With the revelation that a lot of m-mount lenses on the Sony A7(r) may be a bit of a disappointment to some people and others wanting WA autofocus lenses I thought I would take a closer look at A-mount lenses that can work on the camera with full autofocus through the LAE4 adapter that Sony makes. These lenses are all screw drive AF so won't work with the LAE3. By the way B & H has the specifications on the adapters and the LAE4 weighs 160g and the LAE3 weighs 110g (both noticeably lighter than the adapters for NEX). OK what lenses are out there:
Wide Angle:
Minolta 20mm f/2.8 and Sony 20mm f/2.8 - these seem to be exactly the same lens. They have 10 elements in 9 groups, just like the last generation Minolta MD 20 f/2.8 upon which they seem to be based. They weigh 285g and have a floating element. You can find measured MTFs for this lens (well the Minolta version) at the old photodo sight. Here is a link: http://www.photodo.com/lens/Minolta-AF-20mm-f28-712/images
Minolta 24mm f/2.8 - This lens has 8 elements in 8 groups, just like the last generation MD 24 f/2.8 upon which it seems to be based. I had the MD lens that I used on film. You have probably seen samples with the lens. The corners show some weakness and that will probably be obvious on full frame, but this may very well be a decent lens. It weighs 240g and has a floating element. It too has measured MTFs at the old photodo sight: http://www.photodo.com/lens/Minolta-AF-24mm-f28-713/images
Minolta 28mm f/2 - This lens has 9 elements in 9 groups just like the last generation MD 28 f/2 upon which it seems to be based. I had the MD lens and it was one of my favourites and one of the best all around 28mm lenses I have found. It was great close up with a bokeh that could be a bit sketchy wide open, but stopped down just a half a stop the bokeh was beautiful. It was quite sharp as well. The MD lens had a floating element and I would think the AF lens probably does as we'll, but I haven't been able to verify that. It weighs just 285g and got a photodo score of 4.1 here are the measured MTFs: http://www.photodo.com/lens/Minolta-AF-28mm-f2-714/images
Minolta 28mm f/2.8 and Sony 28mm f/2.8 - these seem to be the same optical formula. Both lenses have 5 elements in 5 groups like the last generation MD lens on which they seem to be based. They don't have a floating element like the other wide angles described above and the MTF isn't quite as good as the 28 f/2, but this is a pretty small lens at just 185g and still a solid performer. Here is the measured MTFs: http://www.photodo.com/lens/Minolta-AF-28mm-f28-715/images
Minolta 35mm f/2 - With the excellent FE mount 35mm f/2.8 there may be little market for this lens, but it was a solid performer. It has 7 elements in 6 groups and may have a lineage from the last MD 35mm f/1.8 that I had and liked very much (the MD 35 f/1.8 had 8 elements in 6 groups however). It does not have a floating element and weighs just 240g. It got a photodo score of 4.0 and the MTFs can be found here: http://www.photodo.com/lens/Minolta-AF-35mm-f2-717/images
For those who want AF these lenses are less than perfect, but they do offer IMO at least a good stop gap if not a viable alternative. I was a fan of the 24 f/2.8, the 28 f/2 and the 35 f/1.8 manual focus lenses when I had them and I think there is good reason to hope these lenses retain the character those lenses displayed. For those who want it I can also see a pretty capable and fairly small moderate aperture 3 lens kit. IMO, the Minolta 28 f/2, the Zeiss FE mount 55 f/1.8, and the Minolta 100 f/2 (which by reputation is an absolutely fabulous lens and got a photodo score of 4.4) would make a very nice set.
The only classic Minolta lens mentioned that's probably a must is the 100/2. It's amazing. The other F2's, 28 and 35 are good but don't expect anything close to flawless. The FE 35 2.8 is going to be dramatically better than either of these two (and probably within $300 or so of what you can get the older Minolta's for). The 28/2 is going to show CA towards the borders/ corners and the 35/2 will be tack sharp in the center but never fully sharpen up critically at the borders/ corners. That was my experience with them on the A900/ FF 24MP's. The A7r would just amplify the flaws. Even the ZA 24/2 is not perfect into the corners and there is a lot of sample variation/ decentering prevalent with that particular lens sample to sample (as I went through a few of them myself).
Tariq, I am sure that your assessment is correct, but some may be willing to put up with the flaws for AF or because they are more concerned with the problems that may arise from WA rangefinder lenses particularly if there is smearing in the corners and edges. I also agree that at 35mm the FE seems a tough act to beat, but if it isn't quite fast enough and someone really needs AF, then the Minolta 35 f/2 might fit the bill particularly if they don't care about corners.
Personally from what I have seen at this point, at 28mm I would probably try to get the Leica R elmarit version II, but that lens is way more expensive than the Minolta and a stop slower. I think it would do very well both close ups and at infinity, however. And at 35mm I would be fine with the FE f/2.8 for infinity shooting and if I wanted a wider aperture I would go with the m-mount Voigtlander 35mm f/1.2 which looks to do just fine with these cameras and really isn't that large for an f/1.2 lens.
Personally from what I have seen at this point, at 28mm I would probably try to get the Leica R elmarit version II, but that lens is way more expensive than the Minolta and a stop slower. I think it would do very well both close ups and at infinity, however. And at 35mm I would be fine with the FE f/2.8 for infinity shooting and if I wanted a wider aperture I would go with the m-mount Voigtlander 35mm f/1.2 which looks to do just fine with these cameras and really isn't that large for an f/1.2 lens....Show more →
Well if we can't get the 28mm Leica M RF lenses to work well with the A7r, and if we find the Leica R f2.8 Elmarit V2 does work well with the camera I may bite the bullet and buy one. Of course like others I am hoping that my Minolta CLE MC 40mm f2.0 Rokkor-M (or the Leica C 40mm f2.0 Summicron) will work well. That would leave me with just getting a 21mm lens.
Yeah, the two Minolta wide angle F2's are fine lenses. The 35/2 in particular is rare and can be difficult to find. Neither are plentiful. The value proposition is not very high with either if they are still going for between $450-650 or so given what is a fairly large performance delta (not just sharpness but aberrations) with the native FE 35 (it has been a while since I have shopped for either so perhaps the prices are different now). I don't know how fast the 35 FE is on the A7r so I guess that might come into play for some.
Leaving AF aside, the Leica 28/2.8 II is as heavy as the forthcoming Zeiss 24-70 zoom at 435 grams, and it is overpriced due to reputation and scarcity. Very good though.
I like the CY Distagon 28/2.8 at 280 grams, its drop off is orderly but lacks good corners presumably due to curvature, which you get back off plane. Its centre is as good as the 21mm of the same family, and better than the Leica in that respect. Good price too.
The ZA 24mm is 555 grams and needs the heavier LA-EA4 adapter but has AF - but 700 grams all up. Briantho showed this one against the CY Hollywood recently on NEX - very sharp all the way through the scene but I preferred the CY, a familarity bias I suppose. They were close though.
Some like the AIS 28/2.8 as well, and the 28/2 AIS is also good, these lack the micro-contrast of the CY/L IMO. The 570 gram ZF 25/2 is very good until extreme corners.
PS I am most keen to see the Zeiss FE zoom at 24mm. You cannot even find MTF for it AFAIK.
philip_pj wrote:
Which set of compromises is best?
PS I am most keen to see the Zeiss FE zoom at 24mm. You cannot even find MTF for it AFAIK. ...Show more →
From what I understand, the MM version of the CY 28mm f2.8 Distagon is the best with a different design to the previous version.
I have owned a few CY 28 2.8's over the years. The first one was amazing (contrast and sharpness) on the original Canon 5D, though it did show some nasty CA in tricky backlit situations. The second one was "tested" by the A900. I suspect the 36MP A7r might be too much for this lens to handle but I'm curious to see what people find.
I suspect we will find that many lenses that were considered amazing performers previously all of a sudden look fairly average on the A7r.
If you don't care for auto-focus, i would not ignore the Nikkor 28/2.8 which has a floating element. There use to be the occasional picture out of this lens posted to FM forum but it seems that the forum has mostly become Leica/Zeiss.
Other candidates include the olympus 28/2.0; 24/2.8/ and 21/3.5
i've had the 20/2.8; 24/2.8, 28/2 and 35/1.4. the only lens i still have is the 35/1.4
the 20/2.8 never really shined, the 24/2.8 i neglected since i had the 20 and 28. the 28 had great colour, but dizzying bokeh wide open. in hind sight it was awesome how small the 24 & 28 were though.
I had the CY 28 f/2.8 and it had very high micro contrast and I liked the lens a lot, but it had more CA I cared for and than the Minolta MD 28 f/2 which wasn't free from it either. I shot both on the 5D classic and I suspect with the higher megapixels the CA from the CY will be quite noticeable. Yeah the Leica R elmarit II is heavy, but it isn't that large of a lens. Still your point is valid IMO, it is heavy and overpriced. I never warmed up to the Nikkors, but the close focus of the 28 f/2.8 has always intrigued me, but at infinity I think it won't fair that well. So yes, there are compromises all around and until there are lenses built for the system we will just have to pick which ones we can live with.
I've been weighing these SLR options at 28mm too: I think if I found a small one that I liked, I wouldn't need to go wider than that on an A7R. It's too bad the CV 28/2.8 SLII doesn't seem to hold up in the corners: the form factor is perfect. Likewise, even though the Oly 28's are tiny, every comparison I've seen against the C/Y or Nikkor seems to have the Zuiko coming up a bit softer. Up until this thread, I was thinking I'd wait for a good copy of the C/Y, as it's a bit shorter than the Nikkor and the word seems to be it's better at infinity, which is how I'd use this lens. Now I'm thinking if the Nikkor is significantly cheaper, maybe I'll just get that to tide me over till a native 24-28mm comes out (could be a while). I also have a Rokkor 24/2.8 that I like, but don't know if it'll hold up to 24MP, let alone 36.
I'm lost! Either that or any conclusions arrived at seem to change depending on the time of day and level of the tides. Here's my question:
Are there any solid performers identified in the focal length area of 20 to 25mm? Or at least highly usable performers?
I would really like to have something in that range in hand with my A7r shows up and I don't care what mount (RF M mount or SLR mounts) or about sub-micron tolerance issues with adapters and other such concerns. At this point I'm ok with picking the best of the "good enough" lot , feeling it'll easily out-do waiting for "perfect" for now.
