I have 450 images, taken with 2 cameras, all JPGS and they are all over the place with WB and saturation. I did not take these photos but because they are of my wedding, i'm trying desperately to save them! I was wondering if anyone could point me in the direction of a tutorial for batch processing for custom WB and saturation mainly! Thanks in advance!
Over on lynda.com Taz Telly (sp) has a Photoshop class on color correction. He covers many approaches for color correcting jpg's in Photoshop. The methods will be reasonably quick, but not an automated batch process. You should be able to get some nice results. Once you have a correction for a single image, just apply it to all of the similar images in the batch.
One automated method I almost hesitate to mention ... but, when it works can produce really great results ... especially if you have a few images with correct color balance is the Match Color command (Image > Adjustments > Match Color ...). Here you open an image with correct (desired) color and the image to be fixed. Than select Match Color ... make your adjustments and see if it works.
Another method ... which I have only used once and may or may not work. Is to create a copy of your image on a layer, than select all the layer, average all of the pixels on the layer (AVERAGE is the first filter in the BLUR filters area). The layer will be some grey tone at this point. Then add a curves adjustment layer and use the middle grey eyedropper in the curves command to click on the now averaged pixels. Then delete the averaged pixels layer and the curves layer will apply a color correction to the underlying image. Worth a try to see what you get. This would be an easy action to create.
Another method which might work for your images is to use a filter in NIK's Color EFX Pro. They have a Neutralize filter that attempts to color correct images. They have a demo software version you can try and the filter can be placed in an action.
Finally, you can bring the images into ACR (or LR) and just use the white balance eye dropper tool (plus temp/tint) to correct one image and then apply the correction to the other similar images in ACR by using the sync command. Adobe may have added this capability in CS3, I can't remember.
Actually, there are many ways to accomplish what you want to do ... but, the best approach is a little based on the images.
If it was me, I would just hand color correct the images using one of the methods in the tutorial above.
One more slightly advanced approach that would be worth trying. If you add a curves adjustment layer, then in the curves dialog box ALT click on the AUTO button you will see a hidden auto curves correction box open up. In this box, you will have the option to SNAP TO NEUTRAL midtones. Check that box in addition to any of the other corrections (like find light/dark values) that you would like to make. I can't remember at which level they introduced this function into Photoshop, I use CS4 ... but, it is an easy automated approach.
You can use Adobe Bridge to batch process these files. I do not have CS2 so if this isn't available I apologize.
Adobe Bridge/Select All/Tools/Photoshop/Image Processor.....Then follow the steps. I use this method in CS4 with my raw files, I do not know if it is in CS2.
Your other choice would be to open a jpeg in CS2 and create an action to correct the white balance. Then go to File/Automate/Batch...then let CS2 run the action in the batch process. I don't use Lightroom, so can't help there.
I find the eyedropper tool the easiest to use when batch-correcting WB. I have Bridge with CS3, so I'm not sure it will work with CS2, but for a rescue operation you might be able to download a trial version of CS4 and use it to batch your photos.
Firstly, I go into the preferences in Bridge and tell it to use ACR to edit JPEG's just like I would a RAW file.
I then select all of the jpegs for each camera (so you'll do this once for each camera) and Open in Camera RAW. Then you can simply highlight similar images and using the eyedropper, select something in the photo that is white (or supposed to be white). The WB will change on your screen so play around until you get the colours you're after. With multiple images highlighted the change will apply to all those selected images. Importantly, when you've done this for all the images you want to change, click on "Done" not open. Bridge will save an XMP for these just like a RAW file. You'll need these later as you will batch process the images and THAT is when the WB changes will occur.
When you've done all the different cameras the same way, then simply highlight all the images again and then run the Image Processor from Bridge. This should give you all new JPEG's with your WB corrected.
This is pretty much how I do my wedding images although I use RAW files and I use four different camera bodies on any wedding. With a bit of practice you get quite quick at it and Bridge does allow you to pick the camera by its serial number and to then simply select particular ISO values and stuff like that so you are editing very similar images and changing the WB on those in a very targeted way. I find it easier to edit JPEG's this way than to play around in photoshop matching colours.
