Archive 2010 · Replacement of 14-24 Front Element
weekh
p.1 #1 · Replacement of 14-24 Front Element
Any idea if the front element of the 14-24mm can be replaced?
Dec 16, 2010 at 09:26 PM
Todd
p.1 #2 · Replacement of 14-24 Front Element
yes, you may have to send it to Nikon and have them do it. What happened, did you chip or scratch it?
Todd
www.toddhargisphotography.com
Dec 16, 2010 at 09:34 PM
weekh
p.1 #3 · Replacement of 14-24 Front Element
There was a scratch and I thought it was some sort of stain. Used water to rub it and there goes the lens coating.
Dec 16, 2010 at 09:43 PM
BenV
p.1 #4 · Replacement of 14-24 Front Element
I thinks its about $300 to replace it
Dec 16, 2010 at 09:56 PM
khphotography
p.1 #5 · Replacement of 14-24 Front Element
$300 seems awfully low to me. I'd be betting the replacement element would cost that alone let alone the 2-3 hours of time the tech will take to replace it. You can easily say $600+
When I had the filter ring of my 70-200 changed it cost me $375 and that was just the filter ring that had a nick in it.
Dec 16, 2010 at 09:57 PM
tjny
p.1 #6 · Replacement of 14-24 Front Element
Recently, someone asked how to clean this lense and my answer was, first be gentle, don' do more harm by agressive cleaning - stains are common & they do not affect image quality- I used to be anal about stains on lense coating , not any more. I have a bulbous lense ( 8-16 Sigma Dx ) and I remove lense cap when I am ready to shoot only.
Dec 16, 2010 at 10:46 PM
Dennis H.
p.1 #7 · Replacement of 14-24 Front Element
I would be shocked if water would remove the lens coating.
After all aren't pro lens suspose to be able to take a little weather including a little rain.
Dec 16, 2010 at 10:54 PM
Todd
p.1 #8 · Replacement of 14-24 Front Element
Look here:
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productid=1367
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1390
http://www.edmundoptics.com/technical-support/optics/cleaning-optics/?&pagenum=2
this is what I use for my optics cleaning...great stuff!
Todd / www.toddhargisphotography.com
Dec 16, 2010 at 11:41 PM
RJKphoto
p.1 #9 · Replacement of 14-24 Front Element
OP- If you ever get a solid answer on this please let me know! Thanks!
Dec 17, 2010 at 07:19 AM
weekh
p.1 #10 · Replacement of 14-24 Front Element
Before I posted to this forum, I called Nikon Singapore and was told that they have no spare parts for the lens. At the same time, I was also being told that the lens comes as a whole and no parts can be replaced. I'll have to replace the whole lens.
I'm still waiting for a firm answer if the front element can indeed be replaced.
Dec 17, 2010 at 08:24 AM
trenchmonkey
p.1 #11 · Replacement of 14-24 Front Element
Any impact on IQ if not, don't worry about it.
Dec 17, 2010 at 08:32 AM
weekh
p.1 #12 · Replacement of 14-24 Front Element
Yes! The scratch renders an obvious big dust spot once the lens is stopped down.
I've not examined further to see what's the impact from the wearing of the coating.
Dec 17, 2010 at 08:36 AM
Ivo Heshusius
p.1 #13 · Replacement of 14-24 Front Element
Hmm... are you sure it's not just dust on the sensor? I have seen pics here in the past from lenses with BROKEN front elements - damage on the lens didn't impact the image at all or maybe slightly in the worst case...
Dec 17, 2010 at 08:41 AM
nadroj
p.1 #14 · Replacement of 14-24 Front Element
Maybe it's worse on wide angles since the DOF is so deep, therefore putting the front element slightly more in focus? I had a 180mm f/2.8 with a gouge on the front element (picked it up for $150 because of it) and it didn't seem to affect the pictures in any noticeable way.
Dec 17, 2010 at 08:55 AM
mshi
[X]
p.1 #15 · Replacement of 14-24 Front Element
I had 24-70mm f/2.8G sent to Nikon for adjustment of tight zoom ring, and it came back with broken filter ring and shattered frontal element. It got sent back to Nikon right away. But, Nikon wanted to charge me $264 for replacement. Eventually, Nikon did it for free. At least, you get an idea on how much it costs to replace the frontal element and filter ring of 24-70.
Dec 17, 2010 at 10:45 AM
Zebrabot
p.1 #16 · Replacement of 14-24 Front Element
Todd wrote:
Look here:
[stuff cut]
the edmunds stuff is good- the only trick is to use the least amount possible and even then, drying the stuff off is a pain with typical lint free cloth as that stuff has close to zero absorbency.
Dec 17, 2010 at 03:41 PM
Jammy Straub
p.1 #17 · Replacement of 14-24 Front Element
What did you possibly rub the lens with that removed the glass coating? Old wool, sandpaper?
I clean lenses all the time with a cotton t-shirt after breathing on them (distilled water), there's no way the lens coating should rub off.
Can you share a photo of the front element of the lens itself?
Dec 17, 2010 at 03:50 PM
BenV
p.1 #18 · Replacement of 14-24 Front Element
Im thinking the coating was starting to flake, and water + hard rubbing was the final straw
Dec 17, 2010 at 04:02 PM
Jammy Straub
p.1 #19 · Replacement of 14-24 Front Element
If the coating is indeed flaking off or is that easy to remove, I'd send that lens in for a warranty repair. That's just not normal in a lens that new.
Dec 17, 2010 at 04:29 PM
RRRoger
p.1 #20 · Replacement of 14-24 Front Element
Don't send it to Torrance.
Unless you are NPS or walk it in.
If there is any dirt on it they will claim "impact damage" and charge you their minimum $700.
I would clean the entire lens with 91% + Isopropyl Alcohol, take several pictures of it, pack it in at east two inched of bubble wrap and send it to Melville.
It will probably be covered by warranty.
At any rate, their service has been very good and they have never overcharged me.
Dec 18, 2010 at 10:17 AM
