p.1 #1OM Zuiko 28mm F2 The best and the worst all in one.
...both a pain and a delight. The least clear of all my wide lenses wide open, the "sharpest/clearest" of all F8
Is this what others have found with this lens or should I search out another copy?
Wide open it is a pain to focus accurately, improvement at F2.8 and then a vast increase in "clarity" between F2.8 - 4.
At it's best F8, it at least equals my copy of The Contax Distagon 28/2.8, possibly even bettering it, certainly better at edges and corners, with so much more information in the shadows than the Distagon.
So, is it possible to find this lens with "clearer" wide open performance, or is this just how it is?
Below screenshot of extreme left edge performance at F2 cf. F8 (1:1 in Lr5 Compare, shot on 5DII, focus on outer branches of tree)
p.1 #3OM Zuiko 28mm F2 The best and the worst all in one.
Makten wrote:
I hope you're not using the infinity stop?
Focussed on the branches, fractionally short of infinity stop..but why do you ask? At closer focus distances the lack of clarity is just the same wide open.
I've also shimmed the adapter (Elefoto, Japanese) to give perfect infinity at the stop.
p.1 #6OM Zuiko 28mm F2 The best and the worst all in one.
My guess is, the lens designers don't expect anyone to use it wide open for landscapes. Maybe people will do some close ups or environmental portraits with it wide open which is a good reason to make it "glow" and have more painterly rendering wide open.
Then when it's being used for landscapes at landscape apertures, sharpen it up.
p.1 #8OM Zuiko 28mm F2 The best and the worst all in one.
More information in the shadows probably just means it has more veiling flare (lower global contrast). Sometimes that can be an advantage though.
I'm personally kind of addicted to the look of the Distagon -- it's very characteristic and easy to recognize.
p.1 #9OM Zuiko 28mm F2 The best and the worst all in one.
My limited experience with Olympus on A7R, and specifically the 28 f:2.0 is that there are two different issues. One is that it is soft wide open. Basically too soft for me to be interested, but, as I bought it for landscapes, it is not a problem. The other one is focusing. That is when I realised that I am so used to Zeiss lenses that I didn't realise how much of a focusing help their very strong micro contrast is. By comparison the Olympus has weak micro contrast, which as noted above, can be useful in some circumstances. After some practice I am slowly finding it less troublesome
p.1 #10OM Zuiko 28mm F2 The best and the worst all in one.
Sounds like my findings. However, if you can get past the focussing issue, stopped down it is brilliant.
I was just hoping it was just my copy that was like that, as, like you, I really don't like focussing with it soft.
p.1 #13OM Zuiko 28mm F2 The best and the worst all in one.
philber wrote:
My limited experience with Olympus on A7R, and specifically the 28 f:2.0 is that there are two different issues. One is that it is soft wide open. Basically too soft for me to be interested, but, as I bought it for landscapes, it is not a problem. The other one is focusing. That is when I realised that I am so used to Zeiss lenses that I didn't realise how much of a focusing help their very strong micro contrast is. By comparison the Olympus has weak micro contrast, which as noted above, can be useful in some circumstances. After some practice I am slowly finding it less troublesome...Show more →
I think Philippe, that you should explore the world of Minolta MD Rokkors (early and late).They are more contrasty than Olys,but less than Zeiss.Their colours are more saturated but not as punchy as those from Zeiss.They are in general more usable wo than Olys and only slightly larger,esp the late Rokkors with 49mm filter thread.In short,they are very Leica R like.They're readily available and priced similarly to Olys.
MD W. Rokkor 24/2.8 55mm,MD W.Rokkor 35/2.8 49 and 55mm,MD W. Rokkor 35/1.8 49 and 55mm,MD Rokkor 50/1.4 49 and 55mm,MD Rokkor 85/2 55 and 49mm are really nice for the A7R.
Keeping in mind that in the corner crops, you should look at the wall, not the tree, this actually looks like quite a good performance for such an old, fast lens. At f/2 and f/2.8, it isn't quite there, but already by f/4 it is yielding very decent performance.
p.1 #15OM Zuiko 28mm F2 The best and the worst all in one.
maybe the ones that Minolta designed/made. but, if we're allowed to make generalizations, I've found the later OM lenses to be better than the Rokkors, often with a larger max aperture at any given focal length, always smaller and built better.
of course Im wording mine to be as a personal thing but please pretend Im just saying it's that way all the time which is 1. untrue 2. unsubstantiated and 3. exactly what you just did.
p.1 #16OM Zuiko 28mm F2 The best and the worst all in one.
do you have a reason for thinking this? AFAIK there is literally zero literature on this being the case for this lens.
Id guess they made the best lens they could given their directives and it's soft at f2 because making a 28/2 that's sharp at f2 is something we've seen only relatively recently.
fwiw I have an OM28/2 and mine is easily better wide open than OPs.
p.1 #17OM Zuiko 28mm F2 The best and the worst all in one.
My reasoning is simply from just a practical photography point of view. It's rare to take landscapes at wide open apertures but it's very frequent to do close up with subjects in shallow DoF kind of work with wide open apertures.
p.1 #19OM Zuiko 28mm F2 The best and the worst all in one.
Yes, that image, wide open, looks as though one of the rear elements may have been reversed... I had a similar issue with a 28mm nikon mount lens. Do you know if this lens has ever been opened up?
p.1 #20OM Zuiko 28mm F2 The best and the worst all in one.
I doubt the stopped down results would be as good if it has been? There is no evidence of it having been opened, it's a lovely clean copy, though perhaps I should get it looked at.
However, after reading several of the recent posts by Roger Cicala on his Lensrentals blog, it seems most repairers, even OM approved/accredited ones, don't have the necessary test equipment to do a proper re-setting up, which is really bad news..but does explain some of the poor results I have had with lenses unchanged after being supposedly reset by a repairer.
