-1 wrote:
johnvanr wroteAdding reminder not to buy gear from you...
In that case, I hope to match your track record. I just had my 1.4x roll out of my car onto the road. I should be good for another ten years...
Nov 17, 2015 at 09:35 PM
arbitrage
Details
p.1 #8How Much Damage?
My 5D3 dropped from about 3ft onto hardwood....stopped working for a few hours....then started working again and has been working fine for a year now....so who knows....my 100-400II wasn't so lucky after two drops onto pavement and Canon figured it out so I'm paying for the repair
Nov 17, 2015 at 09:39 PM
gdanmitchell
Details
p.1 #9How Much Damage?
Not sure, but do let us know how it turns out when you finish this experiment.
Nov 17, 2015 at 10:05 PM
Guest
Guest
Details
p.1 #10How Much Damage?
Ouch... Last time I did something to my gear was when my 24-85 fell from about 1 meter height and onto wooden parquet. The filter was trashed and a small scratch Mark appeared on the rear element, but the lens was (seemingly) fine. I gave it to a friend later tho.
Nov 18, 2015 at 03:00 AM
codyconway
Details
p.1 #11How Much Damage?
my 1D III took a drop like that, and the AF screen no longer lined up, camera worked flawlessly aside from this, but had a crack in the upper prism housing. Sent it to Canon with my CPS discount, and it still ended up costing around 780 to repair the prism and upper housing. But, it came back looking like new. I'd suspect the only issue you might have is slight AF alignments from the prism potentially being damaged / shifted.
Nov 18, 2015 at 05:12 AM
John_T
Details
p.1 #12How Much Damage?
Ah, just run an AFMA (Auto Fumble Mutation Adjustment) and it'll be fine.
Nov 18, 2015 at 05:50 AM
danski0224
Details
p.1 #13How Much Damage?
This is like one of those written math problems with all kinds of extra fluff to throw you off.
The key part of this problem is at the end: "How much additional impact can it handle?"
The answer is simple:
One less impact from the point at which it stops working.
Unfortunately, a second camera may be required to reap the benefits of this research.
Nov 18, 2015 at 06:02 AM
schlotz
Details
p.1 #14How Much Damage?
Nov 18, 2015 at 08:29 AM
hotdog12
Details
p.1 #15How Much Damage?
Relax. Does the camera work properly? Anything rattle when you shake it? I would do the "newspaper on the wall" test to verify a lens element has not been knocked out of alignment, then forget about it.
I've bounced more than my fair share of cameras off sidewalks and they usually escape anything other than cosmetic damage.
Nov 18, 2015 at 08:41 AM
3iron
Details
p.1 #16How Much Damage?
Sounds to me like you can dribble and shoot hoops with that thing.
Nov 18, 2015 at 09:59 AM
gschlact
Details
p.1 #17How Much Damage?
Test whether it still floats. ;-)
Nov 18, 2015 at 11:57 PM
kodakeos
Details
p.1 #18How Much Damage?
looks like you took a 2d4 impact damage with additional 1d8 rolling damage.
your titanium housing gives you +3 against impacts and +5 against rolling.
I would say your camera has about 2 HP left at the moment.
Better get a cleric to cast an healing spell.
Nov 19, 2015 at 09:09 AM
danski0224
Details
p.1 #19How Much Damage?
Sounds like a great time to call in a body double for that test.
Maybe something with fewer megapixels will be lighter.
Nov 19, 2015 at 12:23 PM
danski0224
Details
p.1 #20How Much Damage?
I see bigger problems because the housing is magnesium. Probably off by a couple of points for sure.
Nov 19, 2015 at 12:30 PM
