fredmiranda.com Login
This topic is in the 2013 archive. You can read it and like its posts here. It is read only.
Archive 2013a7R/Metabones Combo and Tripod Mounting
tsdevine
p.1 #1a7R/Metabones Combo and Tripod Mounting
I think there has been a smattering of discussion about this in some other threads, but I thought this might be worthwhile others (and me) to have a thread about this.
All my "alt" lenses are still EF mount, and up to this point I've been shooting Canon bodies. Enter the a7R and that's about to change. I already have a Metabones adapter, and in the agony of waiting for the body to ship, the one area that I keep coming back to is how I'm going to use the camera tripod mounted. I have an Acratech (Arca Swiss compatible) clamp and I use RRS L brackets on all my cameras (5D, 5D II, DP1M, DP2M). So my basic instincts lead me to getting an RRS L bracket for the a7R. But I know the Metabones adapter has a mount and generally with the Sony adapters they say use the mount on the adapter...don't mount the camera. (I realize the same holds true for large telephotos on SLRs.)
If I start getting some native glass though, I'm going to need a bracket for the camera anyway. Plus the heaviest lenses I'm going to mount on the a7R are the Zeiss 15 ZE, Sigma 35mm, and CV 125. I realize not only weight comes into play, but I guess the length of the lens should be considered too. I saw Fred post a link to this RRS L bracket that could be used with the Metabones adapter....but then all I can think about is having that mess to deal with when I'm hand holding the camera.
https://www.fredmiranda.com/forum/topic/1247661/55#11945213
Plus I'm just adding more weight to the mount (granted I guess it's not much and it's close to the mount anyway.)
So I'm asking what others thoughts are. I assume others have more experience in this area....or are asking themselves the similar questions. The a7R is supposed to have a sturdier mount, or at least it appears that way based on some of the design differences between the a7 and a7R. Just looking for some informed advice at this point. Do you think the a7R with L bracket will suffice for the lenses I list above?
-Tim
Nov 20, 2013 at 07:16 PM
lostinjapan
Details
p.1 #2a7R/Metabones Combo and Tripod Mounting
So far with the grip attached, I have had to mount the camera to the tripod. The a7r 's mount seems strong enough to hold both the lenses and adapter. Though I would prefer to use the adapters mount instead. I wonder if that RSS bracket would work with the grip attached? That would solve my problem.
Ryan
Nov 20, 2013 at 07:30 PM
tsdevine
Details
p.1 #3a7R/Metabones Combo and Tripod Mounting
Thanks Ryan. Luckily with only EF mount glass I can just use the Metabones mount until I figure out what to do long term. I don't know if that L bracket would work with the adapter attached. We're all blazing new territory here.
-Tim
Ryan
Edited on Nov 20, 2013 at 07:54 PM · View previous versions
Nov 20, 2013 at 07:36 PM
tsdevine
Details
p.1 #4a7R/Metabones Combo and Tripod Mounting
Thanks Rich...here are the stats.
Zeiss 15mm ZE - 28.92 oz (820 g) and 5.31" (135 mm)
Sigma 35mm - 23.46 oz (665 g) and 3.70" (94 mm)
CV 125mm - 24.34 oz (690 g) and 3.47" (88.2mm) - but fully extended it's probably twice the length.
Not sure if that's the same L bracket that I posted in my link, I'll check that out. None of my lenses are extremely heavy...but the mount on the Metabones just doesn't install a lot of confidence in me. With an L bracket screwed into the mount, I guess I feel it's more secure.
But I would love to just use the L bracket on the camera like I do with all my other cameras.
-Tim
naturephoto1 wrote:
tsdevine wroteI think there has been a smattering of discussion about this in some other threads, but I thought this might be worthwhile others (and me) to have a thread about this.
-Tim
Tim,
I don't know the weight of the CV125 much less its length.
I would definitely get the RRS L Bracket when it comes out. I use my RRS L bracket for my Fujifilm X-E1 with my smaller Leica R lenses. Anything of any consequence larger lacking a rotating collar (like my 35-70mm and 80mm-200mm Vario Elmar zoom lenses, 100mm f2.8 Apo Macro Elmarit and my 180mm f3.4 Apo Telyt) I rely on the Novoflex Rotating collar for the Novoflex Leica R to Fujifilm X camera adapter. I will use the same set-up for my larger Leica R lenses lacking a
...Show more →
Nov 20, 2013 at 07:53 PM
Admin
Details
p.1 #5a7R/Metabones Combo and Tripod Mounting
The current RRS L-bracket for the 5DIII or 6D works fine with the Metabones adapter tripod mount when used with the Nex-7 with my EF and TS-E lenses.
And yes, the system feels well balanced with the L-bracket attached to the adapter tripod mount.
I'm not sure how it will work with the A7R or A7R + Grip though.
Nov 20, 2013 at 07:55 PM
naturephoto1
Details
p.1 #6a7R/Metabones Combo and Tripod Mounting
But I would
...Show more →
-Tim
Tim,
I would definitely get the RRS L Bracket when it comes out. I use my RRS L bracket for my Fujifilm X-E1 with my smaller Leica R lenses. Anything of any consequence larger lacking a rotating collar (like my 35-70mm and 80mm-200mm Vario Elmar zoom lenses, 100mm f2.8 Apo Macro Elmarit and my 180mm f3.4 Apo Telyt) I rely on the Novoflex Rotating collar for the Novoflex Leica R to Fujifilm X camera adapter. I will use the same set-up for my larger Leica R lenses lacking a lens collar with the appropriate Novoflex rotating collar.
For you with the Metabones adapter you may want to look at this L bracket and if need be discuss it with RRS:
http://reallyrightstuff.com/ProductDesc.aspx?code=BEA2-L&type=0&eq=&desc=BEA2-L%3a-L-Plate-for-NEX-Mount-Adapter
http://reallyrightstuff.com/mmRRSNET/Images/gallery/BEA2L-front.png
Rich
Tim,
I am not sure. All of those lenses weigh a fair amount more than the camera body which is 407g = 14.36oz. I would think that would put a lot of stress and possibly flex the mount of the camera, but we will have to test them on the camera.
Rich
Nov 20, 2013 at 07:59 PM
tsdevine
Details
p.1 #7a7R/Metabones Combo and Tripod Mounting
Thanks Fred and Rich. I guess the do nothing approach right now will force me to use the Metabones mount. When it gets to the point I pickup a native lens, maybe I'll know more. Even if I had the grip, it doesn't seem like it would solve anything. If I mount using a camera + grip L bracket, it would put stress on the grip and then it comes down to how much stress got transferred to the camera. Using the grip but mounting the Metabones would mean more weight on the camera side, basically both camera and grip suspended in mid air by the mount.
If the 5D III and 6D bracket fits like you say Fred, I wonder if my old 5D RRS bracket will fit. I haven't shot it for eons since picking up the 5D II. Now adding the a7R it will be really relegated to the back burner.
-Tim
Nov 20, 2013 at 08:09 PM
Scott Stoness
Details
p.1 #8a7R/Metabones Combo and Tripod Mounting
...Show more →
Tim - I am wondering the same thing and will buy an L plate for the metabones adapter. I don't want to stress the adapter and have it deform and cause lack of sharpness. I might just buy a generic L plate. I will likely test it this week if the camera comes in.
Nov 20, 2013 at 08:20 PM
tsdevine
Details
p.1 #9a7R/Metabones Combo and Tripod Mounting
Thanks Scott. The adapter Rich posted with the L bracket looks secure. The mount on the Metabones is so small, I wish there was more "beef" to it. I think I just have to get over it.
Nov 20, 2013 at 08:21 PM
dbehrens
Details
p.1 #10a7R/Metabones Combo and Tripod Mounting
I'm in a similar boat. I have a bunch of SLR alts either modified or adapted to Canon. One lens I really want to use is the C-Y Zeiss 100-300 at 925g - but this lens does not have a tripod foot. So I either need to purchase an adaptable tripod foot (cheap and I'm told it will sacrifice about 100-125mm on the zoom movement), rely on a strong tripod foot that is attached to the adapter (Metabones) or bite the bullet and buy a Novoflex + tripod collar ($350). As much as I hate doing it I think I would prefer the Novoflex setup.
For L-bracket I'm looking at JTec. I contacted them and they think their universal bracket will be the solution and should be posting something soon on their web page. Then I need to decide if I go with the battery grip or not.
Dave
Nov 20, 2013 at 08:24 PM
lostinjapan
Details
p.1 #11a7R/Metabones Combo and Tripod Mounting
I am wondering if somebody can design and L plate as a complete replacement for the mount on the Metabones adapter. The mount on the adapter is removable, held in place by two screws (the kit comes with allen wrenches as well as two rubber plugs to use if the mount is removed). That would probably be quite a bit stronger than attempting to attach an L plate to metabones adapter plate.
Ryan
Edited on Nov 20, 2013 at 08:35 PM · View previous versions
Nov 20, 2013 at 08:31 PM
tsdevine
Details
p.1 #12a7R/Metabones Combo and Tripod Mounting
Thanks Dave, I'm hoping as more of these camera get in people's hands that we get some more decent options.
I've never been a battery grip person (sounds odd, but it seems like there are two camps....love them, or hate them.) I realize that it would provide the mass to better balance some of my larger lenses, but then when you add the L bracket for the grip/camera (for native mount lenses) and an L bracket for the Metabones, it seems like it will actually be heavier (and almost as large) than my 5D II/RRS solution I have now.
I wish the Metabones mount was more like the Novoflex.
-Tim
naturephoto1
Details
p.1 #13a7R/Metabones Combo and Tripod Mounting
...Show more →
Dave,
As we have mentioned though in your case if you get the Novoflex Leica R to NEX and the Contax to NEX adapter you can use the same rotating Novoflex collar. So, the collar cost is distributed between both adapters.
Rich
Nov 20, 2013 at 08:37 PM
Admin
Details
p.1 #14a7R/Metabones Combo and Tripod Mounting
I have tried this small L-bracket from RRS:
http://reallyrightstuff.com/ProductDesc.aspx?code=BFT1-L
It was made for the Nikon lenses but I thought it would work well for the Metabones. It works fine with regular EF lenses but not with the 17mm and 24mm TS-Es. (Restricted shifting, hard to operate knobs)
I'm thinking that the best L-bracket for the Metabones tripod mount would be a universal type.
Fred
Nov 20, 2013 at 09:15 PM
wkhc168
Details
p.1 #15a7R/Metabones Combo and Tripod Mounting
Since this is a Metabones thread I hope you don't mine I ask a Metabones question even though it is not tripod mount related. I think I know the answer to this but I just want to confirm with folks who has experience with Metabones adaptor.
I have a first generation Metabones EF to E mount adaptor that I used with my Nex7. I wonder if it would work with the A7r? I only need to control the aperture and I don't care about the AF. I looked at pictures of the V1 vs V3 and I noticed there is a big difference on the inside of the adaptor, the V1 has a much smaller opening, almost like a rectangle while the V3 has a much bigger opening. I wonder if that is needed to support full frame. I really don't want to have to shell out another 3-4 hundred bucks again just for an adaptor.
Nov 20, 2013 at 09:26 PM
Jeff Kott
Details
p.1 #16a7R/Metabones Combo and Tripod Mounting
Dave
Just to be clear it's the JTec Mini Universal that they are pretty sure will work with the A7/A7r. I posted this in another thread. JTec said they are trying to design their L plates so you don't necessarily need to buy a new one each time you get a new camera.
http://jtec-online.com/universal-L-bracket-mini.html
Admin
Details
p.1 #17a7R/Metabones Combo and Tripod Mounting
This inexpensive universal L-bracket should work well with Metabones tripod mount. I just ordered one to try:
http://www.amazon.com/Desmond-DAL-1-Release-Compatible-Camera/dp/B00AR04OI2
Nov 20, 2013 at 09:28 PM
Admin
Details
p.1 #18a7R/Metabones Combo and Tripod Mounting
...Show more →
Only the Metabones Mark III will work with the full frame A7, A7R.
Nov 20, 2013 at 09:33 PM
tsdevine
Details
p.1 #19a7R/Metabones Combo and Tripod Mounting
Let us know what you think when you get it.
-Tim
jhenderson0107
Details
p.1 #20a7R/Metabones Combo and Tripod Mounting
I purchased the Smart Flex L bracket to use with the A7r and my Canon tilt-shifts. I usually shoot from a tripod equipped with a cube, so I attached an RRS BP-CS plate to the underside of the Smart Flex so that it can clip into the quick release bracket on the cube.
The Smart Flex features an integrated quick-release clamp which grips the Metabones adapter directly and allows rapid changes in camera orientation. None of the camera or TS lens controls are obstructed during use.
Edited on Nov 21, 2013 at 10:36 PM · View previous versions
Nov 20, 2013 at 11:26 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
