fredmiranda.com Login
This topic is in the 2014 archive. You can read it and like its posts here. It is read only.
Archive 2014Starburst issue with Sony sensors (A7r) how big is it?
therealthings
p.1 #1Starburst issue with Sony sensors (A7r) how big is it?
I am looking into buying an A7r lately. While doing a lot of research the past few days, especially while i'm interested in low light cityscapes i was looking for such footage. I started noticing something really distrurbing in a lot of images. Which is the starbursts that look really awful. I see it happens with more than one type of lens, so i'm wondering if this is a lens issue or a sensor issue.
Please look here:
https://www.flickr.com/photos/markgaler/15058237158/in/set-72157647309662617
He also shares the original raw file.
Also a crop from someone on this forum:
http://mattgrum.com/fm/luxembourg_crop3.jpg
He stated that he also used an Olympus lens with better results seen in this post:
https://www.fredmiranda.com/forum/topic/1319675/1#lastmessage
The TS-E90 did not produce these ugly blotches in the starbursts.
Maybe more owners of A7r and A7s camera's can shine a light on this because i would like to get to the bottom of this before buying this camera.
Edited on Sep 30, 2014 at 12:29 AM · View previous versions
Sep 29, 2014 at 01:11 AM
therealthings
Details
p.1 #2Starburst issue with Sony sensors (A7r) how big is it?
Sep 29, 2014 at 12:40 PM
jhinkey
Details
p.1 #3Starburst issue with Sony sensors (A7r) how big is it?
The star-burst pattern has a lot to do with the particular lens and the covering over the sensor.
I've found my A7r to be slightly worse than my D800 using the same lens, though pretty close (and they are reportedly the same sensor, but likely different covers).
The A7 was not good with multiple reflections.
I have yet to get a decent star-burst on my m43 bodies using any lens.
Sep 29, 2014 at 01:30 PM
therealthings
Details
p.1 #4Starburst issue with Sony sensors (A7r) how big is it?
It certainly is a sensor/lens combination. I hope to be able to gather statistics of this to create a list with 'incompatible' lenses.
It seems many zeiss lenses produce this nasty effect. Canons TS-E lenses (17 and 90) produce a clean burst. Yet to be confirmed about the 24 TS-E II, which i hope someone can do.
Sep 30, 2014 at 12:49 AM
therealthings
Details
p.1 #5Starburst issue with Sony sensors (A7r) how big is it?
Oct 16, 2014 at 02:34 AM
Matt Grum
Details
p.1 #6Starburst issue with Sony sensors (A7r) how big is it?
therealthings wrote:
Could this be related?
http://diglloyd.com/blog/2014/20140214_1-SonyA7-artifacts-star-trails.html
I sure hope not!
Sony's lossy compression works on blocks 32 pixels wide and 1 pixel high. Pixel values in each block are stored in limited precision relative to the minimum and maximum values in each block, hence if these values are too far apart (like when a bright star appears in front of a dark background) the spread is too great and posterization occurs.
The point is you will only see effects within these 32 pixel line segments, the compression artifacts will have a hard edge outside these blocks, which you can clearly see in the star trail example. The effect you're describe happens in a radial pattern around light sources so I can't see how it can be the result of lossy compression.
My belief is that the effect you are observing is caused by certain lenses in certain circumstances and is not related to the sensor or RAW compression.
Oct 16, 2014 at 05:33 AM
Dpedraza
Details
p.1 #7Starburst issue with Sony sensors (A7r) how big is it?
I always thought it was related to the lens and the amount of aperture blades it has.. Voigtlander lenses make very nice sunbursts as well as zeiss lenses. The new sigmas also create quite nice sunbursts
Oct 16, 2014 at 06:01 AM
therealthings
Details
p.1 #8Starburst issue with Sony sensors (A7r) how big is it?
Matt Grum wrote:
therealthings wroteCould this be related?
I sure hope not!
...Show more →
Thanks Matt, i hope you are right. I emailed Lloyd with this question as well. I still don't have the metabones adapter (argh!!) so it was just my theory. I will do extensive testing with my lenses (24 TS-EII and Sigma 35 1.4 Art) as soon as i have received it and will report back.
Oct 16, 2014 at 06:09 AM
Samuli Vahonen
Details
p.1 #9Starburst issue with Sony sensors (A7r) how big is it?
...especially while i'm interested in low light cityscapes...
I had 3 Canon DSLRs, switched two of them to A7 and A7r. Had to keep last Canon 5DmkII for urban night photography. Organic night landscapes usually cause less issues with A7(r) IF one isn't bothered by lossless packing of RAW-files, which causes terrible effects to star trails AND doesn't include moon in the photos, which causes similar issues as light sources in frame on urban low light photography.
I highly recommend to forget A7 & A7r if your main interest is low light cityscapes.
Samuli
Oct 16, 2014 at 10:29 AM
therealthings
Details
p.1 #10Starburst issue with Sony sensors (A7r) how big is it?
I just got word from Alex Tutubalin:
"Sony ARW lossy compression will result in posterization defects in
32-wide pixel blocks on the very contrast edges.
Like this:
http://www.rawdigger.com/sites/www.rawdigger.com/files/Posterization/image02.png
I do not see anything like this in images in thread you mention. Looks
like effect on microlenses, not like lossy-compression artifacts
You may use RawDigger to detect possible posterized areas, as described
in this article:
http://www.rawdigger.com/howtouse/sony-craw-arw2-posterization-detection"
So it's the same as Matt said before.
I have seen enough examples of night cityscapes, especially with canons TS-E lenses and they show slightly better results compared to my 5dII and 6D, probably thanks to the higher resolution and higher DR at base iso. My only worry was the gritty starbursts and base ISO noise which seem to be not a problem (when using the right lenses).
Still can't believe no one discussing this specific issue before.
Oct 16, 2014 at 11:13 AM
Samuli Vahonen
Details
p.1 #11Starburst issue with Sony sensors (A7r) how big is it?
All of these issues were discussed here when cameras become available ("coma from hell", "RAW"-lossy compression, "shutter shock", sensor glass weird reflections, adapter reflections etc.). I assume you skipped reading the A7/A7r image thread, and the Official thread - highly recommended reading both, every page!! Don't forget rangefinder thread to understand thick sensor glass and lens ray angle relationship.
Tendency is to discuss things when they are new. These cameras are year old (real availability), so these are "old news".
Even I may sound negative, I'm "all in" (except the last 5DmkII body) to Sony bodies after using 10+ years Canon bodies (not lenses thou). In my opinion one needs to understand the pros and cons of their equipment to get best performance from their equipment. In any case for next summer I'll get 3rd Sony A7 (or A8 whatever there is available. Hopefully Sony makes something I can use Zeiss G28, ZM18 etc. rangefinder lenses without corner issues - most likely won't happen, but I'll keep hoping. And there is anyways 6 months wait for next time having shooting weather and something to shoot...
Samuli
Oct 16, 2014 at 12:02 PM
therealthings
Details
p.1 #12Starburst issue with Sony sensors (A7r) how big is it?
therealthings wroteStill can't believe no one discussing this specific issue before.
...Show more →
You can't imagine how much i have read about this camera. Too much information. Then i stumbled upon this phenomenon and created this thread both here and on DPR. No one seemed to know or care about these gritty starbursts. Even 'highly recommended' lens reviews images clearly suffered from this issue. I also Googled on this... No answers found until now. I will digg deeper in the a7r forum. Thanks.
Oct 16, 2014 at 12:15 PM
Samuli Vahonen
Details
p.1 #13Starburst issue with Sony sensors (A7r) how big is it?
I can imagine how much have you read and how little useful info you found. Reviews are almost all paid way or another (advertisement, free stuff to review, risk of not getting next gen stuff for review, etc.). So it should not be great surprise to get reviews, in which only positive things are brought up. Also for invidual people cameras tend to be big investments, and people tend to concentrate to positive things to justify the investment to themselves.
I really dislike 1000 guys discussing and proving themselves that they all made good investment. Personally I prefer to discuss also the "not so great" features to understand limitations as well.
The gritty starbursts are feature of A7r. They do not happen with A7, it has other issues (e.g. "coma from hell"). Lens has very little to do with it, it's more feature of the sensor cover glass. Also I have seen "starburst like" things with lens wide open, which also indicates that it has nothing to do with the lens.
Samuli
Oct 16, 2014 at 12:34 PM
retrofocus
Details
p.1 #14Starburst issue with Sony sensors (A7r) how big is it?
Interesting read so far - I can only say from my observation that I didn't see this phenomena yet. Photo taken with A7R, 90/2.8 TSE lens with f/13:
http://martinbluhm.zenfolio.com/img/s12/v175/p133643499-5.jpg
Oct 16, 2014 at 12:51 PM
retrofocus
Details
p.1 #15Starburst issue with Sony sensors (A7r) how big is it?
Not sure if this resolves the issue, but using a too small of an aperture is often not advantageous for starburst photos since star trail lines tend to intermerge and form more a ball-like structure. I personally try to avoid f/16 and even smaller apertures for this kind of photography as general rule of thumb.
Oct 16, 2014 at 12:57 PM
Samuli Vahonen
Details
p.1 #16Starburst issue with Sony sensors (A7r) how big is it?
Yes of course. Also lenses with 5, 7, 9 (odd number) aperture blades tend to make A7r issue more visible, than 6 or 8 blade lenses, in which opposite side "bursts" make each another stronger. Almost all my lenses, which I prefer for night shooting, unfortunately have 9 blades (might be that I don't have any with 8 blades).
Samuli
Oct 16, 2014 at 01:11 PM
retrofocus
Details
p.1 #17Starburst issue with Sony sensors (A7r) how big is it?
retrofocus wroteNot sure if this resolves the issue, but using a too small of an aperture is often not advantageous for starburst photos since star trail lines tend to intermerge and form more a ball-like structure. I personally try to avoid f/16 and even smaller apertures for this kind of photography as general rule of thumb.
Samuli
Interesting to know - wasn't aware that the starburst form on the sensor also depends on the odd number of blades. I have to check this with my lenses!
Oct 16, 2014 at 01:20 PM
therealthings
Details
p.1 #18Starburst issue with Sony sensors (A7r) how big is it?
I have seen images both with the ts-e 90 and ts-e 17 that created smooth starbursts. Not yet with the ts-e 24 II which i have. If someone can try this that would be great. Otherwise i/we have to wait for my metabones to arrive so i can test this myself. Matt also showed an example shot with an Olympus lens (if i remember correctly) that produced acceptable starbursts as well. Not sure if it's the blades. Maybe a lens coating in combination with the sensor glass.
Oct 16, 2014 at 01:33 PM
Samuli Vahonen
Details
p.1 #19Starburst issue with Sony sensors (A7r) how big is it?
Regarding number of aperture blades all mentioned TS-E lenses have 8 blades. That will make the A7r issue less visual.
I found from other virtual machine bookmarks to the discussion about A7r weird starbursts (first discussion from December 2013, it has been since discussed few times). On small webthumbnails (1000px or so) most likely the starbursts won't look that weird, but at bigger size or print the issues are obvious. For example Bob's (rji2goleez) photos on page 120 look quite OK, but at bigger size (page 121) look indeed very weird.
Also comparing his page 120 photos taken with Rokkor 40/2 (8 blades) and FE35 (7 blades), it's clear that for night photos 8 blades is much better choice with A7r. Maybe I'll need to go next time urban night photo shoot with Contax/Yashica lens (6 blades) instead of Zeiss ZE (9 blades) to see if works better.
Number of aperture blades has caused starburst differences with earlier digital cameras and film, but they haven't been this big. Usually just "how many spikes" in the starburst. Somehow the thick glass on front of the sensor contributes to this.
Samuli
Oct 16, 2014 at 02:10 PM
davidmarinero
[X]
Details
p.1 #20Starburst issue with Sony sensors (A7r) how big is it?
Starbursts have as many points as diaphragm blades when that number is even, or twice as many points when the number is odd. So a 9 blade diaphragm produces 18-pointed startburst, and the 8 blade one produces an 8-pointed starburst.
Oct 16, 2014 at 02:19 PM
