FM ForumsLeica & Alternative GearJoin Upload & Sell
Archive 2009 · Differences in Rokkors?
dancam
p.1 #1Differences in Rokkors?
Hello everyone, I've been interested in getting into some alt glass so obviously here's the place to ask questions. I was looking at some rokkor 58 1.2's and noticed varying model designations. Does anybody have any info?
Thanks, Dan.
Nov 08, 2009 at 08:45 AM
cogitech
Details
p.1 #2Differences in Rokkors?
There are 4 variations with respect to the naming:
Rokkor-PG
Rokkor-X PG
Rokkor
Rokkor-X
"X" denotes export lenses that were marketed in different places than the non-X. It does not denote anything "Xtra". According to Rokkorfiles.com "In line with Minolta’s practice of labeling products differently in different markets, the lenses were labeled “Rokkor-X” in the North American market, and “Rokkor” throughout the rest of the world. It is noted that apart from this minor cosmetic change there is no difference between the Rokkor and Rokkor-X version of the same lens. "
"PG" Denotes the lens formula of 7 elements in 5 groups.
First Letter (no. of groups): T=3; Q=4; P=5; H=6; S=7; O=8; N=9.
Second Letter (no. of elements): C=3; D=4; E=5; F=6; G=7; H=8; I=9; J=10; K=11; L=12.
The practice of including the lens formula was dropped in the third generation of Minolta MC mount lenses. Hence, this third generation would have the label "Rokkor" or "Rokkor-X" depending on what market it was destined for.
The older, all metal versions are all "Rokkor-PG" but there are also some rubber-gripped "Rokkor-PG", and some rubber-gripped "Rokkor-X PG". "Rokkor" and "Rokkor-X" are all rubber-gripped.
They are all multi-coated, right from the 200xxxx series right up to the last ones. I know this for a fact because my 200xxxx and 2 other 200xxxx copies that I have had all had green/blue, pink/purple and yellow coatings. The question is, which surfaces of which elements where multi-coated and how did that change over time? Nobody knows for sure.
The multicoating almost certainly changed over the years, but this is not correlated with serial numbers or body style as far as I can tell. Take any one of them and tilt it in the light and you'll see various colours. However, it is believed that coatings on the MC 2nd and 3rd generation lenses are generally better than those on the earlier 1st generation lenses. This is only a generalization because the coatings were undergoing continual development during this period, and accordingly the break from “old” coatings to “new” coatings was progressive, and it is actually likely that there were multiple improvements throughout this period.
One other notable difference is the presence of thorium (radioactive) glass in the first few runs. Lenses with serial numbers 200xxxx, 250xxxx, 255xxxx, and at least some of the 256xxxx have this. Lenses from 257xxxx through 27xxxxx series do not.
They are all excellent lenses (although there certainly is some sample variation after all this time), but the one I kept over many others is a 200xxxx Rokkor-PG.
The conversion process to EF mount is identical for all of them.
Edited on Nov 08, 2009 at 09:04 AM · View previous versions
Nov 08, 2009 at 08:54 AM
mMontag
Details
p.1 #3Differences in Rokkors?
If you haven't been there - start with The Rokkor Files - rokkorfiles - for some nice gee whizz info - it's a good site. The Pros here will soon provide more than enough on this outstanding lens. I'm using one on a 5D without a modified mirror and just slightly, slightly under true infinity with a JB adapter and shaved lens rear housing.
Nov 08, 2009 at 08:57 AM
dancam
Details
p.1 #4Differences in Rokkors?
Thanks for the quick replies.
Nov 08, 2009 at 10:02 AM
racevedo
Details
p.1 #5Differences in Rokkors?
rokkorfiles already mentioned, here are more reference sites
http://minolta.eazypix.de/shades/lensshades.html
http://minolta.eazypix.de/lenses/body_li.html
http://thesybersite.com/minolta/historical/Minolta_Lens_Chronology.htm
http://minolta.rokkor.de/minoltalenses.htm
Nov 08, 2009 at 12:52 PM
Ed Sawyer
Details
p.1 #6Differences in Rokkors?
they probably used lanthanum glass rather than thorium glass (which was abandoned/replaced long before Rokkors were built, generally) but the effect (reversible yellowing) is similar.
-Ed
Nov 08, 2009 at 06:47 PM
cogitech
Details
p.1 #7Differences in Rokkors?
Hmmm, I have a bad habit of referring to any radioactive glass as thorium or thoriated. Very imprecise.
Nov 08, 2009 at 07:49 PM
JimU
Details
p.1 #8Differences in Rokkors?
i've never heard of yellow'd 58/1.2s. are you certain of that?
Nov 11, 2009 at 12:07 PM
cogitech
Details
p.1 #9Differences in Rokkors?
100% positive. I've had several of them and my current copy is. I'm surprised you've never heard this before. It is well documented.
Nov 11, 2009 at 12:13 PM
alexandre
Details
p.1 #10Differences in Rokkors?
This is not that unusual when considering 20+yr lenses.
Zuiko 55/1.2 has this too, I guess.
Nov 11, 2009 at 12:32 PM
Laminin
Details
p.1 #11Differences in Rokkors?
I am pretty sure that the 55/1.2 Zuiko lenses up to about sn 135,000 (with chrome front ring) have thorium containing elements. From about mid 1977, those with a black front ring, don't show any radioactivity. To my knowledge, it were the big optical glass manufacturers (Schott, Hoya), which have not used Thorium (but still Lanthanum, which is much less radioactive) in their production anymore from the mid 1970th, which forced the lens manufacturers to reformulate their lens designs (at least slightly).
From this timing, I expect that the early 58/1.2 Rokkor's have thorium containing glass, which causes the yellowing.
The following links (arbitrary selection) might be of interest:
http://radlab.nl/radsafe/archives/9803/msg00137.html
http://www.camerapedia.org/wiki/Radioactive
http://www.orau.org/PTP/collection/consumer%20products/cameralens.htm
Nov 11, 2009 at 04:31 PM
Jos Tesseract
Details
p.1 #12Differences in Rokkors?
So this means the Rokkor TC has 3 lenses in 3 groups? Why does that not make any sense?
Nov 11, 2009 at 05:29 PM
Laminin
Details
p.1 #13Differences in Rokkors?
Yes, the early 1960's Rokkor TC's 135/4 and 100/4 had 3 elements, none of them glued together, which means each element represents one group. Makes sense to me.
Nov 11, 2009 at 05:39 PM
cogitech
Details
p.1 #14Differences in Rokkors?
As Laminin says, yes it makes sense. As another example, my current choice of 135mm lens has only 4 elements in 4 groups. The classic "Tessar" design is 4 elements in 3 groups, etc.
Nov 11, 2009 at 05:46 PM
Ed Sawyer
Details
p.1 #15Differences in Rokkors?
Laminin - thanks for the info. I had thought thorium glass discontinued back in the 50s-60s but maybe I am wrong on that. Lanthanum was used as the replacement, yes (though it too is probably discontinued now). the early rokkors did yellow. I have one of them (20016xx), but the good news is they can be cleared with UV. Optically I am not sure if the earlier ones are better - haven't done an exhaustive test on my 2 yet. (one early, one late) Modern Photography liked the later one better that they tested but that could be sample variation also. It was about the best 50ish 1.2 (wide open) they ever tested, fwiw. I'll post the tests soon.
Tessar and other small-element-count lenses can do quite well. they do have their limitations but within them they are surprisingly good.
-Ed
Nov 11, 2009 at 09:53 PM
Jos Tesseract
Details
p.1 #16Differences in Rokkors?
Sorry... mental hang-up for me. I know it makes sense, but the idea of grouping things that are not grouped, doesn't make logical sense, semantically speaking.
Nevermind me... my brain is slowly turning to mush.
Nov 11, 2009 at 10:54 PM
Leon Noel
Details
p.1 #17Differences in Rokkors?
Are you saying a group cannot contain just 1 member?
And we've been using the term 'one man team' for quite some time...
Nov 12, 2009 at 01:09 PM
Jim Schemel
Details
p.1 #18Differences in Rokkors?
Helpful info.Any comment on the "MD Rokkor"
-Jim
Nov 12, 2009 at 02:19 PM
cogitech
Details
p.1 #19Differences in Rokkors?
-Jim
More difficult to convert, worse bokeh. http://rokkorfiles.com/Battle%20of%2050s1.htm
Nov 12, 2009 at 03:00 PM
