I've never understood the logic in spending $4000 or so for a body, $6000 or so for a 400mm lens, and then worrying about spending a $150 to protect it all with something more than a plastic bag? (Comment not directed at anyone in particular, by the way) The ThinkTank system is fantastic for both the 300-600 version and the new 70-200.
The fact you can "mount" the rain cover for the 300-600 on the lens hood and quickly deploy when needed is a huge plus for me...that, and the use of an integrated eye piece means it's significantly easier to use than a plastic bag. Generous arm holes means it's also easy to continue to use the camera normally (even switching horz/vert).
Without a doubt, MUCH better than the Kata system which I used before the ThinkTank came out.
