This topic is in the 2011 archive. You can read it and like its posts here. It is read only.
Archive 2011rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
sebboh
p.1 #1rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
a few people were asking how these two compared bokeh wise a while ago and here is belated half-assed comparison. only at close distance and only from f/1.2 - f/2. i also threw in the takumar 50/1.4 for comparison.
all shots are focused in liveview on the exact same point (i refocused each time i stopped down) and processed in the exact same way EXCEPT for white balance and exposure. both the rokkor and takumar have noticeable yellowing which i haven't gotten around to correcting yet so white balance was taken at the same point in the image when the image was wide open and that value was used for all shots with a given lens. the yellowing also reduces light transmission so all rokkor shots are boosted about 1/3 of a stop compared to the canon and all takumar shots are boosted about 1/4 of a stop compared to the canon. i presume if i left these lenses under a UV lamp for a while the yellowing would go away and i would not need to give them the exposure boost to match exposure. all shot were taken on a tripod with a timer on a camera that has no mirror (sony a55 with mirrorectomy). this is a 1.5x crop camera so don't make any judgements about edge performance. each shot was taken at iso 100 at the same shutter speed for a given aperture (in manual mode) independent of lens. f/1.2 was shot at 1/10 s, f/1.4 at 1/8 s, and f/2 at 1/4 s. all images were downsized to 1024 pixels in width using the exact algorithm described by luka (denoir) in the post processing thread. open each image in a separate tab and switch between them to compare.
first some close in shots where i tried to adjust for the focal length differences a bit (but not enough) by moving the tripod a few inches.
f/1.2:
rokkor
canon
f/1.4:
rokkor
canon
takumar
f/2:
rokkor
canon
takumar
to my eye the rokkor has better (smoother) bokeh at all apertures shown. it also has a bit less contrast and is the least sharp at in focus regions while the canon is the sharpest- you'll have to take my word for it, i'm too lazy to show all the 100% crops. the canon has more color pop, but i always struggle to get skin tones to look realistic with it whereas the rokkor and takumar don't really require any effort in that regard. it's very interesting to compare the canon f/1.4 to canon f/2 shots - the bokeh improves dramatically whereas the bokeh improvement in the other lenses is less noticeable. i believe this is the aperture where SA correction changes from overcorrecting to under correcting on the canon.
here's some shots of the same scene from further back. in this case the tripod was in the same spot for all lenses.
f/1.2:
rokkor
canon
f/1.4:
rokkor
canon
takumar
f/2:
rokkor
canon
takumar
the story is pretty much the same but the differences are more subtle. the stuffed turtle's shell is probably the best place to look for bokeh funkiness.
finally here is a real world lowlight shot taken tonight at dusk at f/1.2 with the rokkor followed by the canon. these are handheld (so framing is obviously not perfect) at 1600 iso and processed identically.
http://farm4.static.flickr.com/3288/5792172607_5f81e4b603_o.jpg
link
http://farm3.static.flickr.com/2021/5792172655_5042d0c374_o.jpg
link
as in the tests the canon has more contrast and sharpness while the rokkor has a smoother bokeh. it may be that the bokeh differences are due soley to the focal length differences but it does not look that way to me. it may seem like i'm down on the canon, but it is a spectacularly sharp lens as shown in one of my previous tests: https://www.fredmiranda.com/forum/topic/978848/0 where it is very competitive for sharpest lens with the much newer and much praised contax g 45/2. for backgrounds that are not challenging the canon is often the better lens to use.
Jun 02, 2011 at 11:57 PM
plasticmotif
Details
p.1 #2rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
I prefer the Rokkor images you've posted. The Canon's look to the point that they could clip colors easily.
I've not had the pleasure of shooting a converted FL 55(out of all the 50s I've shot). I've seen Gasrocks make comments on it.
Again, I think I prefer the Rokkor. If anything for the extra 3 mm.
Jun 03, 2011 at 07:46 AM
Mike Ganz
Details
p.1 #3rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Thanks, sebboh...I really appreciate the time and effort you took to put these together...hope your cross-country move goes without a hitch.
I took some quick sample shots this morning at my pond as the sun was coming up...not very artistic nor spectacular since I didn't have a lot of time due to mosquitoes feasting on me...it seems that the Purple Martins aren't doing their job.
The bench images were shot at f/2, and the pond shots at f/5.6. I noticed when processing that I really had to dial-down my capture sharpening level from what I normally use, almost to the point where none is needed...lens is very sharp. Anything beyond 12-15 feet causes my mirror to hang on the 5D2, however. Some vignetting (not a whole lot) but easily taken care of with PTLens.
http://northlake.smugmug.com/Photography/Canon-FL-5512-Lens-Test/i-hSJ6S29/0/L/bench55f2-L.jpg
http://northlake.smugmug.com/Photography/Canon-FL-5512-Lens-Test/i-stHF3kw/0/L/pond55256-L.jpg
http://northlake.smugmug.com/Photography/Canon-FL-5512-Lens-Test/i-FmcXLx3/0/L/bench255f2-L.jpg
http://northlake.smugmug.com/Photography/Canon-FL-5512-Lens-Test/i-tgk4ct4/0/X2/pond5556-X2.jpg
Jun 04, 2011 at 07:37 AM
sebboh
Details
p.1 #4rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
looks quite good, i've always been curious how the corners are FF since it is such a sharp lens on crop cameras.
anyway, since i spent that time showing how the rokkor's bokeh is better i'll add that the difference is pretty minimal at f/2 and smaller.
here's a few shots that i think are better for being shot with the canon:
f/1.2:
http://farm2.static.flickr.com/1094/4733189890_5247a43848_b.jpg
f/2:
http://farm6.static.flickr.com/5204/5374837826_5ee5c8e2b9_b.jpg
f/5.6:
http://farm3.static.flickr.com/2765/4410578557_f101740703_b.jpg
Jun 04, 2011 at 07:02 PM
Mike Ganz
Details
p.1 #5rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Jun 05, 2011 at 09:12 AM
Mike Ganz
Details
p.1 #6rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
TBH, when I had my Rokkor, I found that f/2 seemed to be the aperture with the most pleasing bokeh. Damn sorry I sold that lens. But so far, I'm more than pleased with the Canon 55....corner sharpness on the FF is very, very good.
Still have my eyes out for another Rokkor, so if anyone on the forum wants to part with one (I know that some of you have multiple copies ) feel free to drop me a PM or email.
Jun 05, 2011 at 09:17 AM
jfinite
Details
p.1 #7rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Love that raven shot!
Jun 06, 2011 at 09:47 PM
debuggerus
Details
p.1 #8rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Did you convert that FL to alpha mount and which version of the takumar is this?
Anyway, very interesting comparison. Thank you, sebboh.
Jun 07, 2011 at 03:23 PM
sebboh
Details
p.1 #9rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
thanks
yes, i converted both the canon and the rokkor to alpha mount. the takumar is the last version with the rubber focus ring.
Jun 07, 2011 at 03:40 PM
mMontag
Details
p.1 #10rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
sebboh,
Thanks for your time for posting the comparisons - nicely done - the Canon looks really good with the greater background distance - as shown on the Raven & pier shots - great shots BTW.
I sold a mint Rokkor a couple of months ago and looking to replace it with an FL - for the cost with a DIY conversion the Canon is a real bargain for a 1.2 lens - the old Canons do have super sharp centers.
Jun 07, 2011 at 09:39 PM
OpticalFlow
Details
p.1 #11rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Thanks for these tests.
I just finished converting my Canon FL 55/1.2 to EOS and I have a Rokkor 58/1.4 on the way (can't afford another 1.2 lens at the current market prices). I hope to find the time to compare the Canon 1.2 with the Rokkor 1.4. I remember seeing some earlier posts that say that the Bokeh of the 58/1.4 Rokkor is similar to that of the 1.2.
Given that I picked up the FL 55/1.2 for $200 (including a well-presevered Canon FT QL body that I don't have a use for) I'm quite happy as the nicer bokeh of the Rokkor 58/1.2 isn't worth the additional cost to me.
Jun 08, 2011 at 12:20 AM
Alf Beharie
Details
p.1 #12rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
...Show more →
I've just gone back over these samples and I have discovered a problem...The framing is not identical for each lens. In every comparison the Rokkor has the narrowest FOV, ie: It appears closer to the subject than the Canon, and the Canon appears closer to the subject than the Takumar...The problem is, the closer a lens is to the subject, the shallower the DOF, and hence the smoother the bokeh, so the Rokkor has been given an unfair advantage.
Now obviously the Rokkor has the longest focal length, followed by the Canon and then the Takumar so to keep the framing the same the Rokkor should be the furthest from the subject, then the Canon, with the Takumar the closest. If it were me, I would have made sure the framing was identical for each lens by adjusting the distance to the subject differently for each lens to ensure I got a completely fair bokeh comparison.
Any chance you could redo them with this in mind?
Nov 10, 2011 at 08:23 PM
sebboh
Details
p.1 #13rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
...Show more →
yes, i mention the framing problem briefly in the original post. unfortunately matching the framing for lenses of differing focal lengths is impossible when the shooting a non planar subject – moving the shorter lenses closer changes the ratio of subject to background distance which of course impacts dof. taking all the images at the same distance gives the rokkor the advantage, taking all the images at the same subject magnification gives the canon and takumar the advantage. i tried to split the difference in one of the test shots by partially compensating for difference in magnification. as i said actual identical framing is impossible so i'm not terribly enthusiastic about redoing the test. i think you can see enough about the quality of blur (not just the amount) to judge how the lenses will perform in different situations. i've shot thousands of frames with both lenses and i can say that generally speaking the canon is sharper with a bit less loCA at every aperture and the rokkor has smoother bokeh at every aperture. the differences in all of these aspects become smaller as the apertures become smaller.
Nov 10, 2011 at 08:44 PM
Alf Beharie
Details
p.1 #14rokkor 58/1.2 vs canon FL 55/1.2 bokeh comparison
Ok, fair enough.
Nov 11, 2011 at 07:43 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
