Peak DR is reached at ISO 200, as usual for crop cameras, because at ISO 100 the sensor saturates before the amplifier.
ISO 3200 and up are limited by the 14 bit encoding and seem to be acheived in software, this is also confirmed by an apparent resampling of the RAW data. From ISO 3200 the histogram is no longer continuous.
Unfortunately I cannot measure the Signal/Noise ratio because I don't have any light intensity reference.
I did measure the system gain at ISO 400 using the so-called mean-variance method on a small patch of clear blue sky. This measurement is rather uncertian, and should not be taken as good. However a control measurement with the 40D was within 5% variation compared to other sources like clarkvision.com
System Gain measured at ISO 400 to 0,6
System Gain estimated at ISO 100 to 2,4 ( 50D has 2,2 according to clarkvision.com)
Full Well 29800 electrons (50D has 27300 according to clarkvision.com)
If this holds to be true, the 500D has improved the highlight end of the dynamic range over the 50D. Again, if it is true, likely by making the photodiodes larger within the same pixel pitch.
The read noise at low ISO will be worse than the 50D, but this evens out from about ISO1600.
Pattern noise is well controlled (in the Canon world). The torture test of this is a black frame at ISO100, developed in DPP with +2 stops exposure compensation, and then levels adjusted in PS with input levels (0 1,00 25). Full frame resized: http://i306.photobucket.com/albums/nn242/Overflate/demo/500DISO100.jpg
