fredmiranda.com Login
This topic is in the 2015 archive. You can read it and like its posts here. It is read only.
Archive 20155DSR has more DR than 5DIII
SoftImage
p.1 #15DSR has more DR than 5DIII
Bill Claff has just completed his measurement of 5DSR DR. You can compare it with other cameras.
http://home.comcast.net/~NikonD70/Charts/PDR.htm
Jul 07, 2015 at 12:58 AM
kevindar
Details
p.1 #25DSR has more DR than 5DIII
good to see. it seems like it may be just quarter stop better than the last Canon DR champion, 6d, and only 1/3-1/2 stop worse than the 360 dollar Nikon d5200 at base iso, and of course easily beating it at higher ISO.
DR is certainly not by any means the end all be all of photography, not even landscape photography. However, significantly advancing it, has been a riddle that has puzzled canon now for 5 years.
Yet small victories, we take.
Jul 07, 2015 at 01:17 AM
KiboOst
Details
p.1 #35DSR has more DR than 5DIII
It also seems that intermediate iso are now usable ? This would show a real difference in design, be it hardware or software.
Jul 07, 2015 at 01:59 AM
Peter Figen
Details
p.1 #45DSR has more DR than 5DIII
It certainly doesn't look the same as the 7DII, which is what the Canon reps were saying a couple of months ago.
Jul 07, 2015 at 02:06 AM
Jeff Fenske
Details
p.1 #55DSR has more DR than 5DIII
Yeah, the 5D2, 5D3 and the 7D2 have the same *roller coaster ups and downs*, but this curve is more linear, more like the 1DX, which also has more than one processor, if I'm remembering correctly? Could that make a difference?
Very encouraging at base ISO! Looks almost a *full stop better* than the 5D3, but still almost two stops less than the Nikon D810 (DR champion). And then the D810 and 5DsR meet at ISO 400, after which the 5DsR stays slightly better.
Canon Asia said the 5DsR has advanced technology in the sensor. Could significantly better DR than the 7D2 (which has the same size pixels but dual pixel AF) be an indication of that?
Jul 07, 2015 at 04:45 AM
snapsy
Details
p.1 #65DSR has more DR than 5DIII
Same pixel-level DR but more pixels means higher DR for equal-sized prints (downsampled). See this post:
https://www.fredmiranda.com/forum/topic/1346836/2#12853611
Jul 07, 2015 at 05:22 AM
snapsy
Details
p.1 #75DSR has more DR than 5DIII
Looks like they're using a two-stage amplifier on the 5DS, same as on some of the 1D bodies.
Jul 07, 2015 at 05:24 AM
Cliff L.
Details
p.1 #85DSR has more DR than 5DIII
In some real-world applications, I've found the 5D SR to have more dynamic range than the D810, but the extra latitude available is in the highlights, not in the shadows like the Nikony sensors.
This is a single exposure, and no ND grad filters were used:
Jul 07, 2015 at 06:50 AM
retrofocus
Details
p.1 #95DSR has more DR than 5DIII
Below ISO 800, the 5DsR is quite a bit lower (up to 2 stops or units on the y-axis) in DR compared to Sony A7R. Impressive graph when plotted.
Jul 07, 2015 at 07:50 AM
big country
Details
p.1 #105DSR has more DR than 5DIII
i do not have the R, but i have been shooting the 5DS at weddings, engagements and some birds w/ the 5DS. honestly, if it were 6-8 fps, and had a bigger buffer, and could go a little higher on the native ISO this would be pretty close to my ultimate camera.
Jul 07, 2015 at 08:26 AM
Jeffrey
Details
p.1 #115DSR has more DR than 5DIII
Good to hear, but I've been OK with the DR on most recent Canon cameras. I'm not one of the current crop of screaming DR junkies.
Jul 07, 2015 at 09:52 AM
Ziffl3
Details
p.1 #125DSR has more DR than 5DIII
I would resemble this remark..... 6-8fps ... I am okay with 5fps, but 6-8 would be cool.
The buffer ... there is a place that could use a bump. This would be my 1 gripe.
Native ISO .... I am okay with the 6400.
The other spot is battery life. Need the grip for weddings... but this could be me.
I am not in the mood to carry additional batteries when shooting all day.
I need to get into the last wedding I shot to understand the colors.
-Mark
Jul 07, 2015 at 11:00 AM
dmcphoto
Details
p.1 #135DSR has more DR than 5DIII
Ziffl3 wrote:
big country wrotei do not have the R, but i have been shooting the 5DS at weddings, engagements and some birds w/ the 5DS. honestly, if it were 6-8 fps, and had a bigger buffer, and could go a little higher on the native ISO this would be pretty close to my ultimate camera.
-Mark
I have the 5DSR and I'm finding the battery life to be surprisingly short. I am not sure how it compares to the 5D3 as my other cameras are 1DX and 1DS3, but some anecdotal playing around with the camera does suggest that battery life could be a problem. Both cameras (5DS and 5DSR) should be identical in this regard.
Jul 07, 2015 at 11:30 AM
Monito
Details
p.1 #145DSR has more DR than 5DIII
Yes, very good to see. Kudos to the OP for posting. I was waiting for this information.
I used to shoot the 5D2 at 160, 320, 640 and 1250 to take advantage of the peaks.
But now on the 5DS, I will just dial in whatever the heck ISO suits for shutter and aperture combination. And generally go back to 100, 200, 400, 800 for default settings, 'cause round numbers are nice.
Jul 07, 2015 at 12:27 PM
curious80
Details
p.1 #155DSR has more DR than 5DIII
There is no such thing as highlight latitude vs shadow latitude as far as the actual raw sensor data is concerned. The sensor DR is sensor DR, whether it gets assigned to shadows or highlights is just a matter of camera metering and jpeg tone curve.
Jul 07, 2015 at 12:52 PM
Jeff Fenske
Details
p.1 #165DSR has more DR than 5DIII
-Mark
They're saying it takes extra power because of the additional processor. But there are some advantages of using the same battery as in the 5D2 and 5D3, I would guess, unless batteries have improved enough since then so they could make one just as small and lightweight, while being more powerful.
Aftermarket batteries are relatively inexpensive too, which the reviews are mostly positive about.
Also
Jul 07, 2015 at 12:59 PM
Ziffl3
Details
p.1 #175DSR has more DR than 5DIII
-Mark
the first wedding I used a 5DS... gripped the 5DS and had 40-50% left. maybe about 1000-1300 images.
The 5DmkIII - no grip ... 400-500 maybe 600. images and still 60%+ (older battery)
-Mark
Jul 07, 2015 at 01:09 PM
darbo
Details
p.1 #185DSR has more DR than 5DIII
This is a nice bit of news. I have always felt the 5D II/II fell just a touch short of the DR that I really want/need in my editing work. My a7R has great DR, which is wonderful, but how these cameras compare is of little interest to me. The only thing that truly counts is how much DR do I really want and need. The 5DS / R appears to have hit that crucial mark.
Looks like I may be doing less bracketing when using my 5DS (scheduled to arrive today).
Jul 07, 2015 at 01:13 PM
ggreene
Details
p.1 #195DSR has more DR than 5DIII
Kind of a shame they didn't/couldn't offer higher FPS on the crop modes. That would have broadened its appeal.
Jul 07, 2015 at 01:20 PM
Cliff L.
Details
p.1 #205DSR has more DR than 5DIII
curious80 wrote:
molson wroteIn some real-world applications, I've found the 5D SR to have more dynamic range than the D810, but the extra latitude available is in the highlights, not in the shadows like the Nikony sensors.
That's a semantic (some might say pedantic) argument, but in practical terms, I could never recover that sort of detail from the highlights of my Nikon or Sony cameras - I had to expose carefully so as not to blow out the highlights, and hope I could pull up the shadows enough to make the rest of the scene visible.
With the 5D SR, I can expose for the midtones/shadows without worrying about noise or banding, and all the detail is still recoverable in the highlights. Since the lowest EVs have the fewest bits of color data, the Canon approach should (and apparently does) produce better results, because it lets you expose really far to the right (RFTTRâ„¢) where most of your bit data is located.
Jul 07, 2015 at 02:26 PM
