Archive 2012 · Ring Flash vs. Beauty Dish
sskoutas
p.1 #1 · Ring Flash vs. Beauty Dish
I'm starting to give some consideration to my next modifier purchase. I currently use umbrellas, soft boxes, and grids for the most part. I'd like to get a "fashion" modifier, and I'm therefore leaning toward a ring flash or a beauty dish.
If I understand their primary uses correctly, both are typically used very near the lens (the ring flash is obviously surrounding the lens, and the beauty dishes seem to be used frequently in line with the lens, perhaps just above camera for a wash of light and limited shadow.
Tell me if I'm wrong in my understanding, please.
Assuming I'm right, they seem like similar tools. Is there any great advantage of one over the other? Are the results similar (with the exception of the catch light)? And if you could only have one, which would you select?
Thanks in advance for any help you can provide.
Jan 30, 2012 at 09:17 PM
BrianO
p.1 #2 · Ring Flash vs. Beauty Dish
sskoutas wrote:
I'm starting to give some consideration to my next modifier purchase. I currently use umbrellas, soft boxes, and grids for the most part. I'd like to get a "fashion" modifier, and I'm therefore leaning toward a ring flash or a beauty dish. ...If I understand their primary uses correctly, both are typically used very near the lens (the ring flash is obviously surrounding the lens, and the beauty dishes seem to be used frequently in line with the lens, perhaps just above camera for a wash of light and limited shadow. ...Assuming I'm right, they seem like similar tools.
...Show more →
I wish Shatterkiss were still a member here; he could give you an excellent tutorial on the similarities, differences, and advantages/disadvantages of each of them.
Briefly, though, a ring flash gives a near-shadowless light to the subject. A beauty dish can be moved around the subject to cast its light from different angles, and so can create modeling shadows.
A beauty dish works a lot like a soft box, but of course is round and rigid. Another difference is that the beauty dish has an opaque disk in the center that can be used, for exampe, to keep from overexposing the forehead (which may be closest to the dish) while giving proper exposure to the rest of the face. While the ring flash is obviously used very close to the lens, I think it's more accurate to say a beauty dish is often used very close to the subject (but not exclusively so).
If I could only have one of the two, I'd probably go with the ring flash because it can be taken off the lens and used like a beauty dish, but a beauty dish can't be used as a ring flash. (In truth, though, I have a beauty dish now, but don't yet have a ring flash; that will change this year.)
Edited on Oct 18, 2019 at 01:38 AM · View previous versions
Jan 30, 2012 at 09:33 PM
cgardner
p.1 #3 · Ring Flash vs. Beauty Dish
Ring flash is shadowless light, typically used in fashion and glamor where the lighting just serves as a "blank canvas" for the make-up artist to paint on the highlights and shadows. It can also be used any time a flat "deer in the headlights" look is need or for near totally shadowless fill flash. The downside are the unnatural O shaped catch lights, unless you are going for an otherworldly look in the eyes. Paul Buff (Alien Bees) sells a ring flash / softbox combination it called a MoonUnit. it can be used around the lens or like a conventional soft box off axis.
As BrianO mentions the Dish creates a "hole" in the pattern which is ideal for lighting full face butterfly pattern without blowing up the forehead by aiming the dark center there. That allows it to be moved very close, which causes very rapid fall off on the sides of the face. The hole in the middle of the pattern disappears as it is moved further back. I use my 22' dish with a sock diffuser as my fill over the camera. The flat shallow shape spills light off ceiling and walls in my home studio creating a nice wrap around spill fill effect in addition the nearly shadowless light (as seen from camera) fill light hitting directly.
A beauty dish can't be used exactly on-axis but due to its compact size it can be placed very close to the lens.
Jan 30, 2012 at 11:47 PM
stuuke
p.1 #4 · Ring Flash vs. Beauty Dish
What happened to Shatterkiss?
Jan 31, 2012 at 12:19 AM
BrianO
p.1 #5 · Ring Flash vs. Beauty Dish
As I saw it, too many pseudo-experts would come on and argue with him or otherwise stick their noses in when he was trying to help people, and he just decided he'd had enough. It wasn't worth his time, I guess, to offer free advice and then have to defend it.
Too bad, because as far as I'm concerned he really knew his stuff and was good at explaining it in layman's terms.
Jan 31, 2012 at 12:59 AM
Steve Wylie
p.1 #6 · Ring Flash vs. Beauty Dish
Respectfully, if I had to choose one or the other, I'd go for the dish, rather than the ring. You can get a ringflash off axis, but I think the beauty dish is much more flexible than the ring in terms of placement and variation of use.
Jan 31, 2012 at 02:13 AM
mikethevilla
p.1 #7 · Ring Flash vs. Beauty Dish
Beauty Dish (among other things, but it's the main light):
http://www.blog.mikevillavisuals.com/wp-content/uploads/2011/12/Victoria-2948.jpg
Ring Flash with "moon unit" softbox:
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/317189_2210997366920_1607070082_32210069_1302586819_n.jpg
Of course you can use the ring flash off camera, but if that's your main use for it you're better off getting an octobox as it's likely the cheaper solution and will give nearly identical results.
Jan 31, 2012 at 02:24 AM
rico
p.1 #8 · Ring Flash vs. Beauty Dish
I don't own a ring light, but it sure fills nicely (just don't allow it to cast its shadow on the wall ). The catchlight is one aspect I can't get over, however, and the reason I go with a BD. The latter can be used either close to the camera or well off-axis, and give that magical hard/soft effect. The catchlight is quite pretty with an opal glass diffuser (if the option is available). The Profoto BD was my first modifier, and I replaced the opaque diffuser disc immediately.
Jan 31, 2012 at 04:27 AM
Mark_L
p.1 #9 · Ring Flash vs. Beauty Dish
Ring flash is an expensive and very specialised tool, it's the cool thing to have right now so that is why you see a lot written.
A BD is much more useful and the staple of beauty photography, some photographers almost solely use one for their main light (see Emily Soto). Its sort of in-between a mini-octa and a reflector.
Jan 31, 2012 at 07:36 AM
dmacmillan
p.1 #10 · Ring Flash vs. Beauty Dish
This is an all too familiar story. It's sad. There are many people with experience who would share their hard earned expertise but can't get a word in edgewise. It's a loss for the community.
I concur that a BD is more versatile than a ring flash. It would buy it first. Also, be aware that you get what you pay for, there's a specific shape involved and it affects the quality of light. Don't scrimp and get a cheap "looks like a BD".
Jan 31, 2012 at 09:52 AM
cgardner
p.1 #11 · Ring Flash vs. Beauty Dish
Want to know what Shatterkiss is up to nowadays? Just Google "Shatterkiss".
There aren't many successful professionals who earn 100% of their income from photography who hang out here regularly for the simple reason they are busy earning a living. Also Twitter, Facebook and simple to use blog hosting has also changed the paradigm. Most who become known well known enough to attract a following find it more efficient use of their time to use those social networks instead of this older and inefficient format which is modeled on Compuserve and the usenet forums of the 80s and 90s. I would lay odds that went down the list of threads on page one today that 95% of the questions have been asked, and answered 100 times before usually by the same handful of regulars who hang out here every day to answer them because on some level they like helping people learn and avoid mistakes they made, evidenced by the huge pile of old photo gear in the closet.
Fred wisely separated the "show my photos" and "talk about gear" forums here, so Lighting Technique isn't where you go to see how the tools are used by people like Shatterkiss, but rather to learn the cause and effect of how the tools work — which is mostly basic physics and common sense. If you hang out in People, Weddings, Landscape etc. and see someone's work you admire odds are nowadays they will have a blog.
The technical side of photography is more a trade like plumbing than a profession in the way that law or medicine are. The notion of Professional photographer with a capital "P" was the result of some very effective PR by the trade association most wedding and portrait photographer joined in the 50s and 60s, the Professional Photographers of America. I joined PPofA as a student while in college in 1971 to get window on the profession.
http://super.nova.org/TP/PPAmag1.jpg
http://super.nova.org/TP/PPAmag2.jpg
Two years later that same magazine published an article I wrote about my experience apprenticing with Monte Zucker. Did the fact Zucker wrote a monthly column have anything to do with me getting that article published? Hell yes. But joining PPofA and reading that column of his is how I knew how he was when I saw a help wanted ad he placed in the Washington Post in 1972. That same year I entered my first PPofA print competition at the Maryland state convention where Jay Maisel was guest speaker and judge and won third place, first place in the "Creative" category with the third place shot (gigged technically for retouching that showed up under the exhibit lights) winning the award for most creative across all categories.
The first place shot was this now faded "C" print of a big Clematis flower on a fence in Zucker's front yard I shot to have something to enter. I shot it on Ektachome but at the recommendation of the manager of the photo lab that was one of Monte's sponsors had a 4" x 5" internegative made to make the 16 x 20 print to avoid grain and enhance sharpness...
http://super.nova.org/TP/1973_FirstPlacePhoto.jpg
What I learned from Jay Maisel (Google him) and the others on the panel afterwards was it won 1st place because of the composition of the vine. If you look close between the V of the petals on the top you'll see the staple I used to create it. In case of selective tunnel vision I hadn't noticed it when shooting or in the print — until it was under the bright competition lights. Fortunately the judges didn't notice it either. The photo that won third and best in show was this one, matted as shown below with the title "Stand Up"...
http://super.nova.org/TP/1973_BLKPwr.jpg
I had shot that the previous year at college of an actor on stage using Kodak High Speed Recording film I'd found in the local Galesburg, IL photo shop and decided to experiment. It was what police used for low light surveillance in the days before night vision...
"Kodak 2475 Recording Film (RE 135), catalog number 163 2033, is described as an: "extremely high-speed, panchromatic film with extended red sensitivity. It is especially well suited for applications requiring low level illuminations or short-duration exposures such as law-enforcement photography". It is a black and white negative film with a nominal ISO of 1000. It is both fast and quite grainy." It could be pushed to ISO 2000 - 4000.
When processing the film I mis-loaded it in the processing real and the corner of that frame got stuck another part of the roll. I should have just run it through the fixer again to remove the undeveloped stuck spot but in my ignorance at the time I just scraped it off. Not having a darkroom to make my own B&W print for the competition I sent it to a lab for a print which didn't follow the instruction to burn in and hide the defect in the corner. With no time to reprint I was forced to fix it with retouching dyes, which I did routinely on our color prints, and that's what the judges saw under the lights. As it turned out it was the very last print judged and the judges seemed to take an eternity to judge it. I was really pleased it won third place in "Creative" and shocked when the judges also selected is best in show creatively. The long debate at the judges table was whether it's creativity trumped its technical flaws..
I was shooting weddings for a living, so why didn't I enter wedding candids? That's what I did for a living, and it wasn't very creative. The photos I entered represented what I did creatively for fun. Why did they win? In large part because of what I learned from Zucker about composition and based on his experience judging competitions like that what judges looked for and rewarded — something that was different from all the kids photos and wedding candids in the competition.
All of that is a fading memory in the rear view mirror. By the following year I decided shooting weddings or running my own business wasn't something I was interested in doing so I move to the reproduction side of photography for a living and pictorial photography became a hobby. Did I stop taking photos, buying gear and experimenting? No. In 2004 I bought a set of studio lights I really didn't need in part so I could give more balanced and objective advice based on first hand experience of the relative merits of speedlights (which I'd long advocated for hobbyists) vs. studio lights and share comparisons like this one of speedlights vs. studio lights ...
http://super.nova.org/TP/DIYvsSB.jpg
Or this systematic comparison of Dish vs circle masked SB I made and posted after getting my AB 22" dish back in 2004...
http://super.nova.org/TP/SBvDish/MedSB.jpg
http://super.nova.org/TP/SBvDish/MedSB_2.jpg
http://super.nova.org/TP/SBvDish/Dish22.jpg
http://super.nova.org/TP/SBvDish/Dish22_2.jpg
In terms of style the speed light vs studio comparison isn't much different than the very first artificial light session I did in high school with 150W bulbs in shop reflectors clipped to step ladders the summer after high school when I bought my Nikon F and 85mm 1.8 lens...
http://super.nova.org/TP/FirstPortraitsSQ.jpg
The "style" and lighting instruction to put fill over the camera came straight out of a 32-page "How To Take Portraits" Kodak book. It was the same configuration Zucker used with dual flash in the 70s an I still use and advice others to use today. Why? Because it's still technically sound and produces quite good results on a very limited budget with unmatched logistical simplicity. But that, or my experience which taught me that aren't obvious when I suggest people by a bracket and learn to get the most out of one flash before trying two and learning out natural lighting creates the illusion of 3D space and shape...
http://super.nova.org/TP/Egg.jpg
... and learning how to do the same with two speed lights...
http://super.nova.org/TP/StillLife1.jpg
... before attempting to do it with three...
http://super.nova.org/DPR/FourLightExercise/LE03.jpg
or four lights:
http://super.nova.org/DPR/FourLightExercise/LE04.jpg
Beyond the examples I've written about 50 tutorials on my web site like this one http://photo.nova.org/FourLightExercise/ which explain what each of the four lights actually do on a cause and effect level. The egg shot above was part of C&C for a guy struggling to understand how to light his pregnant wife without having her look like the the MetLife Blimp. I also drew and included this diagram...
http://super.nova.org/TP/Maternity.jpg
Why bother? What goes around comes around in life and I enjoy helping people lower on the learning curve improve things I've learned to do instinctively. Yesterday I spend 40 min. teaching a new golfer what a competent efficient and powerful golf swing feels is supposed to work in terms of physics and feel. It's actually quite simple once the cause and effect is understood, sort of like lighting.
In the good old days a person interested in photography went to the library or local photo supply store and bought some books. Today Amherst Media http://www.amherstmedia.com/ which specializes in photography books is an outstanding resource where you can find information on nearly every genre and niche of photography.
After reading books we would get off our asses and try the things they suggested. It wasn't a question of whether they worked, but actually understanding from doing and validating and believing it works. Some things, like neutral fill, often seem like a bad thing based on previous experience when suggested by someone with more experience. I remember being told axis fill was a terrible idea and not creative back in 2002 when I suggested it. Then a few years later Paul Buff marketed a $500 studio ring flash and the same people rushed to buy one even now the OP wants before understanding what its really good for. Suddenly even shadowless fill wasn't such a bad thing. It never was.
Gear and advice on gear has run in cycles like that for years. Flash brackets are coming back in style. At the State of the Union last week I noticed about half the photographers, including Obama's using one. You didn't see that a few years ago.
The learning paradigm has changed to people coming to the internet asking ad hoc out of context questions like: "Will my flash powerful enough to use outside in the sun". Duh, get off your ass go out into the yard with the wife and kids and find out. That's what I did 40 years ago and still do whenever a question I don't have an example to illustrate is asked.
Do I tell them that? No. I patiently explain for the 1,000th time how flash and diffusers work. Why, because I have time to do it because I don't do photography for a living. Do you need to be a "pro" for 5, 10, 20 years for advice to be valuable? No. I bought my Alien Bees vs more expensive brands based on feedback and examples from hobbyist like me. Most of the "pro" features of the more expensive brands I could live without.
Would a ring light be good to have? Yes. Would I use it much as a hobbyist? No. As it turned out I was one of the first to buy Buff's dish when it hit the market and posted my tests. My comparison and write up convinced many — mostly hobbyists — to buy one. Few pros bought one based on my advice because: 1) they used more expensive brands -- dish alone costing more than my AB800 light and dish, and; understood what they are good for and when to use them. I knew in theory from the physics and seeing examples how they worked. The tests I did after buying one validated what I knew and illustrated it for others.
A good "home grown" FM example of how good information can come from unexpected places is Chuck Carino on the People forum who started out about 5 years ago just buying a camera to document his kids growing and posting photos for C&C to improve his skills. Over the intervening years he has developed a distinctive style of capturing real life family events in B&W photos which have a fresh approach and a retro feel at the same time that even in the beginning when his technical skills weren't well developed was distinctive. His "fresh" approach was based on remembering the family photos when he was growing up. He's become a great role model and teacher for new photographic niche —family photojournalism— which he now discusses and teaches via his own blog with his own following. I'm not sure if he has quit the day job yet and gone from weekend warrior to 100% "professional" photographer, but as with a lot of other lines the Internet has blurred is that really important?
So when advice is offered don't judge it by where it appears to come from but by getting off your ass, trying it, and seeing if it works the same way for you.
Jan 31, 2012 at 11:22 AM
Mike Mahoney
p.1 #12 · Ring Flash vs. Beauty Dish
They are actually not too similar at all ..
Any advantage one has over the other depends on the user and the lighting they want ...
No ..
Beauty dish, by a mile .. beautiful light with great flexibility depending on size, distance, placement, grids, socks, deflector, etc.
Jan 31, 2012 at 12:23 PM
dmacmillan
p.1 #13 · Ring Flash vs. Beauty Dish
For those of you who weren't here back then, here's some of his work:
https://www.fredmiranda.com/forum/topic/856116/0&year=2010#8006811
More info:
http://blog.sekonic.com/2009/12/16/simon-gerzina-in-the-sweet-spot/
Too bad he doesn't contribute here anymore. At one time he was pretty active.
Sahid Limon
p.1 #14 · Ring Flash vs. Beauty Dish
Really a shame. He definitely knew what he was talking about, and had a lot of great advice. He helped me with the decision to get my first studio lights 3 years back, and his advice was solid. More and more talented people are driven away from forums like this because of people who think they know better, and it's a shame.
Feb 01, 2012 at 08:02 PM
sskoutas
p.1 #15 · Ring Flash vs. Beauty Dish
I've been here almost 6 years, though less and less lately. The talent and knowledge in here was (and is) incredible. Many, many wonderful people have helped me take my photography to new levels. Every time I need to learn something, or seek informed opinions from people who know... people who are hands-on with the topic I am asking about, this is where I come.
There are many super-talented people who have so much to share. They have saved me countless hours and dollars by putting me in a direction that intersected with my goal, or by directing me toward the right equipment for my needs.
Lastly, this group is very good at keeping me humble. Every time I'm feeling like a know-it-all or a top-shelf photographer, about 5 minutes in these forums lets me know that I've got lots still to learn and a long way to go.
Thank you.
Feb 01, 2012 at 09:01 PM
sskoutas
p.1 #16 · Ring Flash vs. Beauty Dish
I noted the advice above that you get what you pay for. That said, my flash heads are all Alien Bees. The Buff Beauty Dish seems rather inexpensive compared with other manufacturers. I realize that could be said of many other Buff products as well, but I did want to ask if anyone has had any experience with this beauty dish and would recommend for or against it. Thanks.
http://www.paulcbuff.com/22hobd-w.php
Feb 04, 2012 at 11:05 PM
surly
p.1 #17 · Ring Flash vs. Beauty Dish
Self proclaimed know it alls stay and helpful, professional knowledge goes. It sure is a shame, FM was better with him.
Feb 10, 2012 at 09:06 PM
Michael White
p.1 #18 · Ring Flash vs. Beauty Dish
Here is what I've observed since 2004 when I got my first DSLR and got on the Internet to see what is going on and to learn stuff mainly post production back then since I've been shooting since the 70's. I've had several photo published in publications that I wasn't shooting for back then..
In 1982 I join the USAF and photography went to the rear of things I could do. From time to time I would grab the camera and do some shooting. I mainly was a available light until about 6 or 7 years ago when I got some studio lights and then shortly later purchased a Canon 580ex2 Speedlite and some Vivitars which I then replaced with more Canon speedlites.
Back on topic. In2004 everything was being done in post vs in camera. Now that everyone is tired of spending all that time behind a computer they are going back to getting everything in camera to save time later.
In the old film days post was done by abs and specialists. Now the photog is doing it. But, several top photos have learned to sub it out to specialists so they can concentrate on shooting the images. I expect in a few years all the top and most of the others will get tired of learning to do post in Photoshop and will either sub it out to digital post production firs or hire a post production expert in house. The photog will shoot the images and run them through the basic stuff you can do in camera raw or Lightroom and select the final images and send them over to a post production and they will send the images back for approval and then they will be sent to a lab for printing. This work flow will represent the same as was used for film. The reason for this is it is the best way to get the best results.
What you will find is new photog looking for work will fall in to four categories. They are shooter, retouched/post production, grip/assistant and printer. Where the individual ends up will depend on his talents and job openings. This will open more jobs since everyone will specialize in to one of those four areas. It is not to say that if you are hire as an assistant and get your name known as a excellent assistant and find job and have interest as a retouched you can't switch specialties or in a small studio you may be required to do more than one job. If there is a shoot you assist or be a second shooter. Then afterwards your required to do te post ad or print in house.
Get off the computer and grab the camera and shoot something.
Feb 11, 2012 at 02:03 AM
Michael White
p.1 #19 · Ring Flash vs. Beauty Dish
Also, I learned a lot from Chuck. It was his tutorials on the Canon speedlites and their wireless system that made it klick. Before that I had read several other how tos and they didn't make sense to me. I also like some of his other tutorials on lighting. I went thru all of his tutorials and feel I'm a better photog because of it as I picked up several things that I had either forgot or didn't know to begin with.
And to work with one of the great portrait photographers is great. How much you can learn by just assisting and doing the tasks over and over then to be able to ask why it is done that way on top of it all. I'm sure the setup was the same from one location to the next. I'm sure they had a setup for general portraits, another for high key and another for low key. But it is possible to do it all from the same setup by changing the background or changing the distance to the background and or lighting it. Because a white background can be shot as three or more different back grounds. Light it really bright and you got high key. Let the light from the portrait subject hit the bg and you got a grey bg, don't let any light hit it and you got a black bg for low key. Add a gel to the bg lights and you can tint it te color of the gel.
Feb 11, 2012 at 02:29 AM
Sid Ceaser
p.1 #20 · Ring Flash vs. Beauty Dish
He's been doing a lot more video and he's really busy and doesn't have the time to spend on the forums any longer.
I saw him about a year ago - he was in my town for a 1 day video job and needed an assistant so he rang me up. It was great catching up with him.
He's been moving between three offices, one in NY, one in Cali, and one in England. Plus with his little one, he just doesn't have the time.
Cheers,
Sid
Feb 13, 2012 at 10:13 AM
