Hi.
From this this thread i became interested in adding a wide angle Zuiko for my A7.
Since i am not sure which one i want i recently bought three lenses and will in the end just keep one (so let me know if you are interested in any )
18mm 3.5 in ok condition a small mark in the middle of the front glass.
21mm 3.5 MC Very good condition, glasses with no marks
21mm 2.0 Great glass but a small "dent" in the filter thread but still accepts filters
Anyway. So i currently don't have much time and the lenses arrived today but i did a first "bokeh" close focus (approx 40cm) ) test.
These will probably not be 100% scientific tests, just so you know.
On tripod, exposure adjustments and a little bit of sharpening for resize.
Focus on the red lego brick with white marks on it.
This is what you get, no 100% crops today, if you don't like the comparison, jump to the next thread..
Next plan is infinity tests outside.
Hopefully this might help someone with their decisions, if you are in my situation
One thing that you se immediately, is that the 18 and 21 f 3.5 has very little distortion compared to the 21 f2
Also that the sharpness in the center of from the 21 f2 is more ok than i would have thought on this distance
I ignored my cold for an hour and will give you a few new scenes to compare today.
The first one is below.
I decided to give you 1920px images instead of dealing with 100% crops etc, should be enough to see differences.
Exactly the same pp, (exposure and sharpening during resize).
Focus on the balcony (middle of the frame)
These were all hand held, so sorry for not 100% exact framing.
All Iso100
All lenses without hood!
I have to say that although the red ring flare of the 21 f 3.5 is cool i LOVE the flare that the 21 f2 produces at f2 and f2.8 in these pictures.
Wow that 21mm f2 gives interesting lens flare when shot into the sun. If I was shooting video then that would be the one I would choose but as I mainly do stills I think I prefer the flare on the f3.5.
Again many thanks for doing these tests - much appreciated.
The Brick shot about 2.3 meters
All Iso100
A quick 100% center crop comparison, screen grab from LR.
Did drag the frame myself, sorry for not exactly the same size..
To me the 21 f2 is less sharp at 2 and 2.8 of course..
At 4 and 5,6 i think it's pretty even against the 21mm 3.5 at 3,5 and 5,6
I have been considering this lens for my a7r. The 21/3.5 and 18/3.5 with 25mm/100gram of adapter are smallish (60mm long and light <400grams). But I am bugged by having i) never seeing a sharp shot from a 21 and not having seen the corners of the 18 at infitity, where I am mostly shooting.
Can you do a just short of near infinity focus landscape type shot at f8. 21/3.5 vs 18/3.5 The good thing about the above posts is that the vinnetting is strong but the color shift is not overly strong in th corners and symetrical . But color cast changes with focus distance. Definitely way better than the voigtlander 15 which is unusable. But none of the pictures looked sharp and bokeh seems ugly - but that might be because all were close focussed? I can live with ugly bokeh because I dont shoot short but I cannot live with not sharp. It has to do better than my 11-22 on EOSM to make it worthwile.
I presume you have not done any edge/color correction on images.?
I am debating the 16-18-21 vs Olympus 18 or 21. Based on the above lack of sharpness, I am not convinced. It defeats the purpose of a 36mpx camera to have not sharp lens. However, weight/size vs quality is the debate.
[Woops I went back throug again and noticed: "This is the 21 3.5 at f11 infinity with the sun just outside to the top right." But it looks soft. Did you focus with liveview or just set it to infintity on the lens (which might be beyond infinity?]
Scott.
I can agree with you, initial impressions on sharpness are not super or zeiss like
I did have a zeiss 21mm earlier and from memory it was clearly sharper than any of these 21mm.
But.. I have not finished testing yet and it's a BIG difference in size..
No corner fixing.
I had two more scenes i will do from today, not much time however but i did export an F8 shot for all three lenses where i have live view focused on the building in the center.
The sun was there for the 21mm f2 shots so the exposure is not exactly the same.
A hood would have helped a bit (most for the 18mm i think)
Just realized the screen grab program doesn't save at 100% jpg quality.. , meaning the 100% crops have a lot of jpg artifacts.
So keep that in mind, but you can at least compare them
Thank you again for all the work. It is very helpful. I was about to buy one and now am less enthused - small but I have to think about quality vs size.
It looks like 18 is clearly the weakest with f2 being the best.
But compared to my TS17 or zeiss 15, not so exciting. I think the leica 16-18-21 would be way better. I will check this evening. I took some shots with it a while back.
I've owned the 18 and both 21mm's and found that my 21/3.5 MC was the best by far.
I really wanted to like the 18, in part because it was the most expensive, but it simply was too soft in the corners even stopped down.
The 21/2 was pretty good for closer subjects, and speed is always nice, but for a landscape/general lens, the 21/3.5 is near ideal
Another thing I really love about the 21/3.5 is its very small size and 49mm filter thread, which allowed me to share filters with the FE 35 and 55's, both of which were 49mm, as well as my Contax 90G, which again is 49mm.
Having sold my A7, my 21/3.5 (MultiCoated) is for sale on the B&S
