p.1 #1.CR2 Files unable to open straight into photoshop?
I just got a 5d mark II, when I drag the files out they are .cr2 and when I try to open those in photoshop I get the message "could not complete this request because photoshop does not recognize this file type. I am shooting in RAW and I thought you should just open raw files right up into photoshop, I know I could do that with my Nikon. (just switched from nikon to canon)
p.1 #2.CR2 Files unable to open straight into photoshop?
Unless you have CS4 with teh latest ACR update you won't be able to open 5DII files on earlier versions of photoshop. The workaround is to use Adobe DNG convertor to convert to DNG format. Adobe like you to buy the latest versions of their software and this is one of their methods of persuasion.
p.1 #4.CR2 Files unable to open straight into photoshop?
What version of Photoshop are you using? This message usually means that your current version of Adobe Camera Raw is outdated and you need to update to the latest version.
The Canon 5D Mark II is only supported in Photoshop CS4 so if you have an earlier version updating ACR will not work. If, however, you have Photoshop CS4 go ahead and update ACR to the current version which is 5.3.
p.1 #5.CR2 Files unable to open straight into photoshop?
James_N wrote:
The Canon 5D Mark II is only supported in Photoshop CS4 so if you have an earlier version updating ACR will not work .... although you could convert the files to dng with the free converter from Adobe. PS will then be able to convert these as normal
p.1 #7.CR2 Files unable to open straight into photoshop?
It's the same ACR engine that Photoshop CS4 would use and a great deal of people prefer starting with Lightroom and plenty of them never even send to Photoshop so its more than fine.
Orlov wrote:
So I have just been opening the files in lightroom 2 and exporting them as psd files, is this fine?
p.1 #8.CR2 Files unable to open straight into photoshop?
had the same problem last night, updated to LR 2 with up date 2.3 and also updated Mac Book Raw previewer from Apple, now can preview CR2 files in Finder. I just clicked on updates from the finder menu and it was on the list of recommendations. all is working fine now, other than the added step changing to DNG to get raw info into photoshop.
