This topic is in the 2015 archive. You can read it and like its posts here. It is read only.
Archive 2015Interesting Reference Data on Dynamic Range - 5dsr
Scott Stoness
p.1 #1Interesting Reference Data on Dynamic Range - 5dsr
http://www.photonstophotos.net/Charts/PDR.htm#Sony%20ILCE-7R,Sony%20ILCE-7RII,Sony%20ILCE-7S
I saw this on the sony forum. But it is broad enough for all forums. I am reposting the link for discussion here.
The test redefines dynamic range to useable dynamic range rather than 1:1 and concludes the a7rii sony sensor is still superior in dynamic range to the 5dsr. A7r is closer above iso 400.
I like the fact that the test does not use the unusable 1:1 range of dxomark.
Based on these measures
it looks like the dynamic range advantage of canon over iso 800 has gone away and the a7rii has 1/2 stop advantage over 5dsr.
it also looks like a7rii is better at > iso 800 than the a7r. And I have always wondered whether the comparison is linear and reflected in a more reasonable test than dxomark.
Some interesting questions that arise to me:
1) My view is that the a7rii (best Iso landscape camera in low ISO) is still too low and needs HDR. The redefining of dynamic range to 20% snr is a better test and supports that conclusion. Eg if you need lots of dynamic range - use HDR or blending. Of course if something is moving you cannot do this, so more dynamic range is good barring all other factors but the a7rii dynamic range is still not enough for me.
2) The a7r has an apparent boosting at some ISO's. It appears that sony is doing some processing of the results to achieve their dynamic range gains above base ISO. This may be why they don't provide raw raw's because they cook them first? The question I have is - you could do the same with the raws of canon for example to match the higher dynamic range.
3) The related question is does such processing decrease something other than dynamic range (usually there is some trade off) like color, iq, ....
Scott
p.s. the purpose of this post is not to re-re-re start the debate on which camera is better. There is more to a camera than dynamic range capability. Like the ability to us my ts17 that does not exist natively in sony or nikon. I just wanted to understand what sony is up to - to see if it can be achieved by canon in post processing.
Edited on Aug 14, 2015 at 01:32 PM · View previous versions
Aug 14, 2015 at 01:24 PM
mttran
Details
p.1 #2Interesting Reference Data on Dynamic Range - 5dsr
Just simply wait for sony BSI EXMOR RS version if you want more DR. Who cares what they are doing as long it fits our needs, right?
snapsy
Details
p.1 #3Interesting Reference Data on Dynamic Range - 5dsr
1. Agreed, all cameras benefit from bracketing. Bill's PDR threshold for the A7rII is not 20:1 - it's 2.47:1, which is very close to DxO's 1:1. The 20:1 SNR threshold for PDR is before normalizing for pixel count (see this post for details).
2. The "boosting" of the A7rII's DR is not raw cooking but instead an analog gain optimization, the same type of optimization seen on most cameras including all Canon DSLRs. The only difference is Sony implements a two-phase optimization that better balances low ISO DR with high ISO DR. Do a web search for "Aptina DR-Pix" for details on a sample implementation.
3. No
Aug 14, 2015 at 01:33 PM
Scott Stoness
Details
p.1 #4Interesting Reference Data on Dynamic Range - 5dsr
But my question is whether it could be done in post processing, to achieve the same results as the sony in canon (e.g.. boosting dynamic range at higher iso's. And whether it trades something else off.
So I care. I am committed to the canon system with 10's of thousands of dollars of lens.
Aug 14, 2015 at 01:35 PM
Scott Stoness
Details
p.1 #5Interesting Reference Data on Dynamic Range - 5dsr
...Show more →
Thanks snapsy - I shall read and see if I can follow.
Aug 14, 2015 at 01:36 PM
RobDickinson
Details
p.1 #6Interesting Reference Data on Dynamic Range - 5dsr
Sony are not above cooking raws sadly. Have done in the past Will do in the future.
The a7s has noise reduction applied to higher ISO raws making comparison hard.
Aug 14, 2015 at 02:17 PM
gdanmitchell
Details
p.1 #7Interesting Reference Data on Dynamic Range - 5dsr
I've stipulated all along that the Sony sensors seem to have somewhat more dynamic range than Canon sensors. I've also said much that same thing that you say here — no current sensor has enough dynamic range to handle all possible wide dynamic range scenes, so the greater DR capability produces an incremental improvement that means the area where one might have to use a blending or HDR technique moves a bit but the need for these things won't be eliminated. (For those who think it is, check back with us when Canons continuing improvement in DR reaches Sony's current level and let us know that DR is no longer an issue... ;-)
[quote)2) The a7r has an apparent boosting at some ISO's. It appears that sony is doing some processing of the results to achieve their dynamic range gains above base ISO. This may be why they don't provide raw raw's because they cook them first? The question I have is - you could do the same with the raws of canon for example to match the higher dynamic range.
Several things struck me along these lines as I looked at the chart's curve representing dynamic range of a variety of cameras. (I plugged in quite a few — Sony Ar7 and Ar7II, Canon 5DsR and 1Dx (and others), all of the Fujifilm X-trans cameras, Nikon D810, both Phase One Backs, Pentax 645z, and probably others.)
Many cameras' curves have "waves" in them — that might have a period of approximately one "whole" ISO value. (E.g. - 100, 200, 400, 800, etc.) The 5DsR does not do this. Its response curve is very smooth. I'm not sure that this is especially significant, though I wonder what it means. (It does eliminate the sense that some have that certain 1/3-stop ISOs will be less noisy.)
The A7rII curve is very unusual. There is a significant measured "bump" in the dynamic range right at ISO 100 —a much larger jump away from average values right at that point. Off-hand, I can't come up with an explanation —though the answers to your third question will be interesting in this regard. It does allow Sony to claim a more significant DR difference at ISO 100. Then, as is always the case, the DR curve drops as ISO rises. However, unlike the 5DsR, there are anomalies in the curve at two points. Part way along on the increasing ISO scale, there is a singular bump in DR. Then about the same distance further along the curve there is a second similar bump. This also leads to your third question.
I think it would be interesting for someone to compare images at that very high DR ISO 100 point with images at something like ISO 200 or ISO 400 where that spike isn't happening. I also think it will be interesting for someone to compare images on either side of the other two anomalies that I mentioned above.
Of course, the bottom line is that when it comes to image quality the Sony sensor seems to do an overall very fine job. (Things are not perfect in Sony Land, as the 12-bit image issue reminds us.
Regarding the "debate" about which camera is better — both are very good cameras that will appeal to somewhat different users. Both have significant pluses and both have some minuses.
BTW: I updated an article at my website that includes a couple of examples of very underexposed 5DsR images from which deep shadow details have been recovered. If you are interested... http://www.gdanmitchell.com/2015/07/19/the-canon-5ds-r-dynamic-range-examples
Nearly black deep shadow section of a 100% crop....
http://i2.wp.com/www.gdanmitchell.com/wp-content/uploads/2015/07/CropPreEdit.jpg
... becomes...
http://i2.wp.com/www.gdanmitchell.com/wp-content/uploads/2015/07/cropPostEditNRSharp.jpg
details in the article
Aug 14, 2015 at 03:04 PM
snapsy
Details
p.1 #8Interesting Reference Data on Dynamic Range - 5dsr
Sony's raw-based High ISO NR doesn't start until 102,400 on the A7s and 32,000 on the A7rII, which is beyond the point of usability for many situations. So for High ISO I would only compare from around 25,600 and below.
Aug 14, 2015 at 03:45 PM
RobDickinson
Details
p.1 #9Interesting Reference Data on Dynamic Range - 5dsr
Untrue. I have seen NR on sony a7s raws at 6400. Its obvious if you look at them.
Aug 14, 2015 at 04:46 PM
snapsy
Details
p.1 #10Interesting Reference Data on Dynamic Range - 5dsr
RobDickinson wrote:
RobDickinson wroteSony are not above cooking raws sadly. Have done in the past Will do in the future.
snapsy wroteSony's raw-based High ISO NR doesn't start until 102,400 on the A7s and 32,000 on the A7rII, which is beyond the point of usability for many situations. So for High ISO I would only compare from around 25,600 and below.
Any NR that's obvious to the naked eye would be very obvious on a noise FFT or frequency plot, whereas the inverse is not always true. This means the analytical methods will detect NR at levels not noticeable to us. And no analytical evaluation of present Sony sensors shows evidence of NR at ISOs below the ones I've indicated, at least for the normal 14-bit single-shot mode.
Aug 14, 2015 at 05:00 PM
RobDickinson
Details
p.1 #11Interesting Reference Data on Dynamic Range - 5dsr
these are astro long exposures which I assume the a7s knocks back to 12bit ( the sonys dont even do 14bit do they??)
Its there. I really dont care if you believe me.
Aug 14, 2015 at 05:17 PM
gdanmitchell
Details
p.1 #12Interesting Reference Data on Dynamic Range - 5dsr
By the way, the notion that testing files "without any NR applied" will produce more accurate comparisons sort of falls apart with at least one test case has applied NR in-camera. In that case, a "no additional NR" test has other cameras competing with one arm tied behind their backs, so to speak.
My idea of a more useful real world test is to take the raw files and process them (for NR, sharpening, etc) in whatever ideal way you would if you were using the cameras, and then compare those results. That, after all, is how you would actually use the cameras, no matter which one your chose.
(My adjusted crop above — the much lighter one — was treated this way. I do show the version without NR or sharpening at the link, but I think the one shown here is the more useful one to consider.)
I saw some very high ISO examples from the A7rII posted in the Sony forum, and they did look quite good. As we would expect, there is noise and the DR is compressed — but considering the ISO setting the test images looked quite good and were certainly usable.
Edited on Aug 14, 2015 at 10:29 PM · View previous versions
Aug 14, 2015 at 07:00 PM
snapsy
Details
p.1 #13Interesting Reference Data on Dynamic Range - 5dsr
Yes, 12-bit long-exposures do apply noise reduction, which is independent of High ISOs.
Aug 14, 2015 at 07:03 PM
RustyBug
Details
p.1 #14Interesting Reference Data on Dynamic Range - 5dsr
...Show more →
Ditto ... well stated.
Aug 15, 2015 at 07:07 AM
RustyBug
Details
p.1 #15Interesting Reference Data on Dynamic Range - 5dsr
Link
Aug 15, 2015 at 07:09 AM
chez
Details
p.1 #16Interesting Reference Data on Dynamic Range - 5dsr
...Show more →
Yes, the final image is what counts...who cares what the images look like straight from the cameras. That test of the new Sony at high ISO was really quite amazing. The noise was very even without any kind of banding and with careful noise reduction applied, those ultra high ISO images would be very usable. This is one area the A7R lacked which seems to have been greatly improved on in the A7R2.
Aug 15, 2015 at 07:29 AM
OntheRez
Details
p.1 #17Interesting Reference Data on Dynamic Range - 5dsr
RustyBug wrote:
gdanmitchell wroteBTW: I updated an article at my website that includes a couple of examples of very underexposed 5DsR images from which deep shadow details have been recovered. If you are interested... http://www.gdanmitchell.com/2015/07/19/the-canon-5ds-r-dynamic-range-examples
Link
+1 Waiting with bated breath for a link fix
Robert
Aug 15, 2015 at 08:23 AM
OntheRez
Details
p.1 #18Interesting Reference Data on Dynamic Range - 5dsr
Ok, I'm well out of my level out of expertise here especially since optics was never in my university curriculum (got too fascinated with statistical analysis). So would someone (maybe in small words ) help me out here?
What I think I know is as follows:
(1) No camera (or for that matter any visual sensing device) can come anywhere near to the human eyes' ability to see both dark and light simultaneously - ignoring of course the extremes of "dark as a coal mine at midnight" and staring at the noonday sun.
(2) Variations in sensor technology do exist, and I'd guess the magnitude of variations from say an iPhone to the Hubble approach infinite.
(3) It is a standard canard that the Canon (pick a current model to beat on) is not as good as camera X. (Was the Nikon D800 for awhile, now seems to be the Sony 7rxxx.) This is a constant refrain around here. I can't really comment on the validity of this line of thought.
(4) Sony's sensors seem to be superior(?) at least to some folks and by some tests, but there's a strong suspicion that they're also throwing in some sort of "secret sauce" that produces a not "true" raw. This might not be a bad thing, and I wouldn't be surprised if all makers don't do something in their A/D transformations.
(5) Finally, it does seem clear that Canon doesn't do as well in resolving detail in the shadow at low ISO. I know Fred demonstrated this more than a year ago with a D800. Doubt that has changed much.
So to me, the question is: what is the bottom line? I nearly always shoot at least a 3 AEB with any scene that has extremes of light to dark. Judicious merging (I use Photomatix) produces richer photos without the garish overdone images that can be produced with HDR. Of course multiple exposures of moving objects is worth snot. Those of us who shoot movement in various shades of dark are forced to wider apertures, as slow a shutter as necessary to stop action, and higher ISO.
So here's the $64,000 question: does this make a difference in how the human eye perceives the photo particularly printed at a reasonable size? I know you can pixel peep to 200x and up, but come on, that really doesn't have much to do with what the photo looks like to other humans.
How serious/significant is this reported superiority of the Sony 7rxxx? Inquiring minds (well at least mine) want to know
Robert
Aug 15, 2015 at 09:02 AM
gdanmitchell
Details
p.1 #19Interesting Reference Data on Dynamic Range - 5dsr
Link
Sorry. I'm battling a little server issue* and the site was temporarily offline. I have fixed it and the link seems to work now — let me know if you still have problems accessing it.
Thanks,
* For the past month the site has locked up early on Saturday mornings! Time to dig into some server logs, reinstall some plugins, and more. Oh, fun! Not. ;-)
Aug 15, 2015 at 09:28 AM
ggreene
Details
p.1 #20Interesting Reference Data on Dynamic Range - 5dsr
From all the samples I have seen from the D810, 5Ds/R, and A7rII, I don't think anyone could reliably pick out what camera did them in a blind test. They are simply all very fine camera's with outstanding IQ.
Aug 15, 2015 at 09:32 AM
