fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009Adapter for CONTAX/Yashica and Canon DSLR
Jakob Arnholtz
p.1 #1Adapter for CONTAX/Yashica and Canon DSLR
Hello.
I used to be a happy CONTAX owner, but I would like to go digital with my beloved Zeiss lenses.
Does a Canon 5D or a 5D Mark II fulll frame camera fit with a Distagon 2,8/21mm T* Zeiss without any problems with the mirror or infinity focus. I know, that I need a adapter, but I need recomandation on which one to buy. I also need to be able to use my 100mm macro Zeiss.
I love the two lenses and find them essential for most of my photograpy work like you see it on the my homepage.
http://imaginebutterflies.dk/NonEuropean5.html
http://imaginebutterflies.dk/betula2.html
http://imaginebutterflies.dk/iris4.html
The 5D's are now showing up as used gear and entering a pricelevel where I can participate, so I guess now is the time to go digital.
Any help, hints or tips are welcome.
Kindly
Jakob Arnholtz
May 22, 2009 at 10:45 PM
ziyadj
Details
p.1 #2Adapter for CONTAX/Yashica and Canon DSLR
Hi Jakob
I use the 21 distagon with the 5D Mk2 with no problems at all and great results .
I use the Kindai Adapter and is excellent. I also understand Cameraquest are also very good adapters (I hear they are the same as Kindai).
Below is a very useful site.
http://www.pebbleplace.com/Personal/Contax_db_Adapters.html
May 22, 2009 at 11:13 PM
Jakob Arnholtz
Details
p.1 #3Adapter for CONTAX/Yashica and Canon DSLR
Thanks amillion times. That is just the info i seek.
Have a nice weekend.
Kindly
Jakob Arnholtz
May 22, 2009 at 11:29 PM
Details
p.1 #4Adapter for CONTAX/Yashica and Canon DSLR
Here's a couple more:
16-9.net Canon 5D Adapted Lens Compatibility lists http://www.16-9.net/lens_tests/compatible.html
Zeiss/Oly 5D compatibility https://www.fredmiranda.com/forum/topic/306575
May 23, 2009 at 05:45 AM
IDURITA
Details
p.1 #6Adapter for CONTAX/Yashica and Canon DSLR
Excellent photos. I am also interested in buying a C/Y to EOS adapter.
May 23, 2009 at 07:23 AM
fit ti be tied
Details
p.1 #7Adapter for CONTAX/Yashica and Canon DSLR
I use Cameraquest adapters with my CZ 35-70/3.4 Vario Sonnar and my new ZF 28/2.0 Distagon on my 5D MkII. No complaints (other than the price). I have also heard that the Cameraquest adapters are "re-labeled" Kindai adapters.
May 23, 2009 at 08:02 AM
mMontag
Details
p.1 #8Adapter for CONTAX/Yashica and Canon DSLR
Hey Fit,
How do you like that 28/2? It's a lens that is rarely mentioned here. I have one and really love it - on a CameraQuest. Great for landscapes - about 8" MFD - and the colors and sharpness are exactly what I like in a 28mm. I would love to see that lens compared to the Leica.
Also, I have a Kindai on my C/Y 35-70 - the machining and texture are a little different than the CQ. They could be from the same manufacturer - but they do "look" different. The precision fit, correct thickness and black anodize of those adapter make the expense worth it IMO. I have a couple of HappyPageHK's on some Leicas - a little loose/ needed to be shimmed - AF is off on one - not the quality of the Kindai & CQ.
Great shots ziyadj - you can re-post those anytime.
May 23, 2009 at 08:31 AM
jjlphoto
[X]
Details
p.1 #9Adapter for CONTAX/Yashica and Canon DSLR
I have the CY 28/2.0 Distagon AE/West Germany. I had it calibrated at Zeiss a couple years ago. I compared it to a friends excellent hand picked copy of the Leica 28mm F2.8 Elmarit-R, and I found that my sample of the Contax had more even illumination across the entire aperture range. Had to give the edge in sharpness to the Contax as well. Others often report differently, but I guess I have an exceptional sample of the Contax.
Regarding the 21, I also have a CY 21/2.8 Distagon. Performs beautifully. No mirror clearance issues. Some users get perfect infinity focus with stock adapters, some modify them. I use a happypageHK chipped adapter. At that time, his adapters were 1.44mm out of the gate, and I added a circular brass shim between it and the lens to achieve perfect infinity focus. If I recall, total thickness including my shim was 1.48mm
Edited on May 23, 2009 at 11:03 AM · View previous versions
May 23, 2009 at 10:56 AM
fit ti be tied
Details
p.1 #10Adapter for CONTAX/Yashica and Canon DSLR
mMontag wrote:
Hey Fit,
It is a fantastic lens, and it is also great for video on the 5DMKII. I believe that it is based on the legendary Zeiss "Hollywood" lens. ( It is a favorite of a lot of film-makers who shoot on the Red One ... a lot cheaper than a Zeiss superspeed prime.) I use it for both landscapes and as a walkaround. I priced Zeiss Hollywoods, and they were anywhere from $600.00 for a so-so copy to well over a $1,000.00 for a decent copy. I picked up my 28/2 used, but LNIB with warranty card, etc., for $725.00 ... and I can use it with both my D700 and 5DMkII (with the adapter). My only issue with the lens on the D700 is that I find I spend too much time fixated on the focus confirmation arrows and dot, which can distract from what you are framing. If I used it full time on the D700, I think I would get a different focusing screen.
I am toying with the idea of getting some Leica lenses and converting them with the leitax adapter to use on the D700. I wonder if you can use a Nikon F to EOS adapter on a leitax converted Leica lens? Seems like it should work.
May 23, 2009 at 11:02 AM
sirimiri
Details
p.1 #11Adapter for CONTAX/Yashica and Canon DSLR
You could spring for the Fotodiox version: http://www.fotodiox.com/shop/product_info.php?cPath=27&products_id=4378
I have one for Mamiya M645 --> Canon EOS, and although not chipped (no AF confirm possible, etc.) it seems quite well made and the price wasn't bad.
May 23, 2009 at 12:52 PM
Jakob Arnholtz
Details
p.1 #12Adapter for CONTAX/Yashica and Canon DSLR
A lot of help and fine answers.
Thank you everybody.
Does any of you use the 5D with theDistagon 2,8/21mm T* Zeiss?
Kindly
Jakob Arnholtz
May 25, 2009 at 01:50 PM
zoomo
Details
p.1 #13Adapter for CONTAX/Yashica and Canon DSLR
Hi, I too have several Zeiss lenses from my Contax days, including the 28/2. How did you go about getting the lenses to Zeiss to have them calibrated? Thanks for any info.
Cheers, Bob.
May 26, 2009 at 02:30 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
