fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Bizarre Photoshop JPG behavior
phil hawkins
p.1 #1Bizarre Photoshop JPG behavior
I am processing some images for 5x7 printing, and want to convert them to JPG for ease in handling for my mother-in-law... In doing the conversions from TIFF to JPG, I am cropping my TIFs at 5x7, 360 dpi. When converting to JPG my sizing is being changed from 5x7 inches at 360 dpi to 35 x 25 INCHES at 72 dpi. I have looked at everything and cannot figure out why it's doing that. I've been to Preferences, I've changed the setting at the bottom of the "Save for web and devices" dialogue box and nothing works. Never seen this characteristic before!!
Any suggestions?
Jun 19, 2009 at 12:45 PM
colinm
Details
p.1 #2Bizarre Photoshop JPG behavior
There isn't a problem per se—the file's still the same size, Save For Web just sets the embedded resolution to screen resolution (72 ppi).
Should still print the same at a lab (which will almost certainly be 240 or 300 rather than 360 ppi anyway), still has the same data in it, etc. If you want to preserve the embedded resolution, use Save As from within Photoshop.
Jun 19, 2009 at 12:50 PM
phil hawkins
Details
p.1 #3Bizarre Photoshop JPG behavior
The size reflected AFTER the conversion says "35 INCHES x 25 INCHES". With all due respect, and I appreciate your response, but that's not the same as 5 INCHES x 7 INCHES. But the main question is why is the resolution and image dimensions being changed? That should not be happening. BTW, it's CS4.
Jun 19, 2009 at 12:57 PM
tomrock
Details
p.1 #4Bizarre Photoshop JPG behavior
Colin's right -- it's the size of the file in pixels that's important. The dpi doesn't mean a thing. It's just a tag in the file.
They'll print just fine.
Jun 19, 2009 at 05:01 PM
rhyder
Details
p.1 #5Bizarre Photoshop JPG behavior
Next time use LR and export the files as JPGs.
Jun 19, 2009 at 05:17 PM
phil hawkins
Details
p.1 #6Bizarre Photoshop JPG behavior
I understand the issue of pixels and file size, but no one has addressed the discrepancy of why it says the image is 35 INCHES by 25 INCHES. I'm not concerned with file size and pixel dimensions, I'm worried about the image size, print size. If PS says the image is 35 inches, what is it that makes you guys think it will print 5x7? I'm not being flippant, I really don't understand how when it says 35 inches, it really is 7 inches. I have something to learn in this regard...
I have LR; maybe I'll give it a try. I really don;t use LR that much for file conversions.
Jun 19, 2009 at 05:24 PM
James_N
Details
p.1 #7Bizarre Photoshop JPG behavior
Its simple math: a 5 x 7 inch image at 360 dpi is the same as 1,800 x 2,520 pixels. (360 x 5 = 1,800 and 360 x 7= 2,520).
Since the Save for Web function by default assigns a 72 dpi to the image; that translates to 25 x 35 inches (1800 pixels/72 dpi=25 inches and 2520 pixels/72 dpi =35 inches).
But as pointed out you still have the same amount of pixels so the file size hasn't changed. When the file is to be printed the printer will adjust the DPI to fit the dimensions you want.
BTW, the reason Save for Web and Devices assigns a 72 dpi is because it assumes you want a low resolution image to be used for things like website backgrounds, etc that will only be viewed on a screen and will load quickly. If you want to keep the original DPI use the "Save As" command as was previously suggested since you intend to have the image printed.
Jun 19, 2009 at 05:44 PM
phil hawkins
Details
p.1 #8Bizarre Photoshop JPG behavior
...Show more →
Thanks, James, but the "Save As" command in CS4 does not have the JPG option when saving from a TIF.
"It assumes..." So, JPGs are only used to go on the internet? People do print JPGs, in fact most all labs will only take JPGs; what is it that makes Adobe think JPGs will only be used on the 'net at 72dpi I go crazy over things like this.
Jun 19, 2009 at 06:35 PM
Eyeball
Details
p.1 #9Bizarre Photoshop JPG behavior
This isn't becaue it's a Tiff, it's because it's a 16-bit image instead of 8-bit. Use Image>Mode to convert to 8-bit and then you will be able to "Save As" to a Jpeg.
"Save for Web" does this conversion automatically but "Save As" doesn't.
Jun 19, 2009 at 06:49 PM
phil hawkins
Details
p.1 #10Bizarre Photoshop JPG behavior
Eyeball wrote:
phil hawkins wroteThanks, James, but the "Save As" command in CS4 does not have the JPG option when saving from a TIF.
Ah, great, thanks!
Jun 19, 2009 at 06:51 PM
figmented
Details
p.1 #11Bizarre Photoshop JPG behavior
It's because labs use all sorts of different ppi files and dpi printers. 72ppi doesnt even matter to them because they change it to whatever the printer needs anyways. 72ppi used to be what monitors were standard, so it was the standard web jpeg dimensions.
Jun 20, 2009 at 02:01 AM
