fredmiranda.com Login
This topic is in the 2015 archive. You can read it and like its posts here. It is read only.
Archive 2015100-400II for Astrophotography
jforkner
p.1 #1100-400II for Astrophotography
I recently acquired the new 100-400 II lens for my Canon 6D DSLR, and wanted to see how it worked as an alternative to my motor-driven 600mm refractor telescope. So I bought a dovetail bar, mounted the lens to it, and slid it into the mount in place of the telescope—you can see a pic of the configuration below. I transferred my green laser pointer to help with aiming via a hot shoe adapter, and voila!
Last night I took the first photos using the setup and captured the Orion Nebula, Horsehead Nebula, and Pleiades Cluster. I took a series of shots that need to be stacked & processed; and as you might expect, the images are somewhat wide-field. While waiting to stack the series, I processed a couple of single-frames in PS CS6. I’m pleased with the quality of these, and am anxious to see if the stacked ones look any better. FWIW, the Orion/Horsehead image was taken at 400mm, ISO 1600, f/5.6 with a 120 sec. exposure; Pleiades was taken at 400mm, ISO 3200, f/5.6 with a 120 sec. exposure.
This isn’t an endorsement of the telephoto over the telescope, but it’s nice to have another tool in the arsenal. Curiously, the lens cost about twice what the telescope did.
Jack
http://jackforknerphotography.com/Temp/_1143024.jpg
http://jackforknerphotography.com/Temp/_MG_4006-II.jpg
http://jackforknerphotography.com/Temp/_MG_4020.jpg
Jan 15, 2015 at 01:43 PM
JoelWilcox
Details
p.1 #2100-400II for Astrophotography
Good lord. I've never tried astrophotography, but this sure is interesting -- and motivating. Thanks for posting.
Jan 15, 2015 at 02:15 PM
kabraxcis
Details
p.1 #3100-400II for Astrophotography
I wish I lived in a less light-polluted area.
Jan 15, 2015 at 02:21 PM
dgdg
Details
p.1 #4100-400II for Astrophotography
Very cool.
When the milky way core rises should be another fun opportunity.
The coma is well controlled, I only see a little on the big peripheral stars.
David
Jan 15, 2015 at 02:30 PM
matanuska
Details
p.1 #5100-400II for Astrophotography
Looks good! Though, not surprisingly for a photo lens I am seeing a bit of coma on the outer edges.
BTW, what is the clear aperture of this lens? I would think that this would be very comparable to my TV-76.
Jan 15, 2015 at 02:57 PM
Tom_W
Details
p.1 #6100-400II for Astrophotography
120 seconds - tracking mount, I presume?
I'm not much of an astrophotographer so I have to ask.
Jan 15, 2015 at 03:10 PM
Tom_W
Details
p.1 #7100-400II for Astrophotography
Really nice captures and setup, BTW!
RobDickinson
Details
p.1 #8100-400II for Astrophotography
Yep thus the telescope mount. Tracking tends to be accurate for a 'short' period of time for this kind of stuff then you stack multiple shots for better resolution/lower noise.
Great test, wonder how it compares to the 400/5.6L
Jan 15, 2015 at 03:13 PM
jforkner
Details
p.1 #9100-400II for Astrophotography
Aperture is 77mm.
Jack
Jan 15, 2015 at 04:46 PM
jforkner
Details
p.1 #10100-400II for Astrophotography
Yes it's a tracking mount---motor drive; not star-guided.
Jack
Jan 15, 2015 at 04:47 PM
jforkner
Details
p.1 #11100-400II for Astrophotography
Can't help ya there, Bud. Fortunately I do, my driveway is my planetarium.
Jack
Jan 15, 2015 at 04:49 PM
Tom_W
Details
p.1 #12100-400II for Astrophotography
Jack
Wow - just learned something again. I knew of motor drive, but hadn't heard of star-guided tracking. I'll bet that's extremely precise.
Jan 15, 2015 at 05:15 PM
jforkner
Details
p.1 #13100-400II for Astrophotography
Tom_W wrote:
jforkner wroteYes it's a tracking mount---motor drive; not star-guided.
Jack
Not so much, but the mount has to support it---mine doesn't. Here's a link to some examples.
Jack
Jan 15, 2015 at 05:36 PM
dwweiche
Details
p.1 #14100-400II for Astrophotography
If those are the single shots, then I'm looking forward to the stacked shots as well. Thanks for posting.
I'd also like to hear the story and setup behind your avatar, assuming that is also a shot of yours.
Jan 15, 2015 at 10:13 PM
EB-1
Details
p.1 #15100-400II for Astrophotography
That looks quite good for a zoom wide open.
Jan 15, 2015 at 10:26 PM
bnoeggs
Details
p.1 #16100-400II for Astrophotography
WOW!!! Cooool !!
That's it...I'm out of words. Cant wait to see more shots form the venture.
Jan 15, 2015 at 10:31 PM
cameron12x
Details
p.1 #17100-400II for Astrophotography
Very nice images... thanks for sharing!
By the way, comet Lovejoy will be in that same vicinity of the sky for the next several days (see image below).
Comet Lovejoy
You ought to try to image it. Maybe with a shorter focal length, but faster glass to get the full tail.
You'll probably need to stack images to get the best results. You should be able to do at least as well as the image below.
Comet Lovejoy January Positioning
Comet Lovejoy as seen below the Pleiades star cluster.
Jan 15, 2015 at 10:33 PM
jforkner
Details
p.1 #18100-400II for Astrophotography
My avatar is the solar eclipse of May 20, 2012. The image was taken with my Olympus E-620 & 40-150mm lens off Hwy. 88 between Stockton, CA and Lake Tahoe about 6:30pm PDT. Specs are: 268mm (equiv.), f/14, ISO 100, 1/4000 sec.
Jack
Jan 16, 2015 at 07:05 AM
jforkner
Details
p.1 #19100-400II for Astrophotography
I did capture Lovejoy, but not with the new lens. I used the 6D on my telescope. But you're right, I should try with the new lens. Meanwhile, here's the image I got---again, it's a single frame. I've had a great deal of trouble processing the comet with my stacking software, DSS.
Jack
http://jackforknerphotography.com/Temp/Lovejoy-StarTools-No%20NR.jpg
Jan 16, 2015 at 07:15 AM
cameron12x
Details
p.1 #20100-400II for Astrophotography
That's still a very nice image... thanks again for sharing.
I'm going to try to image the comet with my 6D and a couple of lenses, but the weather in central Ohio hasn't been good enough recently.
As for processing Lovejoy, I'd approach it this way. The coma of the comet is very bright, so you probably only need one good exposure for it (underexpose it, relative to the tail). I'd then capture multiple images, exposing for the very dim tail (Lovejoy's tail is very faint) and do some post processing.
I'd first crop all of the tail images, removing the section where the coma begins. Then I'd use DSS (or any other stacking software) to additively build up signal and improve the S/N ratio of the tail section. I'd then layer and paste the resulting stacked image into the image where you originally exposed for the coma.
Make sense? I think that could work well. Good luck!
Jan 16, 2015 at 07:28 AM
