ulrikft2 wrote:
mawz wrote
ulrikft2 wrote
I guess, since the sony mount is 2mm shorter than the nikon (FFD), you can add a 2mm ring and a m42->sony mount, screw holes and be pretty much good to go. It really just depends on the mount throat, but nikon is _small_ in this department too, so I don't see how that could pose a problem. You'd want a 1mm ring, since Nikon mount is only 1mm shorter than M42 mount and the adapter makes up the difference.
Hmm, might have to test this out... Time to get another Series E 50 I think. good point.
The main reason for me, is to get infinity @ 1.2 on my rokkor. And if I could use my 24/2, 105/2.5 and other manual lenses too, that would be quite a bargain (d700s go for more used here than a900 new..).
The Rokkor does very nicely on the A900, no mirror issues at all.
Personally, I just really like the Sony FF bodies and Minolta film bodies, but replacing my Nikon kit would be expensive and some lenses just aren't available (85/1.8, CV 58). I think I'm going to have to get a couple M42-Alpha adapters and do a test conversion
