fredmiranda.com Login
This topic is in the 2011 archive. You can read it and like its posts here. It is read only.
Archive 2011What's this, coating problem? Any remedy (Rokkor 58/1.2)?
wfrank
p.1 #1What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Just received a long awaited Rokkor 58/1.2 to use on a 5D2 and NEX 5N. It's overall in very nice condition, little signs of wear and glass is clear, no scratches and almost dust-free but... there are some blemishes close to the edge of the front element. It's only visible from certain angels. I'm pretty sure it's on the back-side of the front/foremost lens. I imagine it does nothing bad for the IQ, but it's annoying. Looks almost like old dried out oil/lubrication.
Anyone knows what it is, and would it be easy to remove by taking apart and clean?
Crop:
Dec 15, 2011 at 01:52 PM
HerbChong
Details
p.1 #2What's this, coating problem? Any remedy (Rokkor 58/1.2)?
that sort of looks like element delamination.
Herb....
Dec 15, 2011 at 02:13 PM
Keith B.
Details
p.1 #3What's this, coating problem? Any remedy (Rokkor 58/1.2)?
If it is delamination, as has been supposed, I'd guess that it'd cost in the multiple hundreds, if not a thousand dollars to have an optical shop separate and then re-cement the elements together. I'm fairly confident that you'll never, ever be able to design or execute a test scenario where that 'defect' could be shown to affect the imaging performance of the lens. Go make some pictures.
Dec 15, 2011 at 02:33 PM
sebboh
Details
p.1 #4What's this, coating problem? Any remedy (Rokkor 58/1.2)?
the front element is not part of a cemented group, so if it is on the back of the front element it is not delamination. the front element is fairly easy to remove if you have a spanner wrench or rubber cup and the guts to examine it wide open so to speak.
Dec 15, 2011 at 02:39 PM
Tariq Gibran
Details
p.1 #5What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Could be lubricant which has worked it's way to the back of that element. I completely disassembled one of these to clean and adjust it once and noticed a lot of lubricant which appeared to have broken down to an oily liquid over time.
Dec 15, 2011 at 03:27 PM
LightShow
Details
p.1 #6What's this, coating problem? Any remedy (Rokkor 58/1.2)?
My guess is cleaning solution that had oils dissolved in it leached around to the other side then evaporated leaving the oils.
http://www.rokkor-x.narod.ru/user_manuals/rokkors_schems/
http://www.rokkor-x.narod.ru/user_manuals/rokkors_schems/Minolta_MC_Rokkor_58mm_f1.2.gif
Dec 15, 2011 at 08:18 PM
HerbChong
Details
p.1 #7What's this, coating problem? Any remedy (Rokkor 58/1.2)?
yeah, it looks more like what Lightshow says now that i have looked at it several times. the coating might be destroyed or it might be intact.
Herb...
Dec 16, 2011 at 10:14 AM
davenfl
Details
p.1 #8What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Anytime you are seeing multiple colors like that some sort of oil is involved. No doubt it is dried lubricant and definitely not delamination. I would leave it along unless it starts to grow at which point something is leaking and deassembly and cleaning is warranted.
Dave
Dec 16, 2011 at 10:42 AM
Gunzorro
Details
p.1 #9What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Dave -- It is incorrect that oil (or other liquid films) is always the culprit of these effects. Please see the reference here on "Thin-film Interference", or wiki/google for yourself. This is the effect common in delaminated lens surfaces. http://physics.bu.edu/~duffy/py106/Diffraction.html
Wilhelm -- I believe you are seeing element delamination. I have a Mamiya RB 50mm "C" lens that suffers this, to a greater extent. Because of this defect, I only paid $50 for the lens four years ago, before prices plummeted. So, I have never bothered to fix it, as I almost never use it. But if I did, I would repair it or buy another used lens on ebay.
Like a large scratch or gouge, it will lower contrast if struck by intense light. But otherwise, IQ is good. It is an important defect, and you should get some serious money off the purchase price.
I haven't had it done, but this can be repaired, and I believe you will be looking as a few hundred dollars, not a thousand! Check around for quality repair shops. Use as is until then. But try to get a price adjustment.
A side note: I bought a used Mamiya 90mm KL (latest design) for about $60 because it had visible fungus tendrils on the side of an inner element, about the same coverage as your delam. That lens turns out the sharpest images of all my RB lenses (outstanding contrast too!), including undamaged 65mm and 75mm KL lenses! I wish I could rig a cheap digital back to that system!
So, check into repair, but also test in high flare situations and see what you get. Smaller apertures will give best results. f/4 and smaller should be outstanding. Sorry to say, wide open will just compound the existing flare-type softness, and I know you want to shoot a lens like that wide open, or nearly so.
Good luck and keep us posted.
Dec 16, 2011 at 11:25 AM
AhamB
Details
p.1 #10What's this, coating problem? Any remedy (Rokkor 58/1.2)?
@Gunzorro: The front element is not cemented and considering what we see in the picture provided by Wfrank, I'd say that is the element that's affected and not one of the two cemented groups behind it. Most likely it's some oils on the back side of the front element like Lightshow suggested.
Dec 16, 2011 at 01:06 PM
wfrank
Details
p.1 #11What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Thank you all for your efforts, insights and suggestions. Much appreciated!
My conclusion is that it may be some hope for this lens "mintyness" - but the only way to find out is to take the front lens off and try to clean the backside of it. If I manage that, what fluid should I try - some alcohol/etanol solution would be my guess (?).
Repeating my second image and combining with Lightshows lens layout (thanks) it seem possible to just remove the front lens and nothing else (?). There seem to be two rings within the filter thread. There are some "grips" visible in the shot below (yellow). How does a tool look to try to unscrew those (sebboh, you mentioned "spanner wrench", that is that)?
Anyone think that I could be successful in un-screwing those two rings and that the front lens would come off? Really appreciate your input as I've never done this before.
Edited on Dec 16, 2011 at 03:09 PM · View previous versions
Dec 16, 2011 at 02:10 PM
Gunzorro
Details
p.1 #12What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Aham -- Thanks for that info. I agree you are probably right. Hopefully it will be a simple fix for Wilhelm to undertake.
Dec 16, 2011 at 02:12 PM
AmbientMike
[X]
Details
p.1 #13What's this, coating problem? Any remedy (Rokkor 58/1.2)?
It may cause flare in extreme lighting. Also will hurt the value. Will it spread?
Dec 16, 2011 at 02:24 PM
sebboh
Details
p.1 #14What's this, coating problem? Any remedy (Rokkor 58/1.2)?
...Show more →
this thread and it's links should be helpful (i can't view the images now to say how helpful ):
https://www.fredmiranda.com/forum/topic/806552/
it's been a while since i opened mine up, but i think the outer ring holds the front optical assembly and the inner ring holds the front element. i can probably check in a little bit (or it might be on one of the links from the thread above).
this is a spanner wrench: http://www.micro-tools.com/store/P-SP3/Spanner-Wrench-Medium.aspx
Dec 16, 2011 at 04:19 PM
LightShow
Details
p.1 #15What's this, coating problem? Any remedy (Rokkor 58/1.2)?
That's correct, the inner most ring holds the front element to the optical block,
If you're lucky, it won't take much effort to loosen the ring.
For spanner wrenches, look here(there are other sources like Amazon)
Thorlabs.com edmundoptics.com micro-tools.com
I like the Thorlabs design.
Dec 16, 2011 at 11:28 PM
crazeazn
Details
p.1 #16What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Please be extremely careful!! I had the same problem, and somehow chipped the front element (the inner one). The inner ring and outer ring should come apart easily enough.
Dec 17, 2011 at 12:06 AM
crazeazn
Details
p.1 #17What's this, coating problem? Any remedy (Rokkor 58/1.2)?
I'm almost positive that I caused it while cleaning
Dec 17, 2011 at 01:09 AM
LightShow
Details
p.1 #18What's this, coating problem? Any remedy (Rokkor 58/1.2)?
Yes be very careful with lenses, especially with sharp metal objects.
Sorry to hear about the scratch crazeazn.
Dec 17, 2011 at 01:55 AM
wfrank
Details
p.1 #19What's this, coating problem? Any remedy (Rokkor 58/1.2)?
HAPPY ENDING!
It was oil/lubricant. I had it checked and cleaned and got it back today. When he put the front lens back and tightened the holding ring - more oil appeared. Resulting in him taking the full front lens set apart and cleaned them all. All for 50€ (which is cheap for Swedish standards)!
Now the lens is minty which is good for something more than 40 years old
Appreciate all inputs, thanks a lot all.
Not that these prove anything but I post them anyway, second image shows what happens when a lens is reverted acting like a strong magnifyer - showing the paper grain of an ordinary A4-paper (/Letter)
Edited on Jan 12, 2012 at 02:25 PM · View previous versions
Jan 12, 2012 at 01:57 PM
crazeazn
Details
p.1 #20What's this, coating problem? Any remedy (Rokkor 58/1.2)?
i'm happy it worked out for you! Mine is as old as yours too, hopefully I can find another one.
Jan 12, 2012 at 02:18 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
