fredmiranda.com Login
This topic is in the 2014 archive. You can read it and like its posts here. It is read only.
Archive 2014Leica M240 Purchase
freitz
p.1 #1Leica M240 Purchase
While I was out with my wife we stopped by the Leica store and I played with the M240. I currently have the 6D with a 24-70 MKII and 70-200 MK II. Covers all that I need for shooting; we like to travel which is where I take most of my shots, also just snap shots and family shots, hardly and high speed or action shots.
The leica looks like it would help with weight that is for sure, was planning on going with a 35 and 75 as my only two lenses with this system. It also would allow me to feel more comfortable bringing the camera everywhere, sometimes the 6d with a 70-200 is a bit to pull out in heavy crowds.
-smaller form factor
-seemed fun in the store for the 2 hours I was in there
-leica lenses
-loss of AF
-loss of longer focal lengths
-I feel like I will have my camera on me more.
Anyone else that has made this switch. Please provide your input.
Mainly used for
-travel
-family pictures
-landscapes
-astrophotography (rarely)
Thanks!
Aug 30, 2014 at 06:29 AM
rico
Details
p.1 #2Leica M240 Purchase
35/75 is a good mix: I'm using it on my FF Nikon DSLR. Longer focal lengths are available to "M" users by way of the live-view feature; I will try not to mention Visoflex. No digital M in my stable, but I do have a large M/Barnack kit.
Aug 30, 2014 at 06:51 AM
adamdewilde
Details
p.1 #3Leica M240 Purchase
You'll never leave the house without it. Especially on trips (never leave the hotel without it). The A7 or a Fuji X100s or RX1 can do the same though for a lot less! (The "same" meaning always having a small camera on hand while traveling.)
Yeah the M240 35+75 combo is really all you need for trips. There will be the odd time you'll crave a 21mm if you're in a church/building.
If you're not on a budget the 35Summilux-FLE and 75 Summicron-APO are the way to go. On a budget I'd suggest skipping Leica altogether and getting yourself a 35/2 Zeiss ZM lens and the 75 Summarit.
For 21mm I'd go with the 21/2.8 Zeiss ZM or a 21SEM if you're not on a budget.. Really not on a budget get yourself a 21Summilux-ASPH
75mm can be a bit tricky to focus on the M, a 50 Summilux-ASPH or 50/2 Zeiss ZM will be easier to focus and smaller/lighter.
The 28Summicron is also a good option, but I preferred the look while on a M9, more then on the M240.
Hope this helps.
Aug 30, 2014 at 07:10 AM
freitz
Details
p.1 #4Leica M240 Purchase
...Show more →
Thanks for the advise. Did you also come from a FF DSLR?
Aug 30, 2014 at 07:11 AM
Mescalamba
Details
p.1 #5Leica M240 Purchase
Astrophoto? Never saw any with Leica, tho as its now CMOS, should be ok.
Otherwise, fine for everything else. With EVF (or back screen, no matter how wierd it looks), you can use even zooms to some extent if you wish (almost any manual focus lens in fact as long as you are okay with focus + recompose, since EVF displays at 100% only center portion of image).
M240 is as much mirrorless as A7. Only its a bit crippled in LV mode, but it can be used, which is that important part. Other than that, quite same.
If money are no issue, Leica is good choice.. or maybe even best for what you want.
Aug 30, 2014 at 07:23 AM
loosh
Details
p.1 #6Leica M240 Purchase
Lol, you really need to rent one and try for yourself. There are lots of smaller kits for much more reasonable prices, and people who shoot Leica usually know exactly why they're willing to pay the premium.
Aug 30, 2014 at 07:27 AM
freitz
Details
p.1 #7Leica M240 Purchase
...Show more →
Money isnt an issue. I would sell off my Canon Gear. I have become attached to my canon gear and thinking I will miss some of the things it offers which is why I am trying to see if anyone has made a similar transitions. Thanks for the input. What are you shooting with by the way?
Aug 30, 2014 at 07:29 AM
braindeadmac
Details
p.1 #8Leica M240 Purchase
I wouldn't say that I've made a switch, but I now own both a full M system and fairly comprehensive DSLR system (Canon zooms with some Zeiss primes).
I currently use the Leica M almost exclusively. Although a leica rangefinder user for about 15 years, I didn't make the nearly complete switch to M until about 10 months ago when I bought the M 240. Before that I owned film Ms and an M8.
I have a bad back that is easily aggravated, so weight (and bulk) was a pretty big consideration.
The Leica lens and cameras are a lot more dense than their Canon (and even Zeiss) counterparts, so although there is a weight savings, it's not as huge as you might guess. My Leica setup consists of 8 prime lenses from 21mm to 135mm. With the M body the kit weighs in at 4.2 kg. Since there a couple of duplications in there, the actual full kit I would carry weighs in at about 3.7-3.8 kg. Typically, I take the camera with 3-5 lenses at most, so I'm carrying maybe 4 pounds of gear. About the equivalent to the Canon with the 70-200/2.8
The equivalent full frame Canon system with Zeiss primes (substituting the Canon 85/1.2 for the not so good Zeiss 85/1.4) would weigh in at 6.9kg. However, it's a lot more bulky. I can fit my M system in a canvas shoulder bag that measures about 15 inches long, 10 inches high and 5 inches deep. My Canon body with the 70-200 and hood attached in working position occupies about the same space in the same bag.
My Canon 5diii, 24-70 mk II, 70-200/2.8 mk II weighs in at 3.3 kg. For a days casual shooting I'll typically throw in a Macro lens with that, or the 21 zeiss. So it winds up being about the same weight as the M kit.
If you can afford to keep the Canon body and a couple of lenses, consider doing that. For example, downsize the the 24-70 and 70-200 to the f4 lenses, which offer considerable weight and size savings. Also, keep in mind that there are some things that the M just isn't so good at doing. For example, it's just OK at Macro, although you'll want an EVF for that. Focusing with the telephoto lenses, especially the 135, is an acquired skill and requires some practice. Although there are a couple of die hards on the internet that swear by it for use with some of the excellent Leica R zoom lenses, it really kind of sucks for that because of the lackluster performance of the EVF.
Aug 30, 2014 at 07:45 AM
Jman13
Details
p.1 #9Leica M240 Purchase
If you think you may miss a lot of the features of your Canon kit, then it may make more sense to go to one of the mirrorless kits. You can still use the excellent Leica glass on something like the A7, but you'll get a lot more versatility. If you wanted an AF kit, the Fuji also has amazing lenses that are fast.
That said, if it's the full Leica experience and rangefinder that you want, then the M240 would be the way to go.
Aug 30, 2014 at 08:29 AM
uhoh7
Details
p.1 #10Leica M240 Purchase
or a clean M9 for 3200 USD, which many would prefer to the 240.
You may still want to keep the 6D , in addition to the leica.
for travel that little Sony Rx100 Mk3 is pretty great.
Aug 30, 2014 at 09:57 AM
freitz
Details
p.1 #11Leica M240 Purchase
Its a strange choice that is for sure. What I am looking for does not exist I am sure. Some type of cross between what I have and the Leica 240. Actually enjoyed playing with the leica for the 2hours I was in the store but its hard to say what pictures I would get by having a smaller form factor and ease of having it with me all the time vs. the pictures I could potentially miss by not having the DSLR.
Aug 30, 2014 at 11:47 AM
tthorne
Details
p.1 #12Leica M240 Purchase
I come from FF Nikon (years ago 2x D3 70-200/17-35) and was traveling so much that I had to find a smaller alternative. I made stops in M43 and Fuji, and while they had their great sides, there was always something missing for me, so I kept jumping around. Then I tried the Ricoh GXR and that was the best of them. I love that camera. I had the M mount module and naturally started looking at all kinds of Leica glass. Gateway drug!
Ultimately I ended up with a pair of M240s and it has been that way for a long while now. I shoot 21Lux, 35FLE, 50ASPH, 50Noct.95, and 90APO, but adding the 135APO soon. I travel with all of this in my Billingham 335, no problem, but I tend to walk with a smaller bag with 2 bodies and maybe 3 lenses. I like 21, 35, 90, but 21, 50, 90 works great too.
M240 and my old 21mm SEM (Great lens, will buy it again) roaming Paris
Aug 30, 2014 at 01:38 PM
freitz
Details
p.1 #13Leica M240 Purchase
I guess really the only thing to do it rent one and try it out. Tried to grab one for this holiday weekend but not possible unless I just go to the leica store and buy it.
I guess what I'm asking is what do you miss from your DSLR when moving to the Leica system.
Aug 30, 2014 at 02:24 PM
flash
Details
p.1 #14Leica M240 Purchase
I switched from a bag of "Ls" nearly five years ago. M9's and a mix of Leica and Voigtlander glass. But I found I still needed a macro and something longer so I went through the mirrorless roundabout. Panasonic, Fuji, Olympus and Sony.
I still have an Olympus EM1 and some glass plus a full SOny A7 kit. But the type 240 means they get almost no use now. So little that I've just picked up a second M 240 body. Now that battery life is really good and you can adapt many many lenses to Leica (solving the macro/telephoto issue mostly) I'm finding fewer and fewer places where I pull out the Sonys. The Olympus gear will be sold soon.
As long as you're happy with manual focus you can get some stunning longer lenses (Leica R or Nikon especially). I've got a Zeiss 100 Marko Plannar in ZF mount that I use on my M's.
The only downsides are the large cost and the nearly insatiable lust for the lenses. There's just so much fantastic glass out there it's nearly impossible to resist. You may only want a 35 and a 70 but it's easy to end up with 4 or 5 of each!! :-) They don't call Leica stores dealers for nothing.
I would never say a Leica leads to better images, cause it doesn't. It does make you think about shooting differently, for sure. But mostly I just find it a wholly more satisfying shooting experience than any other 35mm camera.
Gordon
Aug 30, 2014 at 02:25 PM
SR777
Details
p.1 #15Leica M240 Purchase
I didn't make the switch. I added the Leica to the Canon 6D. The two are not equivalent to me. The 6D with the super telephotos and the IS lenses is pretty good. The Leica is an awesome system for travel and street photography, one where the Canon system got in the way at times (even with the small 28/2.8 IS or the 50/1.8.
I have the M240 with the 28 Cron and the 50 Lux ASPH. Both the lenses are brilliant and deserve all the praise one reads online. The M240 with the chrome 50 Lux ASPH is quite heavy with its metal construction and not all that small relative to a Sony or Fuji mirror-less. However, it feels solid, extremely quick to focus, has excellent sharpness, contrast, very simple to use and feels like a precision instrument. I love it.
Aug 30, 2014 at 02:37 PM
uhoh7
Details
p.1 #16Leica M240 Purchase
Well I don't miss, but it is missing: AF; Zoom lenses--(OK WATE is a zoom)
Basically the whole shooting experience with a Leica RF is totally different than DSLR. From when you pick up the camera to when you develop in LR. Viewfinder is totally in it's own world, but has it's strengths.
Very very simple. Best lens set in the world. Quirky.
The 240 can shoot SLR glass also, but the Sony A7x makes more sense for that stuff. Way better MF.
For me, combo of M9 and A7 give every option.
Aug 30, 2014 at 02:40 PM
freitz
Details
p.1 #17Leica M240 Purchase
All great advice.
My current Kit (includes my wife's Camera which she never uses really just a backup)
6D
24-70 MKII
70-200 MKII
SL1
40 F 2.8
17-55 F 2.8
I would not be able to keep the 6D and get a M240. I have other expensive hobbies that don't allow for that. So my solution was to pick up a M240 and get a Leica T (for the wife *wink) Leica T is a mirror-less should have the reach with the zoom they offer and has all the bells and whistles my 6D has without the image quality.
My main concern is, I;ve spend a fair bit this past year on a MKII 24-70 and MKII 70-200 as well as the 6D, I find sometimes I make excuses to not take it out because it isn't the easiest thing to move around with esp when traveling or at dinners... The only fast moving subjects Ill ever have to shoot would be children but right now I don't have any. Also maybe people dancing. As I said above this is a hobby for me, I seem to have lost that feeling when picking up my 6D, it hasn't been as enjoyable the past 2 months. I have taken less and less pictures.
I have read a fair bit on Leica's and people who enjoy them the past few days. I haven't seen anyone who has bought one and used it and sold it. If they have they haven't posted online about why they didn't like it. I agree its not something for everyone, but I think it help with revitalizing the enjoyment by thinking more about the picture rather then just shooting aimlessly.
Aug 30, 2014 at 02:52 PM
HEMIROTT
Details
p.1 #18Leica M240 Purchase
I was in the same boat as you. I had the 5d3, quite a few L prime and L zoom lenses. Once I got the Fuji and Sony, I stopped using my Canon gear altogether for the same reason as you. I hate lugging around the DSLR. With the mirrorless and Leica, I am taking my camera everywhere and capturing a lot more moments than I do with my Canon. An my opinion that is what it is all about.
The sensor on the Leica is not the best but still better than Canon. But combined with the Leica 50mm Lux Asph, it blows away any 50mm lens on any system I have personally shot with. For more critical landscape work, I will keep the a7R around.
I do at times miss the speed of the DSLR but not enough for me to ever go back as I primarily shoot static subjects.
I felt like I had to shoot with the DSLR versus wanting to shoot with the Leica. Good luck in your decision.
Aug 30, 2014 at 03:20 PM
freitz
Details
p.1 #19Leica M240 Purchase
...Show more →
That makes perfect sense. With my 6D i feel compelled to shoot with it. I invested the money and it would seem silly to leave at home. More often then not it stays at home.
Can the Leica not handle the Landscape work? I am considering the M240.
Aug 30, 2014 at 03:28 PM
flash
Details
p.1 #20Leica M240 Purchase
freitz wrote:
All great advice.
6D
24-70 MKII
70-200 MKII
SL1
40 F 2.8
17-55 F 2.8
...Show more →
You know you might be better off with a Canon 50mm 1.4 or a Sigma 35mm Art?? Those lenses you have are probably the issue, more than the camera. I'm a Leica fanboy, but don't think for a second you'll get better images dropping 15-18K on a body and two lenses.
Even a modern Leica is like driving an old sports car. They've removed the radio, carpet, trim and airbags and charged you $5K more. That's what Leica is. All the bells and whistles removed and back to a more pure camera. Mind you with video, Av and live view it's a bit less pure than it used to be but you can use it without any of those things getting in the way.
If you want negatives, here are a few:
* Super expensive.
* Long repair times if anything happens. (months not weeks)
* possible rangefinder calibration issues although both me M240's have been perfect.
* No zooms or AF (personally that's not a negative for me).
* Not as easy to shoot vertically.
* Small but surprisingly heavy.
* Some find an M hard to grip on to.
* Limited flash options for TTL.
That's a small list against the positives.
Gordon
p.s. Get you wife a Sony RX100 mk3 not a T.
Aug 30, 2014 at 03:41 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
