p.1 #1Contax N to Sony NEX with electronic aperture control - a new hope
Hi Contax N users,
There is a new adapter type from Kipon on the Ebay for Contax N lenses on Sony NEX bodies
(Kipon Adapter W/ Electronic Iris Control Function for Contax N1 lens to Sony NEX) for 255 bucks.
The text states, that it can control the electronic aperture of the Contax N lenses. The description is not fully understandable. (It is written in a special English.)
The adapter has electronic contacts and definitely differs from the previous primitive version which has manual aperture blades inside the adapter.
As I have several unconverted Contax N lenses (including the Aposonnar 4/400 and the 2.8/17-35) I am highly interested.
Is there anybody who has more info about this adapter ? (I already asked the seller too.)
It would be great to use these lenses on NEX too. For me AF is not so important but the electronic aperture is a must have.
p.1 #2Contax N to Sony NEX with electronic aperture control - a new hope
I saw it in the Chinese forums a while back when I was checking for A7(R) photos but I wasn't sure who was releasing it and I didn't spend too much time to check the posts. It might be similar to contax g af adapter as it was produced by a third party and is selling under 2 brand names now... The contax g lens af is slow, but the mf and electronic aperture works. So contax n adapter might be similar.
p.1 #3Contax N to Sony NEX with electronic aperture control - a new hope
According to the description, this adapter does not have AF, but offers electronic aperture from NEX. It speaks about aperture 1.4 but only two Contax N lenses have 1.4 aperture.
I consider to buy it. It is a much cheaper option than the conversion.
p.1 #12Contax N to Sony NEX with electronic aperture control - a new hope
I was curious about those Contax N lenses for a long time. So when I read about this adapter, those lens lust demons took over and now I'm the happy owner of some of these fine lenses and a Kipon Contax N to E-Mount adapter. Thank's to the OP for the info!
I got the following lenses: Vario-Sonnar T* 2.8/17-35mm, Vario-Sonnar T* 4.0-5.6 70-300mm, Vario-Sonnar T* 3.5-4.5 70-200mm, Macro-Sonnar T* 2.8/100mm.
The adapter quickly made it's way from China to Germany but then got stuck in customs for four days. All the lenses where delivered while waiting for the adapter, so I could start playing when it arrived.
The adapter comes with a two pages manual. Bad thing is, I have to learn Chinese to read it. No big deal, as the function of that equipment is clear.
The first thing I saw, after I've mounted the Macro-Sonnar 100 and looked through the viewfinder of my A7r, where some scary ghosts in the middle of my room! Luckily I was forewarned from that spooky ghosting thread here on the forum and didn't have to call the old lady, that otherwise handles such occurrences in our block .
When I looked inside the adapter, I saw that there is some black shiny plastic covering the electronics. That reflects so much light, that the unmodified adapter is unusable on the A7r. On Nex 7 you can still see some flaring, albeit it doesn't ruin the hole picture.
I could eliminate most of the flares with some deep blue cardboard I put inside the adapter. There's still some blank plastic left that causes some shimmering. I will cover that in a second try with tape and cardboard.
On Saturday the weather was fine, so I went out to test my new camera system. All worked fine for about 2 hours. After that the camera lost connection to the lens several times and I could shoot most of my shots wide open only.
Back at home I put the adapter with the lens on my NEX 7 and everything worked fine again. Encouraged by knowing that the adapter was not faulty, I cleared the contacts on the camera side of the adapter and on the A7r and all worked perfectly again!
The adapter is well crafted. You put the aperture ring to wide open position and then can control the aperture from the camera. If you set the aperture on the lens the f-number get's reported to the camera. Unfortunately the camera adds that information to the exposure calculation and produces underexposed results.
When using a flash with the adapter you get a delay of about 1 second, regardless if the flash is in auto or manual mode. That's a bit disappointing for me, because I was eager to use the Macro-Sonnar with my Minolta MFC-1000 ringflash. I have high hopes in that AF adapter now. Or maybe Kipon brings a firmware update at one point.
I have put some of my first results in the Zeiss picture thread, including a link to the fullsize files on flickr.
p.1 #14Contax N to Sony NEX with electronic aperture control - a new hope
I just checked a Chinese website about the Kipon adapter, it says the adapter allows aperture control via the camera but no AF, so it is for MF only. Also, aperture cannot be adjusted during video recording.
EXIF support, including FL, aperutre used, max aperture (but can't record the actual max aperture of lens with variable aperture)....
It does not support NAM-1 adapter.
The camera "MUST" be turned off when mount/remove the lens.
p.1 #15Contax N to Sony NEX with electronic aperture control - a new hope
Thanks for the update. I don't know if your adapter is loose or not, but I have noticed the mount size increased from nex-5/5n/6 to A7R. So the contax g adapter similarly looses contact w/ A7R though it was perfectly working w/ nex-6. I even replaced my first A7R due to this and second one also has the same issue. I read that another user has the same experience in dpreview w/ contax g af adapter. That might be the problem if the specs were based on nex cameras....
p.1 #16Contax N to Sony NEX with electronic aperture control - a new hope
My adapter arrived today but I don't have a lens to try it yet (24-85 & 70-300 in transit). The adapter seems to be all flat black inside so it looks like they have learnt from the ghosting problem.
p.1 #17Contax N to Sony NEX with electronic aperture control - a new hope
That's very interesting. The plastic in the adapter in your link looks exactly like the one in my adapter. You can even see the shimmering. Does yours look different?
The manual in your link is very interesting too. My Chinese manual seems to contain more information than the translation. There under the list of compatible lenses, I can read the words NAM-1 and Contax 645 surrounded by those Chinese characters I can not understand. Then it continues with a second page with many clauses.
I'm curious now what the rest of the manual has to tell us.
p.1 #19Contax N to Sony NEX with electronic aperture control - a new hope
The adapter has some mild play in the camera mount similar to the play my native lenses show on the A7r. I could replicate the contact loss with the 70-300mm lens on the A7r. The zoom operation gives enough torque to loose contact at times.
On the NEX 7 the adapter indeed sits a little bit stiffer and I could force no contact loss. They must be aware of the problem, because it's mentioned in the manual in the link in Hrossm's post. Or it's a problem with my specific camera.
I knew it could get a bumpy ride. Can't wait to test the upcoming AF adapter now. Will keep the Kipon as a backup if that one works better.
Edit: I somehow read over that you tried two A7rs'. That seems to rule out a specific camera problem.
